Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 06-30-2005, 01:57 AM   #406
Trader Rating: 18 (100%+)
Cool! let me know when they are ready to ship, I'll take three.
Chris Brown is offline   Reply With Quote
Old 06-30-2005, 02:38 AM   #407
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
You're at the top of the list .....
Curtis,
Curtis Schlaht is offline   Reply With Quote
Old 06-30-2005, 02:52 AM   #408
Cool! Hopefully it won't be so hard for me to pay you next time Oh, and my dad says hi. Well, he said a lot, but I stop listening to him after one ortwo sentences.
Old 06-30-2005, 09:10 PM   #409
Trader Rating: 70 (100%+)
Curtis you got pm.
Steve
SpeedZone Batteries
steve eaves is offline   Reply With Quote
Old 07-01-2005, 08:18 AM   #410
Originally Posted by steve eaves
Curtis you got pm.
Steve
Old 07-02-2005, 09:32 AM   #411
Hey Curtis, I got the batteries in yesterday. Thanks again for those and keep me posted on the C2's.
Old 07-02-2005, 12:46 PM   #412
Fatboy Joe's Avatar
Default Cobalt 8x1 Round Wire gearing
Hi, im in need of a good starting point for gearing my cobalt 8x1 round wire motor w/ the standard xxx brush. My track is 112ft x 100ft. Im using a jrxs w spool up front. I started off running a 9.73 final drive (128 spur & 24 pinion), acceleration was not as impressive and lacked topend. Next test was a final drive of 9.3 (128 spur & 25 pinion), it lacked acceleration, but gained some topend, power hits just right after middle part of the 112ft main straight, then i changed pinion to 26T to get a final drive of 9.0, again, no acceleration but has top end although power kicks in rather late. timing of motor is 12degrees. if i hit a final drive of 9.5, will i be able to hit the sweetspot of the motor? im compared performane of this motor against reedy Ti Worlds 8x2, the reedy seemed to be more powerfiu overall. any tips or advice will be greatly appreciated thanks guys
Fatboy Joe is offline   Reply With Quote
Old 07-02-2005, 02:26 PM   #413
HI Joe,
It sound’s like you’re still under geared. Around a 8.6FD is what I’d recommend as a starting point for gearing on a track of that size… To help with bottom end torque you can narrow the face of the XXX P-94 brush to 3.9-3.8mm, and bend the springs an additional 45 degrees for more tension (purple springs)…
Curtis,
Old 07-02-2005, 09:04 PM   #414
Fatboy Joe's Avatar
Originally Posted by Curtis Schlaht
HI Joe,
Curtis,
Hi Curtis,
Thanks for the help Do I still keep the 12deg timing?
Old 07-03-2005, 10:24 AM   #415
Originally Posted by Fatboy Joe
Hi Curtis,
12 degrees is a good starting point (very neutral)… Increasing the timing will help the motor produce more overall power… Your should first try what I have mentioned and see if helps, then try bumping up the timing in 3 degree increments up to 18 degrees for more overall power……
Curtis,
Old 07-03-2005, 11:03 AM   #416
Arun's Avatar
The 8's with the XXX style brushes seem to really come alive for me when I bump the timing up to around 16-18 degrees .
http://nexusracing.com
Arun is offline   Reply With Quote
Old 07-03-2005, 07:41 PM   #417
Fatboy Joe's Avatar
Curtis,
Hi Curtis,
The motor just came alive w power when i followed your instructions. i hit the track as soon as you posted your reply. i hvent touched the timing yet but im already very happy with the available power, now i got more options with tuning for more punch. What more if I was using a UL Arm, il be flying Thanks for the help Curtis.
Old 07-03-2005, 11:32 PM   #418
Ran the 19t's today wow!!Aweaome hp Curtis thanks man,making another order tues i will give you a call
SpeedZone Batteries
Old 07-04-2005, 02:54 AM   #419
DIMO's Avatar
Default Timing, Settings
hey Guys. I am getting myself a DC 7x1. Just wandering what settings i should use on my ESC its a Novak TC. And the track requires a mix of torque/power so what timming should i use. Its my first ever go into modified racing. So dou guys have any tips.
DIMO is offline   Reply With Quote
Old 07-04-2005, 05:12 AM   #420
Default About the Ultra Light arm
Hi Curtis,
This is my first post here and I'm glad that DC has such a big group of supporter. I recently tuned DC motors for a racer in Reedy Asia. My driver handed me two Cobolt based motors with 8 turns Ultra Light arms. When I looked at it, I worried about the satuation as a lot of metal was shaved away. And the round brushes also worry me as the punch and torque will be less (width of brush is wider than standard stand up brush).
I have several questions that would like to have your precious comment:
1) Will the arm over-satuated easily?
2) Will harder spring for Cobolt base motor available?
3) What config of brush is the best for touring? Stand up size? Round? Or the oringal size and cut accordingly to the diameter of the comm?
4) Will hole drilling on XXX brush help the performance?
Thanks for your advice before hand and keep on your good work!
Schumacher
JamesSchumacher is offline   Reply With Quote
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
