Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Like Tree1Likes
Old 11-04-2011, 05:52 AM   #31
defcone's Avatar
Trader Rating: 15 (100%+)
Hello all, would the tq 13G wire be up for modified tc applications?
defcone is offline   Reply With Quote
Old 11-04-2011, 07:03 AM   #32
miller tyme's Avatar
Yes, it is what most run quite successfully.
Ken Miller
RCTarget - Capricorn - Pro Level RC - MAX Power - Maxima Fuel - EA Motorsorts - TQ Wire
LONG LIVE OPEN MODIFIED
miller tyme is online now   Reply With Quote
Old 11-04-2011, 09:28 AM   #33
ralph m's Avatar
R/C Tech Charter Subscriber
Trader Rating: 31 (100%+)
I've checked with several team drivers and confirmed that they've been using 13 gauge in mod TC with no issues.
tqwire.com
ralph m is offline   Reply With Quote
Old 11-04-2011, 10:55 AM   #34
Mike Haynes's Avatar
For sure, i have been using it for mod sedan on carpet and asphault with no issues at all, even with 4.0 motor and boost.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-05-2011, 09:36 PM   #35
HEADSHOTPUNK's Avatar
Will the 13 gauge wire work for a 7.5T Ballistic motor? My setup is a TLR 22 with a Tekin Rs and 7.5T Ballistic on indoor clay. I was also curious why you don't make a 12 gauge?
Thanks!
HEADSHOTPUNK is offline   Reply With Quote
Old 11-05-2011, 11:35 PM   #36
Thanks!
Yes it will work fine.
I may get corrected here but, I don't think 12g is warranted, due to the high quality copper and the fine strands resulting in higher strand count the current capability of the 13q is better than others 12q
Ken Miller
Old 11-06-2011, 12:24 AM   #37
I figured that was probably the case. I already ordered the 5 wire 1ft package because of all the good stuff I had heard.
Old 11-06-2011, 12:37 AM   #38
1 other question. I plan on swapping out the 7.5 Ballistic stator for a 17.5 stator to run stock but I dont want to desolder every time I swap them so I was going to go with 4mm high efficiency/current bullet connectors. Is this okay, or is it that much better to solder the motor straight to the esc?
Old 11-06-2011, 05:24 AM   #39
Soldering is always better, but i do know a few mod guys running the bullet connector, mostly the guys with Speed passion mods, they don't seem to be giving anything up. Go ahead and try it and just feel the connector after a run and as long as it is not hot (indicating a power loss) you should be ok
Ken Miller
Old 11-06-2011, 08:30 AM   #40
ralph m's Avatar
Thanks!
We've tested the wire with low turn mod motors in sedan, buggy etc. using 2S and have no reported drop off in power. I would think your experience will be the same. That said, 12 gauge with the same stranding will have the capacity to carry more current - the question is whether the extra weight (usually higher than the CG) is really neccessary.
There are lots of companies doing 12 gauge, Deans makes an excellent product, so I didn't think we needed to duplicate something already available.
tqwire.com
Old 12-01-2011, 07:07 AM   #41
Warren Weaver's Avatar
Trader Rating: 47 (100%+)
The flatwire sensor cables are sweet
R1 WURKS-AWESOMATIX USA-LRP-BITTYDESIGN-TQ WIRE-PROTOTYPE RACING-SWEEP RACING-TXDSKINGRAPHIX-HOBMAX-THE RUG-TEAM EZDUZIT
R.I.P. MY FRIEND JDUB MISSED BUT NEVER FORGOTTEN
Warren Weaver is offline   Reply With Quote
Old 03-15-2012, 10:57 AM   #42
ralph m's Avatar
New low profile, Silver Plated 4mm bullet male connectors provide lower resistance. Available in 18mm and 14mm lengths.
http://www.tqwire.com/balance_&_power_cables.htm
tqwire.com
Old 03-22-2012, 10:12 PM   #43
k_bojar's Avatar
Trader Rating: 30 (100%+)
Send a message via ICQ to k_bojar Send a message via AIM to k_bojar
Hey Ralph - quick question...
when you measure your sensor wires and they are, say, 50mm, is it 50mm end-to-end, including plugs or 50mm between the plugs??
Trying to figure out what size to get to setup my TCS car
thanks
Kaybo
Bodies By Bean | Team Belly
k_bojar is offline   Reply With Quote
Old 03-22-2012, 11:36 PM   #44
ralph m's Avatar
Between the plugs.
tqwire.com
Old 03-23-2012, 06:04 AM   #45
k_bojar's Avatar
Originally Posted by ralph m View Post
Between the plugs.
thank you, sir
Do Not Buy Anything From TQ RACING PRODUCTS bubbafrc Electric Off-Road 82 05-23-2011 06:51 PM
Deans wire broqenjeep Electric On-Road 12 11-10-2009 06:58 AM
