DC Motor Sports Discussion Thread:
#1801
Originally Posted by Curtis Schlaht
Email me your address ([email protected]).... I'll get a replacement out to you tomorrow....
Gearing & timing sounds good. I'd perfer to see you running a slightly harder spring than the std firm. Maybe MR032 4.3 N/mm (8 coil)....
Curt,
Curt,
#1802
the usual cause of this from what i've seen is overtiming the motor - i ran an 8x2 @ 24deg on a mid sized track and had the same thing happen.
the motor still works fine, i just go gentle with it, clubdays, 12th scale etc.
mine was ~5 runs old when it happened too, still going strong after a few months in the 12th scale though
#1804
i usually run 8s on mid-sized tracks at around 18 deg, up to 24deg on small tracks (read: tennis court size)
7 turns live at 6deg, occasionally will do 12 on the small tracks though
#1808
Originally Posted by mini-dub
I always run my 7 turns at no more than 18º, when I tried to dump with a 7x2 once I finally blew it up at 22º... but it was fast . Then for 8 turns I only crank them up to 22º, and 24º for 10 turns.
#1810
We’ve moved!!!
We’ve moved!!!
New Contact info for DC Motorsports….
DC Motorsports
775 County Road 33970
Powderly, TX
75473
PH# 903-737-8555
Email is still the same: [email protected]
-Hours of operation-
M-F 9am-5pm Central Standard Time
Closed Weekends
Curtis,
DC Motorsports
Powderly, TX
75473
PH# 903-737-8555
Closed Weekends
Curtis,
#1811
We’ve moved!!!
DC Motorsports
Powderly, TX
75473
PH# 903-737-8555
Closed Weekends
Curtis,
DC Motorsports
Powderly, TX
75473
PH# 903-737-8555
Closed Weekends
Curtis,
#1812
I'm considering to get couple of IB3800's for Stock Truck and I know you have Battery Assembly option but do you also include Deans connectors with the assembly or does it come with extra cost?
#1815
Okay, fair enough. :-)
Another question then - did you make many changes in gearing for the different powerband? I've been using DC V2 motors and DC Ti3 motors for the past year or so and I expect the Checkpoint to feel quite a bit different in comparison to them because of that powerband change.
