Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-19-2005, 12:03 AM   #1486
TTT
Mark Barden .
mb racer is offline   Reply With Quote
Old 11-19-2005, 12:43 PM   #1487
I UNDERSTAND JOHNS NOT WITH FUSION ANYMORE?
pony klr is offline   Reply With Quote
Old 11-19-2005, 01:57 PM   #1488
Nothing could be further from the truth Dave. I have changed my responsibilities to refelect what I am best at. I will be doing all of th4e high level research and development of all of the new products. I will not be managing the team except at major events where I will be present.
John
John Malin is offline   Reply With Quote
Old 11-20-2005, 04:59 AM   #1489
RED-LINE M03's Avatar
Trader Rating: 127 (100%+)
Default question
Now I am racing every week or two should I change the maintenance on the packs?????
RED-LINE M03
ORLANDO FL.
220 Posts Since Jun 2005 09-17-2005, 06:09 AM need a little help Post #1365
Need a little help!!!!!!!!!!!
I purchased preassembled 3300 from fusion two weeks ago and have not had time to build my first touring car.I will be racing my car about once a month. I am a NEW-B to the r\c world so any help would be very appreciated. This is what I have to work with LRP COMP 2 with 10 amp discharge and a set of lights @ 30 amp discharge............
Thanks,
E
RED-LINE M03
View Public Profile
Send a private message to RED-LINE M03
Send email to RED-LINE M03
Find More Posts by RED-LINE M03
Add RED-LINE M03 to Your Buddy List
John Malin
833 Posts Since Dec 2002 09-17-2005, 08:51 AM Report | Post #1366
redline charge those at 5 amps for about 10 minutes and then put them away until you are ready to use them. Then when you are ready to use them discharge them first then charge them up fully.
John
Wide open til u see GOD then brake!!!!
If you're not Fusion you're losin!!!!
Fusion Team Manager
Team Tekin
FJ Creations
RED-LINE M03 is offline   Reply With Quote
Old 11-20-2005, 09:13 AM   #1490
Nope same still applies. The newer cells are marked better than 3300's though. Be advised.
John
Old 11-20-2005, 09:19 AM   #1491
Public safety has found that my talents are very useful. So My primary mode of employ is now working with the the public safety community. I am still however involved with Fusion In the R&D of new products and on going evaluations of matching procedures for best performance. In a way you could say that I am now a consultant to the company. That said I will answer any and all technical questions to the best of my ability. All team driver inquiries and orders need to be placed with Jeff or Judy.
John
Old 11-20-2005, 03:42 PM   #1492
jamescam's Avatar
R/C Tech Charter Subscriber
I bought 3 packs of 3300's & 3 packs of 3700's then my wife was put into the hospital due to pregnancy complications and they sat without a charge for about 2 months. Yesterday when I went to use them at the 1st Round of our local Winter Off-Road series they acted very weird. I first put each pack on my Novak Smart Tray and discharged each cell to .9 then charged them on my Turbo 35 BL at 6amps to a PK Detect of .05 volts. I was getting a charge done message after anywhere from 400 to 2200 seconds!
Here are my charger settings as well as actual cycle numbers from a 3300 pack I cycled a few minutes ago:
Turbo 35 BL
CHARGE
1 Peak CHRG 6.0
Trickle N
Long LockOut N
Pk1 Detect V .05
TFLex1 N Level 1
DISCHARGE
AMP 30 6c
Cutoff V5.50 6c
Fusion 3300
AV 1.181 to 1.183 SEC 0422
Peak Chg V 9.14
Rel Int Res 166
Act Int Res 32.3
mA HR 3083
mW HR 3083
Dischg Time 370
DS AVE V 6.59
DS AVE @ IV 6.62
Supply Volt 14.39
A few questions...
1. How good/bad are these numbers for 3300's?
2. Any ideas for putting some life back into them?
3. If there are any Turbo 35 BL users out there what is the average time in seconds should it take to charge 3300's at 6amps? I was thinking 2200 seconds is about 10 mins too quick but I'm no expert.
