Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-06-2005, 01:13 PM   #886
OK Red here is the story with Mv settings. You have to look at this in three ways all at once..... First is this settien determines your chargers sensitivity to shutting the charger off after peak(almost an after peak delay of sorts), second after a pack peaks your pack is basically going into overcharge...The Mv setting determines how much overcharge you get by monitoring the delta voltage movement, having said that it is also kinda like a thermometer for your charger. Bigger mv per cell or pack the hotter the battery will be when it is done. So if you are in a hot environment I would go smaller on the Mv number for less overcharge/heat. Do just the opposite in a cool environment. You are looking for the temp to come to around 120 degrees F. i HOPE THAT SHEDS A LITTLE BIT OF LIGHT FOR YOU.
John
John Malin is offline   Reply With Quote
Old 04-06-2005, 01:19 PM   #887
crimson eagle's Avatar
Send a message via ICQ to crimson eagle
Thanks John,
From what I understand Mv is based on each cell? i have never had a charger which uses Mv so I don't know how to set them up. In the winter I temperature charge to 115f. in the summer the ambient temp is too warm so I peak charge with a lower fallback (.03).
Chris.
crimson eagle is offline   Reply With Quote
Old 04-06-2005, 02:00 PM   #888
R/C Tech Charter Subscriber
Trader Rating: 24 (100%+)
Thanks for the tips guys. Crimson: I will try "traying" them as you suggested. John: I get the mV setting now. Thanks. BTW Fusion was well represented at the Midwest Touring Series this last weekend. My racing wasn't as spectacular as I'd hoped (I didn't have enough motor to pull the track!), but I got faster each time I was out. Nick Billie also did pretty well.
RC Tech Subscriber # 79
Red Z is offline   Reply With Quote
Old 04-06-2005, 07:59 PM   #889
KoE
KoE's Avatar
Send a message via Yahoo to KoE
john,
can you look at order #3180 and put "R/C parts" on the form tax kinda hefty ya know LOL! btw, what's the runtime can i expect out of the packs?
Yo!
KoE is offline   Reply With Quote
Old 04-08-2005, 09:13 AM   #890
Send a message via AIM to loosenut
Hey can you guys recommend the best discharger for the fusion 3300 packs - for mod electric sedan applications. FYI, i have a LRP PULSAR for general discharge functions - would that be sufficient? Thx!!
Tekno SCT410//B44.x Avid Chasis//B5M//HW 3656 - 4700 kv// HW V10//MT-4
loosenut is offline   Reply With Quote
Old 04-08-2005, 09:20 AM   #891
The common theory is to discharge at approximately the load at which you are racing. Having said that you should look for a discharger that simulates a load near which you race. You said mod so I am thinking something like the Integy zero-thirty might do the trick.
John
Old 04-08-2005, 09:29 AM   #892
Cool I'll get that one then! I'm a little confused though....
If I get the zero-thirty , would I still need a equalizing tray?
G
Old 04-08-2005, 10:19 AM   #893
That tray is an individual cell discharger. Seems the jury is still out on if equalizing with a higher discharge rate is better or worse. However that tray will double as an equalizer of sorts.
John
Old 04-08-2005, 10:25 AM   #894
Default JOHN MALIN
another great day in cali going to tamiya tomarrow more testing, maybe some super secret RDX testing , how are things going ? im out charlie a
lickrim is offline   Reply With Quote
Old 04-08-2005, 11:32 AM   #895
Umm..couldn't I use my PULSAR to discharge the batter at 30 AMP and get a seperate equalizing tray?
G
Old 04-08-2005, 11:47 AM   #896
Default pulsar
no 30 amp discharge try GFX
Old 04-08-2005, 12:54 PM   #897
Hi All,
I like discharging at 30A down to 1 volt per cell but I when I go to equalising I want it to be at a very low rate. I like the idea of having a higher resistance across the cells when taking that last little piece out and also I think with a high equalising load you depress the voltage a lot which does not help in getting the most out of your cells that you can. The cheapest integy try is about $20 and has a 0.5A discharge (at least initially anyway)
Chris
Old 04-08-2005, 02:38 PM   #898
Ok...it is best to have a DISCHARGER like zero-30 AND another seperate equalizer like..say a novack smar tray....
That's the part I was confused about. Is there a unit that can discharge at 30 amp and do the equalizing function at a lower amp?
G
Old 04-08-2005, 03:09 PM   #899
loosenut,
I do not know of an all in one unit to do both but I would say there was a benefit to having sepperate units. The "Light Tree" dischargers seem to work ok for the higher amp discharges, just make sure it has a voltage cutoff. There is any number of cheap discharge trays which will equalise nice and slow. But do not get the equaliser which stops when the cells gets to a certain voltage. To get the best of your cells you need to keep the load on them for a fair amount of time (at least 2 hours). You can tell by how much you are putting into your cells on charge if you have equalised enough. For low run time cells you should be around 4000 on charge, for high run time cells I have seen 4300+. This does depend on age and condition to a certain extent.
Chris
Old 04-08-2005, 03:16 PM   #900
GMartinez's Avatar
Trader Rating: 85 (100%+)
Hey fellas been away for a while but just wanted everyone to know that I am not going to be part of the team for personal reasons. It was great being a part of the team & good luck to everyone
www.fullthrottlercraceway.com
Home of The U.S. World Nitro Cup 2013,2014,2015,2016
2014 Roar Electric Nationals, IFMAR ISTC Worlds, 2015 Roar Fuel Nationals
2017 U.S.World Nitro Cup Nov 29th - Dec 3rd
U.S.Open Fuel Championship Returning soon
GMartinez is offline   Reply With Quote
Fusion Batteries...anyone? John Malin Electric Off-Road 121 03-03-2015 05:30 AM
Fusion Batteries racer6888 R/C Items: For Sale/Trade 1 12-07-2005 07:01 AM
FUSION BATTERIES 1.16 380 ONE NEW AND OLD jocktheglide R/C Items: For Sale/Trade 0 06-30-2005 11:31 PM
Fusion Batteries!!! Techart27 Electric On-Road 58 06-12-2004 09:10 AM
