Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-27-2006, 12:41 PM   #1396
Hyperform Racing's Avatar
Nice job at the TSC Carlos. What did you think of the new proto 12th?
Hyperform Racing
www.Hyperform-Racing.com
[email protected]
(978) 416-2572
Hyperform Racing is offline   Reply With Quote
Old 03-27-2006, 12:47 PM   #1397
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
I was supprised with you going to a 4 screw rear pod and a the front was stiffer with more graphite surface area than the original one. The new car would be to stiff for my use on asphalt. One question though, I notice that most guys don't run the upper front brace, what is the reason for this? All in all it is a nice car.
CarlosG. is offline   Reply With Quote
Old 03-27-2006, 03:59 PM   #1398
tpczx6's Avatar
Originally Posted by CarlosG.
I would like to thank Tim for help setting up my car and the driving tips for the Texas State Championships. I now see where the car carries its corner speed. Being that I have not ran my car in over a month and on ran carpet once a year only for this race, I qualified 9th and ended 8th in the A-main with the H-12. I hopefully would like to make it up thee again sometimes this year, but if not next year for the race again. Thanks Tim.
Anytime Carlos
come up and give us a call and we will be out there also if you want to come up during the week sometime if you have a few days Vac let me know and we can go thru your car and let you try out some setup
Tim
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 03-27-2006, 05:29 PM   #1399
The car is def geared towards carpet as was the previous design. The four screw design adds to the stiffness of the top plate allowing the shock to do more of the work. I am considering releasing and asphalt chassis. Basically the same thing but 2mm instead of 2.5mm with more cutouts...
As far as the front brace. Because of manufacturing tolerances, the brace tends to bow the chassis. If you install one, take a straight edge to the front. If it is not tweaked, then run it. CRC also makes a nice adjustable aluminum cross brace although you need to use the older 12l3 style caster blocks...
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-28-2006, 02:44 PM   #1400
Hey guys, I'd like to send out a big congrats to Hyperform Racing team driver Brad Johnson on his win in 19t sedan at the ROAR Region 5 Championships. Nice job Brother.
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-31-2006, 08:31 AM   #1401
Trader Rating: 37 (100%+)
More win...awesome.
Good job Brad.
Leno sent you some info via email.
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 04-03-2006, 09:13 PM   #1402
Nice Job Brad!
Lino, we running 12th friday?
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 04-04-2006, 11:54 AM   #1403
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
From a pan car standpoint, i run oval.. Ive noticed when running a front brace it makes the car inconsistent..
Put it on once then compress one side of the suspension.. if you watch the other side as you compress you will see it moves the other caster block outward.. It honestly doesnt really brace anything. All ive seen it do is force the blocks one way or the other depending on what side the force is on... if it had a mount in the center that bolted to the chassis then it would brace..
Ive seen some guys make them work.. This is just an observation ive noticed when trying to use them..
also if you do want to use one and dont want it to bow the chassis as lino said, take two standoffs, and get a long set screw.. you can have an adjustable mount and set it for perfect lenghth..
burbs is offline   Reply With Quote
Old 04-04-2006, 04:15 PM   #1404
Yes J-Rod, 12th it is brother.
Mike, your package will arrive by 10:30 AM tomorrow via UPS. I'll send you an email with the tracking number. Good luck at the nats!
Hyperform Racing
[email protected]
(978) 416-2572
Old 04-07-2006, 07:00 AM   #1405
CarlosG.'s Avatar
It sure has been quite in the land of Hyperform. What has been going on? Anything new in the works?
Old 04-07-2006, 02:45 PM   #1406
Formula1fan's Avatar
Any idea when you will have motor springs back in stock?
Formula1fan is offline   Reply With Quote
Old 04-07-2006, 11:01 PM   #1407
Yeah, I've been really busy the past couple of weeks. Things are well though. IB4200s are on the way along with the new 12th.
Also, I did get springs in, I just need to update the website...
Hyperform Racing
[email protected]
(978) 416-2572
Old 04-09-2006, 06:00 PM   #1408
Hey guys, wanted to let you know IB3800 1.20-1.209 cells are on sale this month. Click here for pricing and availability.
Also, for those who are not on our mailing list, here is a copy of the April newsletter for you all to read. If you would like to be placed on the mailing list, email [email protected] with subscribe in the subject line. Enjoy!
Hyperform Racing
[email protected]
(978) 416-2572
Old 04-09-2006, 08:34 PM   #1409
BTW, the website has been updated so that all springs can now be ordered...
Hyperform Racing
[email protected]
(978) 416-2572
Old 04-10-2006, 08:14 PM   #1410
gmintimidator's Avatar
I have a 12L3 that I picked up cheap ($20 ) with 2 good and complete axles. The main chassis is broken at the front body mounts, so it's toast. I see that you have a conversion kit available and are in the process of updating it. Will it be about the same money? Does your chassis require tape to hold the cells in?
gmintimidator is offline   Reply With Quote
NEW Hyperform Racing "RAZOR" conversion kit Canuck R/C Items: For Sale/Trade 1 08-22-2006 06:38 PM
!!!new hyperform 12 car for sell!!! lightning11 R/C Items: For Sale/Trade 13 04-08-2006 12:24 AM
Hyperform 12L4 Greg Amendola R/C Items: For Sale/Trade 9 03-16-2006 08:33 PM
anyone bought from Hyperform Racing before? nw racer Electric On-Road 39 08-01-2005 12:19 AM
Hyperform Racing Hyperform Racing Electric On-Road 3 04-11-2005 02:29 PM
