Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-21-2006, 07:33 PM   #1366
chach's Avatar
Jim, After reading your signature line, I'd hate to hear your acceptance speech if you ever won an oscar.
chach is offline   Reply With Quote
Old 03-21-2006, 07:38 PM   #1367
J.Gonzalez's Avatar
Trader Rating: 16 (100%+)
Job well done Jarrod!!
I was listening to the race on line and it sounds like you drove inch perfect for the win...almost had it in 12th scale also...very impressive.
Cheers
Jamie
J.Gonzalez is offline   Reply With Quote
Old 03-21-2006, 09:34 PM   #1368
Hyperform Racing's Avatar
Originally Posted by JoelV
Is it basically the same car with a new top deck and a new chassis? The bottom pod plate and the tweak brace look unchanged.
top
bottom
There is a little bit more going on there as is the case with most 12th kits. They all look the same but it's the little things. First off, we went to a four point top plate. This increases rigidity and allows the shock to do more of the work. The bottom plate is very similar although the hole placement is different since the left pod plate is different. The cross brace is very similar with just some slight aesthetic changes.
The chassis has been refined in many ways. The tbar routing depth has been optimized based on extensive track testing. The cell cutouts are shorter and include battery stops. The battery stops are not installed in the pictures you posted from the nats. The front three cutouts have been eliminated and the fourth one has been changed to allow you to lay the servo flat without interference. Although all components are still cut from the same 2.5mm quasi carbon fiber plate, the new chassis design is significantly stiffer then the previous chassis.
We are really happy with the way the car performed at the nats and will be moving into production next week. More pics and the such will be posted soon. If you have any other questions, please let us know. I'll also try and get Jarrod on here to let you know what he thought of the car. He managed to place third at the nats with it even though it was his first time running the chassis.
Hyperform Racing
www.Hyperform-Racing.com
[email protected]
(978) 416-2572
Hyperform Racing is offline   Reply With Quote
Old 03-21-2006, 11:54 PM   #1369
tpczx6's Avatar
Great job Jarrod
looks like you put the smack down.
conrats to team Hyperform for there first of manny Nats wins will done guys know lets take it outdoors in june and then Vages baby.
J-rod send me the setup we have the texas state champs this weekend
One more time great job Jarrod and Lino
Tim
RcAmerica--Xray---Hudy----KO PROPO USA---ORCA---GRAVITY RC
Motiv------Apexrc----- AVID
SWEEP Racing USA
Mike's Hobbyshop in Dallas (RIP)
Nor-Cal Hobbies [The Race Place]
tpczx6 is offline   Reply With Quote
Old 03-22-2006, 02:36 PM   #1370
Hey guys, the CO27 stock motor has arrived and is now available in both standard and hyper tuned versions. Click here for pricing!
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-22-2006, 02:39 PM   #1371
the_barbarian's Avatar
Hey Lino what do you think the performance is going to like in comparison to the roar and monster
what sort of rpm and torque are we talking
the_barbarian is offline   Reply With Quote
Old 03-22-2006, 02:43 PM   #1372
The seem to have more tourqe then the other two. You have to gear them a few teeth higher then the monster. They are very fast when setup properly though... To be honest, I haven't spun any on the dyno, we have only track tested them thus far.
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-22-2006, 03:02 PM   #1373
Tim you got pm buddy
I will post my set up on here for everyone if you guys are interested. The car was awesome all week start to finish, i was very happy with the car considering the bumps in the track the became progressively worse with more traction.
Since the car started out strong the basic set up of the car didnt require much change through the week, i ended up just trying different tire compounds and battery position to make the car work better through the bumps. For main day the final set up was when the car was fastest, should have it posted shortly for you guys.
www.rikter-designs.com
[email protected]
Jarrod Langlois is offline   Reply With Quote
Old 03-22-2006, 05:19 PM   #1374
I'm no J-Rod, but we ran basically the same setup at the nats.
Front
-New CRC Lowered Front Blocks for the Dynamic Strut
-20 springs
-10 degrees of caster
-1.5 degrees of camber
-1 degree of toe out
-Parma purple tires trued so no shims are required for proper ride height (This keeps the roll center low)
-3.5mm ride height
Rear
-0.063 T-Bar
-Silver center spring (Jarrod ran a blue spring)
-35wt oil
-Batteries in center position (1/8th inch from full back position)
-Trinity Purple Stuff in damper tubes
-96 tooth spur
-Parma grey tires
-3.5mm ride height
If I left anything out, let me know...
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-23-2006, 12:08 AM   #1375
tpczx6's Avatar
Thanks Lino
going to spend all day at track thrusday with new car to make sure I have it ready for the Texas State Race will let you know how its go
Tim
SWEEP Racing USA
Old 03-23-2006, 12:25 PM   #1376
Default pics from nats
Here are some pics from the nats of J-Rod. That's if you can draw your eyes away from that certain someone else on the podium.
Hyperform Racing-nats2.jpg   Hyperform Racing-nats3.jpg   Hyperform Racing-nats1.jpg
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-23-2006, 03:33 PM   #1377
CarlosG.'s Avatar
Send a message via Yahoo to CarlosG.
Heeeyyyy.... Were can I get one of those sweat jackets that J-rod is wearing? I like that along with the lovely eye candy that J-rod is got his arm around.
CarlosG. is offline   Reply With Quote
Old 03-23-2006, 04:14 PM   #1378
I'm out of hooded sweatshirts. Not sure how big of a boy you are, but I have an extra XXXL T-Shirt kicking around...
Hyperform Racing
[email protected]
(978) 416-2572
Old 03-23-2006, 07:25 PM   #1379
CarlosG.'s Avatar
I am not that big of a boy. I am more of an XL. However, put me on a waiting list for a sweatshirt,a polo shirt, and/or t-shirt. I the one J-rod was wearing looked nice.
Old 03-24-2006, 06:07 AM   #1380
Will do Carlos... J-Rod is wearing one of our hooded sweatshirts in that pic. I'll actually be ordering all new swag shortly with the new logo.
Hyperform Racing
[email protected]
(978) 416-2572
NEW Hyperform Racing "RAZOR" conversion kit Canuck R/C Items: For Sale/Trade 1 08-22-2006 06:38 PM
!!!new hyperform 12 car for sell!!! lightning11 R/C Items: For Sale/Trade 13 04-08-2006 12:24 AM
Hyperform 12L4 Greg Amendola R/C Items: For Sale/Trade 9 03-16-2006 08:33 PM
anyone bought from Hyperform Racing before? nw racer Electric On-Road 39 08-01-2005 12:19 AM
Hyperform Racing Hyperform Racing Electric On-Road 3 04-11-2005 02:29 PM
