Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 05-08-2005, 12:26 PM   #991
axel's Avatar
Hey, i'm intersted in buying some fusion batteries off their site. When they send you your batteries, do you know what numbers you get prior to when recieving them?
axel is offline   Reply With Quote
Old 05-08-2005, 03:02 PM   #992
Brian McGreevy's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to Brian McGreevy Send a message via Yahoo to Brian McGreevy
axel,
When you order off the site, you will see the range in which the packs are. The Team packs are 1.170-1.174, the Factory Team packs are 1.175-1.180 and lately there have been a plethora of Worlds packs, which are 1.180+.
Hope that helps
USVTA Member #211
Support Formula SAE - get kids into engineering!
http://motorsports.illinois.edu/
Brian McGreevy is offline   Reply With Quote
Old 05-08-2005, 03:15 PM   #993
axel's Avatar
thanks, but i was also looking to find the i.r. and maybe runtime.
Old 05-08-2005, 03:30 PM   #994
IR isn't on the site, but runtime is. I forgot that, sorry. You won't be disappointed in any of the numbers; Fusion packs rip, and I don't say that just because I am a team driver.
USVTA Member #211
Old 05-08-2005, 04:07 PM   #995
axel's Avatar
Well my main concern is punch so IR is what i'm looking for. I know fukayama batteries have very low IR. But i like Fusion's service and how they deliver pre-built, and also because they are well known matcher. so Brian what kind of IR's do most 1.175+ have?
Old 05-08-2005, 04:18 PM   #996
Most of the 1.175 batteries will have an IR of around 15-16. I have seen lower IR's on a friend's Fukuyama packs, but the Fusions are never lacking in rip. Remember, numbers from matcher to matcher are never totally comparable. Try them and you'll see for yourself. I guarantee you won't be disappointed.
USVTA Member #211
Old 05-08-2005, 05:07 PM   #997
mini-dub's Avatar
Trader Rating: 16 (100%+)
Also remember that when you build packs your self you risk damaging the cells performance from over heating them, Fusion packs are never damaged during assembly. So even if the IR on your buddies pack says it's lower, it may have been damaged during assembly and not have the performance of those numbers.
Weylin Rose - www.shiftedcinema.com
Riding Bikes | Skiing | Helis | Rotor Rage | Cyclone Blades | RC Trim | Dead Kat Raceway
mini-dub is offline   Reply With Quote
Old 05-08-2005, 05:08 PM   #998
axel's Avatar
Default Hard Wiring vs. Deans plugs
What can i expect if i directly solder my esc to my batteries? I'm wondering becuase i want to know if soldering my esc to my batteries all the time is worth it? Righ now i'm using deans plugs. Also would i have to change wire gauge on my lrp sport esc when hard wiring?
Old 05-08-2005, 08:15 PM   #999
Post Re: Hard Wiring vs. Deans plugs
You shouldn't have to change the wire guage it should be fine . But as for using deans . thats ok . I solder direct and have no problems .. if you never tried it , it will take a bit of time to get used to . meaning being ready for your heats and not rushing on soldering your wires and having bad solder connections ... I think it is worth it altho deans more of a convience , especially if running more than one car with the same batt's ... but you can always convert your other cars too ....
give it a try and see if its benifical to you ......
Mark Barden .
mb racer is offline   Reply With Quote
Old 05-08-2005, 08:17 PM   #1000
axel's Avatar
thanks, do you see any battery performance difference
Old 05-08-2005, 09:31 PM   #1001
Post
well there is less resistance when wiring direct , so there should be some difference . maybe small but its there ...
Mark Barden .
Old 05-09-2005, 04:12 AM   #1002
MadMikeB's Avatar
Shouldn't it be pretty simple to test a lenght of cable, then test some Dean's with a simple multi meter? I would be very suprised if there is any on-track noticeable difference.
MIKE
MadMikeB is offline   Reply With Quote
Old 05-10-2005, 07:40 PM   #1003
Korey Harbke's Avatar
Generally it shouldn't be super noticeable. But there are more solder joints for electricity to pass through, so that means more resistance. There is a reason Pro drivers hardwire their packs to the battery bars.
-Korey
Xray - RC America - Hudy - Apex RC - LRP - Protoform - AVID - 1Up Racing - Xenon - Xpert - Sanwa - RC Mission America - SpeedZombi - Slapmaster Tools - Turtlemaster Racing - Seattle RC Racers
Korey Harbke is offline   Reply With Quote
Old 05-10-2005, 08:52 PM   #1004
axel's Avatar
-Korey
why is that?
Old 05-10-2005, 08:57 PM   #1005
From what I understand solder isn't always as efficient as some think. Solder has a fair amount of resistance in it, but I guess it depends on the solder. I know Fusion uses a really high quality solder for making their battery packs that has less resistance. Someone should correct me if I'm wrong though lol.
-Korey
Fusion Batteries...anyone? John Malin Electric Off-Road 121 03-03-2015 05:30 AM
Fusion Batteries racer6888 R/C Items: For Sale/Trade 1 12-07-2005 07:01 AM
FUSION BATTERIES 1.16 380 ONE NEW AND OLD jocktheglide R/C Items: For Sale/Trade 0 06-30-2005 11:31 PM
Fusion Batteries!!! Techart27 Electric On-Road 58 06-12-2004 09:10 AM
