Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 07-23-2005, 07:46 PM   #586
Scotty Ernst's Avatar
Hi Curtis, package arrived today at Trackside. I gave it to him today when he arrived. Let me know about Vegas.
Take care,
Scotty
Scotty Ernst is offline   Reply With Quote
Old 07-23-2005, 07:52 PM   #587
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
Take care,
Scotty
SWEET, Thanks BOSS!!!
Curtis Schlaht is offline   Reply With Quote
Old 07-23-2005, 09:37 PM   #588
Jeff Brown's Avatar
Curtis....
Got back from the sweat shop earlier tonight. I tested 3 different arms and I think I got the gearings down on them pretty close to perfect. Give me a call tomorrow if you want as my dad and I will be at my place all day Dynoing and comparing.
Its all about Dyno numbers and Amp draw!!
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 07-23-2005, 09:40 PM   #589
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Sweat shop? You should have been racing with us today...I need to move to FL too cool off after today!! My damn pit table was 105 in under the tent in the shade!! Darn batteries were temp cutting off as soon as you hit charge!! LOL
But still put the UL on TQ pace and took the "W" with a lot of luck!!
EA
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 07-23-2005, 09:41 PM   #590
Team EAM
Oh ya Jeff...the Sauce seemed to work good!!
EA
Contact Us
Old 07-24-2005, 01:15 AM   #591
DirtyDog3375's Avatar
Trader Rating: 37 (100%+)
Send a message via MSN to DirtyDog3375
Originally Posted by Curtis Schlaht
We should have more IB 3800 cells available by the 8th of August....
Thanks for the reply Curtis, will order some soon as they're available. Could you please email/pm me if possible???
DirtyDog3375 is offline   Reply With Quote
Old 07-24-2005, 07:20 AM   #592
Jeff Brown's Avatar
EA
Thats good to hear.
Jeff
Old 07-24-2005, 01:34 PM   #593
Will do....
Old 07-24-2005, 05:54 PM   #594
Curtis, i have a coule of DC motors and have been happy with their performance, however the question has been asked of me about their conformation to IFMAR rules, as this is what we base the motor lists on in Australia, our rules call for no mixing of manufacturer components, as such can you please advise how your motors apply to this line of thinking?
12th Scale - The premier class (if you can make runtime)
Besercoe is offline   Reply With Quote
Old 07-24-2005, 08:06 PM   #595
EDWARD2003's Avatar
Default Timing For 8x2 Flat Wire.
Hello everyone, I have a V2 Marc R 10x2 with original brushes (i think enduro). Well anyway i switched brushes to the 2-6 runs and i found it heated the com up really fast. This is what i found out.
I did a temp test on the motor when i first bought it was around 120 f after 5 min run.I raced the motor until i needed to replace the brushes so then i switched to the 2-6 burshes cut the com broke the brushes in and the motor temps went up to 160 f. Is this normal? What is a good temp range for Mod?
Timing is still at 18 degrees.
Now this is my main question, i bought a Epic 8x2 FW arm what timing should I adjust it to? What pinion should i go too? 22 tooth?
I run a TC3 with foams. Pinion is 24 and spur is 100. Rollout is 16.56.
The track has a 150 foot straight and a few technical sections. To sum it up its more of a nitro sedan track. big and wide open.
Edward
EDWARD2003 is offline   Reply With Quote
Old 07-24-2005, 08:10 PM   #596
Rollout is way too low, it would be overheating. I have not used a 10 in ages but i would gear an 8 V2, around 23mm, so i would guess a 10 would be in the 27-28 mm range. This is for a gas style track of course.
Old 07-24-2005, 08:12 PM   #597
Jeff Brown's Avatar
All the teardowns DC Motorsports uses are IFMAR approved worldwide.
The mixing of manufacturers refers to like......... an Orion can, with a Trinity Endbell and a Reedy Armature. I think......... Curtis will correct me if I'm wrong.
Jeff
Old 07-24-2005, 08:16 PM   #598
Jeff Brown's Avatar
Edward
Yeah, undergeared for sure.........
if you are gearing the 8 turn at 24/100 then I would gear that up to about 30-33/100.
Jeff
Old 07-24-2005, 08:16 PM   #599
EDWARD2003's Avatar
Really increase my rollout? Right now i am running 59 mm dia foams. So let me get this, increasing the rollout is like adding another tooth to my pinion? How much per mm is adding one tooth to my gear ratio. Or do i have it backwards?
Confusing but i will figure it out.
Old 07-24-2005, 08:22 PM   #600
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
23 mm sounds about right for an 8 turn...and maybe 24.5 mm for a 10 turn.
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
