Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-04-2004, 10:58 PM   #91
Imjonah, if John didn't answer your question, you probably didn't ask what you were thinking about. I'd hate for you to imply that most matchers produce fake numbers, because that is not the case. You imply that you don't have the equipment to test the true parameters of a cell, since you're wondering how to test a battery without the equipment. If you don't have the equipment, then how can you tell if a matcher is lying?
There are so many variables when checking batteries that there is a good chance that your numbers will be different than what a matcher provides. What could be the cause of the discrepency? Old equipment could be an issue. How are the contacts on your battery box? Are you using the same matching equipment? What battery charge rate are you using? How long do you let the battery sit between charging and discharging? What is the temperature and humidity of the test environment? Does it stay constant during the cycle, or does it vary? How about the airflow in the room? Do you blowing across the cells? Does the velocity of the air change throughout the cycle, i.e is it just a breeze entering the room? Have you had any runs on the batteries since you bought them?
The bottom line is that you can't necessarily compare numbers from matcher to matcher. I think John will also agree with this, different matchers will do different things to their test environment, and this will in turn affect the test results. For example, you cannot compare Reedy's Realtime cells to Fusion's cells because the voltage measurement parameters are competely different! This is not to say that one is right and one is wrong, they just do things differently. Likewise, Orion's numbers are not comparable. What really matters is that there is consistency in the matching processes of a given brand, and this is an issue of product control. I like fusion's products along with a few other matchers, and I hate it when people make broad negative generalizations such as yours.
Since it seems like you want to be really technical about your other question, here is the answer. There is really no equation converting battery matching parameters into acceleration, so what John was implying was using a sort of acid test to determine the relative punch of two batteries. There is a theoretical truth that lower IR battery will have more punch than a higher IR battery, ALL ELSE EQUAL. That means that it will reach the end of the straightaway quicker from a dead stop. All else equal, a battery with higher voltage throughout a discharge cycle will have higher top speed, and also reach the end of the straightaway earlier. But, which is better, the battery with higher average voltage and lower IR, or vice versa? There is no equation for that. Then it becomes a question of looking at the powerband of the given motor. For some motors and some tracks , one battery will work better than the other.
071crazy is offline   Reply With Quote
Old 08-05-2004, 12:37 AM   #92
EddieO's Avatar
R/C Tech Charter Subscriber
I source out my batteries to be Matched by Fusion for my company, Team br00d Racing. I have randomly checked cells from them on my turbomatchers......and everything always check out fine.
And to answer your question.....there really is no way for anyone to answer that. There are simply TOO many variables, you will never get an answer from that even from Danny at SMC or Mike Reedy at AE.......
Simple comparison....go to a real engine builder with your real car....ask him the same question if you would add another 50 HP to your car. I am sure he can give you some BS answer, but any guy with a clue is going to give you the same type of answer John did. And likewise, look in a jegs catalog at any type of engine performance part, they will all say adds 50hp or whatever.....you won't see any say, add 2.5 meters per second to your 0-60 distance...
If you want to test the cells, simply borrow someones 1.15 and cycle them on a GFX(borrow one if you need to)....then cycle some 1.17s....you will see the difference on the charger if the numbers are correct(try to get two batteries around the same age that have been properly cared for). Once you SEE the numbers for yourself, its basic electronics at that point.
Later EddieO
www.teambrood.com
EddieO is offline   Reply With Quote
Old 08-06-2004, 04:23 PM   #93
thanks for helping explain what I was trying to say. cheers guys
John Malin is offline   Reply With Quote
Old 08-10-2004, 08:13 AM   #94
Good luck to the pimp and team butter at Fernando this week for the norrca nats.
Old 08-10-2004, 07:35 PM   #95
RCGaryK's Avatar
John, I just got back in town and I got your PM. I will call you at the shop tomorrow sometime. Anytime better than another?
Site Content Specialist- Surface
HorizonHobby.Com
Horizon Hobby is on YouTube with hundreds of different videos! Visit us at
http://www.youtube.com/HorizonRCdotCom
RCGaryK is offline   Reply With Quote
Old 08-11-2004, 07:37 AM   #96
9-5 is good
Old 08-11-2004, 08:04 PM   #97
RCGaryK's Avatar
how about 4 + 2 more? LOL
HorizonHobby.Com
Old 08-16-2004, 08:08 AM   #98
congrats to Furman walker for winning 19t at the Norcca Nats. Good job to Michael Abraira for putting his car in the top 5 as well.
Keep up the good work fellas.
John
Old 08-16-2004, 01:11 PM   #99
TeamButter's Avatar
Send a message via AIM to TeamButter
Just wanted to thank Fusion Batteries for the awesme Power this past weekend at the Norcca Nats.. I placed 5th in the A-main in 19 turn and teammate Furman "Former" Walker brought the win home for Fusion Power with an impressive display of driving in the main. Congrats Furman!! Mr. 2004 Norcca 19Turn National Champion!!!
If you ain't Fusion.....you losin!!!!!!!
Xray / BMI Racing / KO Propo / Team Epic / Parma-PSE / High Velocity Racing / TeamButter / P3 Graphics / MDI Racing
TeamButter is offline   Reply With Quote
Old 08-16-2004, 01:50 PM   #100
onebeatuptc3's Avatar
Send a message via AIM to onebeatuptc3
John, thanks for your return email (i sent you an email about my pack and about it getting fixed). Whats the address to send my pack in to, to get it fixed?
onebeatuptc3 is offline   Reply With Quote
Old 08-16-2004, 02:07 PM   #101
Brandon Melton's Avatar
Send a message via AIM to Brandon Melton
Congrats to Furman, he is definatly a nice guy and a great representative for your company. I know how he felt the first day, I had the same kind of luck, but he showed his caliber and battled back in a big way during Saturdays qualifying.
Butter- Nice to meet you, and put a name with a face. See ya around.
Team Associated~Reedy~Werks Racing~Pro-Line~Competition Suspension Inc.~Schelle Racing Innovations
Brandon Melton is offline   Reply With Quote
Old 08-16-2004, 02:26 PM   #102
Butter- It was nice to meet you this past weekend and congrats to Furman, I also wanted to let Fusion know that Michael represents your company well. He's definetly an asset.
Brandt
Ozwald Bates is offline   Reply With Quote
Old 08-16-2004, 04:04 PM   #103
Regional Moderator
kumpol's Avatar
Brandt
I don't know what else to say.
FUSION GUYS ROCK!!!
kumpol is offline   Reply With Quote
Old 08-16-2004, 04:55 PM   #104
TeamButter's Avatar
Brandon-Nice to meet you too!! Hopefully next time you won't have half as many radio problems as you did this past week!!!
Old 08-16-2004, 05:06 PM   #105
Yeah, the glitching killed my Friday and my car, lol. The time wrenching sucks, but it's the $40 in parts that hurts, lol. I was heading to the house if Fernando hadn't had the extra radio for me. My first couple runs with it were shaky, you know how it is to just pick up someone's radio for the first time to qualify with it. It was all in all a fun weekend. Did all of you guys' property down in FL end up OK from the storm?
Fusion Batteries...anyone? John Malin Electric Off-Road 121 03-03-2015 05:30 AM
Fusion Batteries racer6888 R/C Items: For Sale/Trade 1 12-07-2005 07:01 AM
FUSION BATTERIES 1.16 380 ONE NEW AND OLD jocktheglide R/C Items: For Sale/Trade 0 06-30-2005 11:31 PM
Fusion Batteries!!! Techart27 Electric On-Road 58 06-12-2004 09:10 AM
