Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 06-19-2005, 08:39 AM   #346
Curtis Schlaht's Avatar
Send a message via MSN to Curtis Schlaht
For the best performance out of your IB cells this is what we recommend:
To help maintain consistence through out the batteries life keep a small amount of charge in the pack. Do this by discharging the battery down to .9 per cell after a run. It doesn’t matter what method you use to discharge the battery, a tray type discharger or a GFX will work fine. After the pack has cooled and rested put 500 seconds of charge back into the pack.
For Max Voltage:
Dead shorting the battery will yield the maximum voltage, but at the sacrifice of runtime. We recommend that you dead short you pack for no longer than 24 hours prior to use (a longer period of time did not yield better results). As this will help obtain the maximum life expectancy of the pack and maintain consistency through each cycle… Dead shorting will decrease the batteries runtime on average by 40-50 seconds, just like GP cells. Once a battery has been dead shorted the runtime cannot be regained so make sure this is the route you want to follow… Charging for stock and 19 turn racing: 4Mv per cell at a 6 amp linear charge
For Max runtime:
Store your IB batteries with 500 seconds of charge at all times. Prior to use discharge the battery in a tray down to .9v per cell…. Charge at 5amp linear with a 4-3Mv peak detect…. This will yield a pack with maximum runtime for modified racing…
Curtis,
Curtis Schlaht is offline   Reply With Quote
Old 06-19-2005, 09:31 AM   #347
LazyBug's Avatar
Originally Posted by DirtyDog3375
So, can the same be said for the ib3600 cells? Cause I just bought some and wanted to know how to look after them. (after a race and in between as well). There is so much varying and conflicting information out there. At the moment, all I do is charge them at 6amps linear and after a race discharge them on my charger/discharger at 10 amps and then let them sit till the next time I need to use them (usually 1 week).
Should I be doing anything different? Any help or advice would be greatly appreciated.
According to the distributor, IB has improved the new 3600 cells and with a new shrink. New IB3600 is based on IB3800 cells. So we use same charging/storage way as IB3800. We have found that the new IB3600 has similar runtime as GP3700 but has more punch than GP. The much improvement over the old 3600s are they don't drop much in performance during our 8 minutes race while the old IB3600 only good for 5-6 min. It is really good news to us.
LazyBug is offline   Reply With Quote
Old 06-19-2005, 11:27 AM   #348
Guo Chean's Avatar
Send a message via ICQ to Guo Chean Send a message via Yahoo to Guo Chean
Hi Curtis,
may i know for the IB 3800 cell is that the size will bigger than or same with GP 3300? because for pro 4 they still havent updated the chassis and even 3700GP the size also cannot put on the kit. if the size are same with the 3300 GP i think i would buy and try the battery. thanks
[FONT=Comic Sans MS][SIZE=3][COLOR=red]|HotBodies|HPI|Full Throttle Motorsports|KO PROPO|DSM|Nosram|JACO|MUCH MORE RACING|Schacht Design Works|[/COLOR][/SIZE][/FONT]
Guo Chean is offline   Reply With Quote
Old 06-19-2005, 12:04 PM   #349
Tempest2000's Avatar
Trader Rating: 21 (100%+)
the 3800's and the 3700's are the same size... i.e. bigger in diameter than the 3300's...
Tempest2000 is offline   Reply With Quote
Old 06-19-2005, 02:40 PM   #350
Originally Posted by Guo Chean
Hi Curtis,
Hi Guo, Tempest2000 is correct. The IB 3800 and GP 3700 are both larger in diameter than the GP 3300's.....
Curtis,
Old 06-19-2005, 11:08 PM   #351
Old 06-19-2005, 11:28 PM   #352
LazyBug's Avatar
From what we have on hand, new IB3600 has the same size as GP3300, while IB3800 has the same size as GP3700
Old 06-20-2005, 02:31 AM   #353
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
New to brushed mod motors and would like to know speed difference between the following:
V2 7x1 timing 12 degrees
V2 9x1 timing 18 degrees
both will have same springs and brushes.
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 06-20-2005, 08:08 AM   #354
The more notable differences between the two motors will be acceleration (RIP) and top end... The 7x1 being the faster of the two motors.
Old 06-20-2005, 08:33 PM   #355
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
Curtis or others...what are the timing increments on a revolution motor? We would liek to know beforer we fry it lol, are they 12 degrees? 10 degrees? 7 degrees?
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 06-20-2005, 08:58 PM   #356
danjoy25's Avatar
6 degree on every line.
Old 06-20-2005, 09:15 PM   #357
Jeff Brown's Avatar
6 deg on an Orion/Peak label......... DC labels are 12 deg for each major line on the label.
Jeff
SXT Traction Compounds | www.TractionCompound.com
Jeff Brown is offline   Reply With Quote
Old 06-20-2005, 09:26 PM   #358
Moderator
Thanks guys!
SMC Racing
Old 06-22-2005, 07:01 PM   #359
Guo Chean's Avatar
hey Curtis about the Ti series do you still in production? izzit also will be available to purchased at tomorrow?
thanks
Old 06-22-2005, 11:48 PM   #360
thanks
Our standard Ti modified series is being replaced by the newer Ti3 series. At the moment we've pulled down all the info on the Ti's as we're in the process of updating picture and product description for the Ti3... Our Ti3 series modified motors will be available for purchase on our E-Shop July 1st.
Curtis,
2005 RCX Discussion Thread wizard9x Electric On-Road 2 11-11-2009 06:49 AM
GSRacing discussion thread Panic Singapore R/C Racers 118 12-31-2007 10:34 AM
RRR Discussion Thread tornado Malaysian R/C Racers 84 09-06-2005 08:05 AM
Come Join the IRT + Discussion Thread Cmotif International Racing Team 20 05-01-2004 11:48 PM
