Go Back  R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Trinity and ReVtech Motors discussion >
Like Tree321Likes
Old 07-19-2022, 10:40 AM
  #1306
Bar
Default Posted wrong
Bar is offline
Old 07-20-2022, 04:52 PM
  #1307
Anyone Have any Touring car 21.5t gearing / timing or 17.5t gearing / Timing setups for asphalt? for the new Trinity slot machine ?
Aurora_007 is offline
Old 07-23-2022, 05:13 PM
  #1308
BEMO2019's Avatar
For the Revtech 21.5 3.7 FDR 17.5 4.1 FDR. This is on a track with around a 100' straight. I don't have a slot machine yet but this should be a solid starting point.
BEMO2019 is offline
Old 07-25-2022, 07:09 AM
  #1309
Bar
Originally Posted by Marcos.J View Post
Does it sacrifice any revs for more torque or is it just a faster motor overall?
Bar is offline
Old 07-25-2022, 07:57 AM
  #1310
Super Moderator
Marcos.J's Avatar
Trader Rating: 235 (100%+)
overall about the same with a better bottom end , 4.05 FDR worked out pretty well still trying out different timing settings but 47degrees on the motorlyzer the motor came off at 135 degrees with 149.2 degree track temps
Bar likes this.
Marcos.J is offline
Old 08-03-2022, 03:38 PM
  #1311
Super Moderator
Slo_E4's Avatar
Trader Rating: 61 (100%+)
I’ve seen that before.
Marcos.J and gigaplex like this.
Slo_E4 is offline
Old 08-14-2022, 08:12 PM
  #1312
Originally Posted by b-man777 View Post
Hey y’all: Just curious to know a few things about the new Trinity esc. 1st: Is their new esc’s being made in house or outsourced and by who?
2nd: Will they offer a 1s version?
Trinity ESCs are made by ZTW, just like Pro Performance, Fantom, Reds, Team Powers, ETC. I even use my Pro Performance programmer on my Trinity ESC. They said in one of their videos a 1s version will be coming later, but didn’t mention a timeline as far as I remember.
Bcollins82 is offline
Old 08-15-2022, 10:22 AM
  #1313
I picked up a 13.5 slot machine at the hobby shop a week ago. I reached out to Trinity and they said team drivers are running around 46 degrees of timing and are up 4 teeth on their pinion from what they were running on their xfactors.
b.j.a is offline
Old 08-19-2022, 10:01 AM
  #1314
BEMO2019's Avatar
Has anyone experienced issues with the new sensor board/bearing design?
I have a 1 year old revtech 5.0, the bearing on the sensor board side got pushed in causing the rotor to eat the hall sensors. This broke the stator and esc in the process.
Another racer purchased a slot machine 17.5 and experienced the same issue. Did not cause any further damage beyond the sensorboard.
Both instances were with a touring car. No major impacts with either cars and the bearings were not removed from the sensor board assembly prior to running. The design is flawed allowing this to happen as the bearing is not backed and can allow the rotor to be pushed into the sensor board. This isn't an issue with the previous trinity motors.
BEMO2019 is offline
Old 09-18-2022, 07:52 PM
  #1315
I’ve been trying to find the “sweet spot” for my 21.5 slot machine for a couple weeks now. I’m running gt12 1s rubber tires on crc black carpet. No one else at my track is using the slot machine. Any ideas or suggestions would be helpful. Thanks
Kruss45 is offline
Old 09-19-2022, 01:12 AM
  #1316
bertottius's Avatar
Trader Rating: 26 (100%+)
try 45-48 degrees timing and a lot of gear
hanulec likes this.
bertottius is offline
Old 09-20-2022, 07:41 PM
  #1317
I should also say that the motor has the red high torque rotor installed. Does that make any difference on what timing I should set it to?
Kruss45 is offline
Old 09-21-2022, 01:37 AM
  #1318
bertottius's Avatar
I haven't tried the red rotor in it yet but I would probably say to set it at 48 and just gear it 3 teeth higher than you usually would with say, an Xfactor.
Antimullet and Kruss45 like this.
Old 09-25-2022, 07:10 PM
  #1319
Trader Rating: 65 (100%+)
This is true, both my 13.5 and 17.5 car are at minimum 2 teeth up. Even on a pretty small track. Medium to Large track I can easily see that tall of a gear.
Antimullet is offline
