Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 06-24-2004, 08:19 PM   #16
you should be able to charge them as high as 6 amps with no trouble. the packs will run just fine without cycling them. You should discharge them first before charging them. Use a turbo 35 or something like it to get the batteries to 0.9v per cell then charge them as usual. when you store them discharge them to 0.9v per cell and put them away. If you arent going to use them for more than a week put about 5 mins of charge back into them before you store them. This will help them keep their runtime up.
John Malin is offline   Reply With Quote
Old 06-24-2004, 08:43 PM   #17
j240z's Avatar
Default Heat sink bars?
Do you guys sell just the battery bars by themselves?
j240z is offline   Reply With Quote
Old 06-25-2004, 07:14 AM   #18
No we do not sell the bars seperately. We would not want someone to build a pack with them claiming it was our build.
Old 06-25-2004, 11:38 AM   #19
Hey J240z, I have a source that you can get those bars but it will
cost you more than the reg bars.
Dr Smooth is offline   Reply With Quote
Old 06-25-2004, 04:19 PM   #20
The bars are patented so you may get bars just not ones with heat sinks on them.
Old 06-26-2004, 11:31 PM   #21
ttt
Old 06-27-2004, 01:53 PM   #22
peter_robinson's Avatar
Trader Rating: 21 (100%+)
hey john, get ready for the onroad nats, becuase my pan car is super dialed! were you still sending me stuff? shoot me an email to let me know.
peter
For orders or inquiries, email [email protected] Follow RC-Trim on Twitter and Facebook
RC-Trim | Serpent USA | On-Point | Trinity | Revtech | ORCA | BSR | KO Propo | PT RC Racing Oil | WTRC | rcpitwhores.com
peter_robinson is offline   Reply With Quote
Old 06-28-2004, 02:37 PM   #23
Announcing a 20 percent off sale !!!! Including 1.18s coupon code to follow.
572H-1F4B9T Use this code at www.fusionbatteries.com and get 20 percent off all packs.
Old 06-29-2004, 08:51 AM   #24
You better hope it is super dialed. I just might hafta come out and school you on on old school pan car racing.
Old 06-29-2004, 04:15 PM   #25
LancerEvoV's Avatar
hey, just a dumb question, but i was wondering what all the settings are to charge my 3300's on a peak charger. They are 1.1's with 390 runtimes.
thanks much,
a new racer
LancerEvoV is offline   Reply With Quote
Old 06-29-2004, 07:32 PM   #26
FUSION FOR LIFE BLACK PIMP IN DA HOUSE,SEE YA AT THE NATS
layedbackpimp is offline   Reply With Quote
Old 06-30-2004, 10:00 AM   #27
There are only a couple of settings you need to look at. First is the charge rate or current. Depending on your type of racing you will want to charge between 4.5 and 6 amps. The next setting that you need to know about is the peak detection fall back voltage or delta peak. If your charger has an adjustment for this setting you should set it to 0.03 volts or 30mv. Those were numbers if your charger does the delta by total pack voltage. If your charger measures by cell voltage then 5 mv would be good. Assuming you are chaRGING NI-MH you should be using the linear mode if you have it. The only other settings that may be of interest is trickle charge, flex charge, and long lock out. If you have long lock out it is used for charging batteries that were mostly dead, it is used to keep the charger from false peaking early. Trickle charge does exactly as its name implies. You would want to turn this feature off. Flex charging is for old tired batteries that might benefit from having the built up crystalline structures broken down thereby giving back some of their intial performance. I hope this helps.
John
Old 06-30-2004, 03:37 PM   #28
LancerEvoV's Avatar
thanks a bunch
Old 06-30-2004, 09:31 PM   #29
Glad I could help.
Old 07-01-2004, 01:06 PM   #30
still got 1.18s for 76.00 if any one is looking for some. Use this code on the web site 572h-1f4b9t or just call the shop 954-227-1301.
John
Fusion Batteries...anyone? John Malin Electric Off-Road 121 03-03-2015 05:30 AM
Fusion Batteries racer6888 R/C Items: For Sale/Trade 1 12-07-2005 07:01 AM
FUSION BATTERIES 1.16 380 ONE NEW AND OLD jocktheglide R/C Items: For Sale/Trade 0 06-30-2005 11:31 PM
Fusion Batteries!!! Techart27 Electric On-Road 58 06-12-2004 09:10 AM