Appreciate any help you can offer. Thank you!
jamescam is offline   Reply With Quote
Old 11-20-2005, 03:50 PM   #1493
Trader Rating: 32 (100%+)
I'm not sure about all those settings, but any charger with any battery will deliver 100 mah per minute at 6 amps.
If I figured it correctly it is 1980 seconds for 3300 at 6 amps (if it is constant charge)
gulio is offline   Reply With Quote
Old 11-20-2005, 04:07 PM   #1494
jamescam's Avatar
I think you missed the question portion
Old 11-20-2005, 04:13 PM   #1495
I was attempting to answer number 3 question only.
Old 11-20-2005, 04:24 PM   #1496
James it wouls appear that your cells sat discharged for quite some time. Unfortunately 3300 do not seem to tolerate this very well. 3300 have a tendency to trade runtime for voltage after having been stored for long period without use. I would try cycling your packs a few times and using a good cell equalizing tray in between cycles. The run time numbers you showed were about what decent used 3300 are but the voltage numbers were very depressed. Please try cycling and then get back to me.
John
Old 11-20-2005, 04:27 PM   #1497
jamescam's Avatar
Now I see, thank you!
John, will do. Yes they sat discharged. No fault of Fusion just trying to do what I can to bring them back up to par. Hoping the Trinity Dyna Pulse will help.
Old 11-20-2005, 04:51 PM   #1498
jamescam's Avatar
Should I charge at a lower amp (maybe 4 or 5amps instead of 6) to help bring them back to life? What about lowering the Peak Detect to .03 or .04? What about discharging at a lower amp?
Old 11-20-2005, 07:59 PM   #1499
Thumbs down John Malin,FUSION so called TEAM?
Well john,I guess this is the only way we can talk!!???
I have emailed you several times,called and left messages 4 times,with NO results!!!!
But you sure can talk on here,so lets talk!!
I have asked you if a certain person was now on the team,w/no response again!
I have been waiting for batteries for 3 months now,plus you NEVER gave the raffle packs for FOCAR!!!!...
But I guess if you are an OVAL racer,FUSION could care less about you!!!!
I believe this is a case of,you being a so called on road racer,and fusions team manager,that you could care less about OVAL racers!!!!!!
And don't even respond with BS about how you do care about OVAL,and that you just went through a hurricane!!!!
Because this was 2 1/2 months before any of that!!!!!
I don't want anything from you,I am just PO'd,at the whole thing!!
You sure do talk a good game,but I think most of it is guessing(hot air)!!!
It is too bad the only way to communicate with you is through here,But I bet if I was an on road racer you would have sent what you promised and answered me by now!?
You don't need to respond,because I quite,I no longer wish to be a part of your one sided BS!!!.I have another sponsor who I think will honor both oval and on road EQUALLY!!!!!!
And I think any oval racer should know that they are not welcomed at fusion,in my personal opinion!!!!!!!!!!!!
Good luck!!!!!!!!!!!!!CYA!!!!!
45 TEAM FUSION is offline   Reply With Quote
Old 11-20-2005, 08:17 PM   #1500
Charlie O's Avatar
Wow im glad i just pay for mine at 30-40 bucks a pack who needs sponsorship, when i started 4 years ago you couldn't get a 2000 nicad pack for that much, let alone matched, built, and kickin!
Charlie O is offline   Reply With Quote
Fusion Batteries...anyone? John Malin Electric Off-Road 121 03-03-2015 05:30 AM
Fusion Batteries racer6888 R/C Items: For Sale/Trade 1 12-07-2005 07:01 AM
FUSION BATTERIES 1.16 380 ONE NEW AND OLD jocktheglide R/C Items: For Sale/Trade 0 06-30-2005 11:31 PM
Fusion Batteries!!! Techart27 Electric On-Road 58 06-12-2004 09:10 AM
