Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-11-2005, 07:15 PM   #991
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
Originally Posted by Ramyuras
Any news on the armuture for the TD dyno?
Winding them up right now.... I'll have them finished some time tomorrow.
Curtis,
Curtis Schlaht is offline   Reply With Quote
Old 10-11-2005, 07:19 PM   #992
Curtis,
NICE.
Ramyuras is offline   Reply With Quote
Old 10-11-2005, 09:29 PM   #993
highwayman's Avatar
Modified motors on the other hand do require a bit more tuning to make use of these high-voltage low-IR batteries…. If one were to take a modified motor that was last used with 3300 (assuming the motor ran perfect with these cells) you would definitely notice more commutator wear/discoloration along with elevated operation temperatures. This is simply because mod arms have 90% less resistance than that of a stock motor, and can make better use of the lower internal resistance on these new IB cells. Being that the internal resistance is so low on these batteries mod motors now have more available amperage at their disposal, which isn’t a bad thing, it just means mod motors can now pull more amps out of every corner, and if tuned properly WILL create more power
i'll try a bit more tuning on my mod motors to try and coax a bit more consistent performance in 5 mins. Thanks again
highwayman is offline   Reply With Quote
Old 10-12-2005, 07:22 AM   #994
Alex_kipper's Avatar
hey curtis, my motor is leaving tonight.
i didnt have time to send it yesterday!
Alex Kipp
Alex_kipper is offline   Reply With Quote
Old 10-14-2005, 06:03 PM   #995
Replacement armatures for the CE Turbo Dyno have been added to our e-shop along with 12v lathe armatures… Click on the "Hand Wound Armature" menu tab.
Curtis,
Old 10-14-2005, 06:12 PM   #996
tc3 racer sc's Avatar
Curtis,
hey curtis i miss u at the nats need the power drew had lol
hotbodies cyclone, hotbodies tcxx orca v3 esc
tc3 racer sc is offline   Reply With Quote
Old 10-18-2005, 09:04 AM   #997
Trader Rating: 22 (100%+)
Default 19T ultralight
Hi Curtis
Got the motors today both look great I have a couple of questions on the 19T ultralight? The brushes look like 766s if so would 767s give me more power?
Red springs can I go to purples the track is a large outdoor rubber tyre?
Also what guage wire is the armeature wound with?
Most times I use 767s with purple both sides. Do you run the setup on the motor because of heat.
Regards BJ Spinner
bjspinner is offline   Reply With Quote
Old 10-18-2005, 01:52 PM   #998
Curtis,
Is there anybody at DC MOTOR? placed an order today try calling a few times but no answer.
Old 10-18-2005, 02:25 PM   #999
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Curtis.....I got the Door Prizes for the first leg of our winter point series thanks a ton man. We had 96 entries for the first race not to shabby. I know the guys that walked away with the DC stuff were stoked.....Thanks again for the suport with the series. I qualified 2nd in 19t 12th scale and ended up 4th in the main.....after I got the gearing right that Flame 19t was a missle....Thanks
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 10-18-2005, 03:06 PM   #1000
Originally Posted by bjspinner
Hi Curtis
Regards BJ Spinner
Hey BJ,
Glad the motors arrived... In most cases the 767's will give more power, but they have a tendency to burn up rather quickly, and sometimes there toast before the end of the run. Try the motor like it is, the 766's work quite well on our KR Outlaw 19 Motor... Red springs are a good starting point for the big comm motors; remember the bigger comm pushes the brush out further so your spring tension increases.... All our outlaw 19 arms are wound with 18Awg wire.... Hope this helps.
Curtis
Old 10-18-2005, 03:12 PM   #1001
Were open Monday through Friday 9-5 (Central Time).... If you get the answering machine that means I'm on the line 1, leave a message and I'll back to you ASAP..... Today was a super busy day, I'm actually on the phone right now helping a customer ....
Curtis,
Old 10-18-2005, 03:16 PM   #1002
Hey Kevin,
My pleasure, always happy to give something back to the racers . 96 entries, that GREAT, especially for the first leg..... Glad you like the Quad Mag 19 turn, BTW what rollout did you end up at?
Curtis
Old 10-18-2005, 03:27 PM   #1003
Kevin K's Avatar
I think its 1.92 if my chart is right.....I ran a 32/96 with a 1.83 tire on about a 100ft straight.
Old 10-18-2005, 03:44 PM   #1004
Sweet..... Thanks!!!
Old 10-18-2005, 04:07 PM   #1005
Hey Curtis you got a PM
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
