Like Tree78Likes
EAMotorsports discussion thread
Old 07-05-2015, 07:36 PM
  #7591
Suspended
Originally Posted by gsxr0311
Anybody know of other low ir batteries except ea and smc. Both of those companies are out of stock.
smc has 2s 40c 5000mah in stock...just bought my first one from them the other day...i usually run 70c turnigy's
kongluc is offline
Old 07-10-2015, 01:05 AM
  #7592
B00t13g's Avatar
Ea has his excellent 5000 70c packs in stock, as well as his new 8200 80c.
http://www.teameamotorsports.com/ind...tegory&path=60
B00t13g is offline
Old 07-13-2015, 03:55 PM
  #7593
R/C Tech Elite Member
Jamison R's Avatar
Trader Rating: 66 (100%+)
That new battery and D4 13.5 1s in my 12th scale has amazing power. Just what I needed. Thanks Eric. Good stuff.
Jamison R is offline
Old 07-13-2015, 05:46 PM
  #7594
Team EAM
Trader Rating: 79 (100%+)
Great to hear Jamison! LMK if you need anything else.
EA
EAMotorsports is offline
Old 07-13-2015, 05:47 PM
  #7595
Team EAM
Thanks Mackie. LMK how you like them in Mod!
EA
Old 07-13-2015, 06:02 PM
  #7596
EA
He could use a driver if you have one available
Racermac73 is offline
Old 07-14-2015, 08:56 AM
  #7597
Cosmo's Avatar
Zing!
Cosmo is offline
Old 07-31-2015, 06:45 AM
  #7598
Jamison R's Avatar
Eric- I need to replace switch on orca 1s. Can you buy just the switch?
Old 08-03-2015, 07:04 AM
  #7599
Jamison R's Avatar
Now that is beyond expectations for customer service. Thanks Eric. Switch was in package with my new battery. Awesome!!!
Old 08-03-2015, 12:45 PM
  #7600
Team EAM
Not a problem Jamison. Ive seen a few get broken because the on off button is so long. Happened to me a few times too!
Thanks as always!
EA
Old 08-07-2015, 07:49 AM
  #7601
xevias's Avatar
Default Puffed Batteries
How puffed is too much?
I left a couple 1S and 2S batteries in a very hot pit room for 2-3 weeks and they puffed up. Each of them rocks on my setup board about 1/8". The cases are in tact, but one of the 2S batteries feels "squishy".
I cycled them on my iCharger just to see if their numbers are still good. 10A charge with a 10A discharge (don't have equipment to do higher discharge).
All the batteries came off the cycles with resistance less than 3 ohms per cell.
Numbers say the cells are still good, but I can't tell if they pass the smell test.
What do you think?
xevias is offline
Old 08-08-2015, 07:58 AM
  #7602
Team EAM
What do you think?
All batteries will puff a little when put through use and especially heat. As long as they still perform well and numbers look good I will still use them UNLESS the case seam starts to split and the battery just looks like it could break open at any time. Then I will not use them anymore. I always use a lipo sack and always keep an eye on them when charging (Make sure to always balance charge too).
EA
Old 08-09-2015, 05:07 AM
  #7603
Jamison R's Avatar
What rotor are you using for 1/12 17.5 in a short stack D4?
Old 08-09-2015, 10:12 AM
  #7604
Team EAM
As far as I know everyone is running the 12.5HT rotor in pretty much all spec classes. Some people have ran the 12.3 standard as well and it will run better down the straight but the car has to be very very good or it will heat up and fade.
EA
Old 08-10-2015, 09:24 AM
  #7605
SLOWINSLOWOUT's Avatar
Trader Rating: 20 (100%+)
What size bearings do the D4 motors use?
SLOWINSLOWOUT is offline
