Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-10-2005, 10:04 PM   #3406
Regional Moderator
UnderDaHill's Avatar
Send a message via AIM to UnderDaHill
Originally posted by tony q
fellow teammates have you guys heard the new charger RECORD BREAKER i know some people here they get good results more info visit speedtechrc.com
Sorry... I don't follow. What are you talking about?
UnderDaHill is offline   Reply With Quote
Old 02-11-2005, 12:13 AM   #3407
tony q's Avatar
it's a new charger and only speedtechrc has it. it was use by hara and surikarn at jmarc in japan and in japan itselt already sold 10,000 unit. the charger has a 3-step charge mode. my friend bought one his 3300 olds packs use to peak at 2800mah w/ the new charger it peaks at almost 4000mah and w/ a high voltage w/in a month i will get one. more info visit the web.
tony q is offline   Reply With Quote
Old 02-11-2005, 07:00 AM   #3408
Just wanted to say glad to be a part of Surge!! Ordered some batteries this week can't wait to get them in!!
beanster is offline   Reply With Quote
Old 02-11-2005, 08:30 AM   #3409
Super Moderator
Trader Rating: 17 (100%+)
If it uses a three step charging method it could pump the Mah up by charging at say 6 amps then lower then even lower again. Remember that you want linear charges unless you are trying to break up the crystals in your cells (shock an old pack back to life). Most people will recomend 6.0 amps with .03 cutoff. Your packs should peak off around 9.0 volts and the temp should be around 140 degrees. I dont dead short and I have always had power to spare.
Tekno|JConcepts|TeamTrinity|BOOMrc
Bob Barry is offline   Reply With Quote
Old 02-11-2005, 09:27 AM   #3410
Beanster - welcome aboard!!
A 6 amp charge is a good starting point for 3300's, but .03 threshold is usually too high for the latest generation cells - Try .01 first, if your cells don't get to around 140 degress bump it up on the next charge until they reach that temperature. The reason I suggest this is because if your peak detection voltage threshold is too high, you will loose voltage as you're actually overcharging your cells.
Rule of thumb - Start low, gradually work up.
I haven't seen this new charger, I'm gonna have to look into it.. So many extreme charging choices!! I'm finally using a GFX <grin> and I have to say I still liked the Futaba CDR's features better. In the whole week I used it before it died, it showed me it had features the GFX just can't touch.
ghuber is offline   Reply With Quote
Old 02-11-2005, 02:51 PM   #3411
Trader Rating: 74 (100%+)
Default .
Most people will recomend 6.0 amps with .03 cutoff. Your packs should peak off around 9.0 volts and the temp should be around 140 degrees. I dont dead short and I have always had power to spare. [/B][/QUOTE]
Yeah, thats because you used Surge products!
Team and Sales Manager for USRC Imports, home of Sworkz! Looking for drivers for 2017-2018, KingMax Servos www.kingmaxhobby.com Gens Ace www.gensace.com, MIP www.miponline.com,Schelle , WWW. Schelleracing.com, Slavich Designs, GARCIA GRAPHIX
CHECK OUT GARCIA GRAPHIX ON FACEBOOK -LOOKING FOR 2017 TEAM DRIVER'S!
Raul Garcia is offline   Reply With Quote
Old 02-11-2005, 02:53 PM   #3412
Default call me
Gary,
give me a hollar, I did what you had asked me to do. I will pm my # to you. Thanks.
Old 02-11-2005, 02:54 PM   #3413
Super Moderator
Actually slick thats what I have been doing since Panosonic 3000's. Ive tried just about every method. Being in Trinity country allowed me to get alot of packs and ideas and this was the all around best.
Old 02-11-2005, 08:15 PM   #3414
imjonah's Avatar
Default I am confused about these new 3600/3700/3800
I am not that knowledgeable about electronics.
It seems that voltage is the standard by which everyone grades batteries. To the point, that 5 hundredths of a volt (difference between 1.75 and 1.8) is considered significant. In a 6 batt pack that is 3/10ths of a volt difference during the flat part of the discharge curve 6.9 volts vs 7.2 volts.
Since at least for stock racing any 3300 will go 6+ minutes
Where is the gain from using 3600+ batteries?
Isn't there away at least theoretically to increase voltage using a transformer. Would it be possible to use the additional storage capacity to hike voltage? and give up unneeded extra runtime?
imjonah is offline   Reply With Quote
Old 02-11-2005, 08:19 PM   #3415
Company Representative
Tres's Avatar
R/C Tech Charter Subscriber
Trader Rating: 14 (100%+)
Transfomers work on AC, not DC.....
You can increase DC voltage other ways, but at the expense of amperage...
It's all part of the create/destroy energy thing...
Tre's
TnT-Fx Custom Graphics
www.tnt-fx.com
Tres is offline   Reply With Quote
Old 02-11-2005, 10:57 PM   #3416
tony q's Avatar
i ordered my batts and motors last night can't wait to use them.
Old 02-13-2005, 07:11 PM   #3417
Trader Rating: 20 (100%+)
Send a message via AIM to Jamie Fredericks Send a message via MSN to Jamie Fredericks
bump it up! how did everyones racing this weekend go?
Jamie Fredericks is offline   Reply With Quote
Old 02-13-2005, 07:21 PM   #3418
RJ1
RJ1's Avatar
Well unfortunately the only racing I saw was the Bud Shootout last night. Had to work this weekend. Local track was closed though because most of the guys went to the snowbirds. Hopefully things will get cranked back up next weekend.
RJ1 is offline   Reply With Quote
Old 02-13-2005, 09:05 PM   #3419
tony q's Avatar
no racing this time my merchandise did'nt arrive maybe tomorrow.
Old 02-13-2005, 10:16 PM   #3420
Jack Smash's Avatar
Trader Rating: 29 (100%+)
Finally got to run for the first time this year. Club race in Stockton, CA. Comp is tight in Northern Cali. 8 cars in mod, all on the same lap in qualifying. Got punted in every heat, qualifed 7.
Got a good start in the main, up to 5th. Picked off another car and started realing in third. The car that was running behind me had more corner speed than I did and just drilled the back of my car, pushed the back of the body in and had to wait for a marshall. Got going again and finished 6th.
A bad day of racing is better than a good day at work
Gotta find some corner speed though, need about 3 tenths a lap. Car felt good though.
My next race probably wont be until the State Carpet Champs in March. We get one whole day for practice so I should be able to get the car sorted.
Kyosho / Orion / Amain.com / Protek / MIP /
Jack Smash is offline   Reply With Quote
Surge problem!!!! ghj1997 Electric Off-Road 2 07-01-2008 03:16 PM
12th scale associated. free shipping worldwide kurtcash R/C Items: For Sale/Trade 2 01-21-2008 08:14 AM
Mugen MTX3 Prospec 3mm Chassis $50 shipping worldwide asw7576 R/C Items: For Sale/Trade 0 07-19-2005 10:39 AM
shortage worldwide of FK kits DUE TO NEW CAR COMMING OUT? VenomWorldOrder Australian Racing 72 01-18-2005 11:37 PM
