Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-11-2004, 02:03 PM   #2176
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Default Re: ...see how much stuff this starts...
Originally posted by punkboy
How bout dem Pro4's??
Look pretty good when someone else runs them!!!!!! I do like that car. Might get another one sometime and deck it out with another BMI setup on it.
ST Racing Concepts (STRC)
Old 11-11-2004, 02:06 PM   #2177
L.Fairtrace's Avatar
Trader Rating: 23 (100%+)
Send a message via AIM to L.Fairtrace
Im running the xray this weekend with the xxxs as a backup. I have it here with all my stuff in it. I found out today that I have to work next saturday but I might be able to make it. But I think I can still go to the ORL race.
Awesomatix USA - EaMotorsports - RocheUSA - MonTech - Sanwa - BSR Racing Tires - TQ Wire - Solaris Racing Tires - Side Piece Racing
180 and 360 Raceway. Best on the East Coast. Take your pick
L.Fairtrace is offline   Reply With Quote
Old 11-11-2004, 02:07 PM   #2178
Jon Williams's Avatar
That's cool. Let us know how it goes for ya.
Jon Williams is offline   Reply With Quote
Old 11-11-2004, 03:44 PM   #2179
blast's Avatar
Trader Rating: 28 (100%+)
Send a message via AIM to blast
[QUOTE]Originally posted by punkboy
[B]what ya doin that for?
To give my front more protection and to stop my body from alot of cracking. Yea i know stop hitting things and i wont have that problem.
Patrick Connors
FTM Grip
You're not fast if you don't have the grip
A Master key can open any lock, but a lock that can be open by any key is an sloppy lock.
blast is offline   Reply With Quote
Old 11-11-2004, 03:52 PM   #2180
rcinsight's Avatar
Is there a nerf bar for the TC4 to protect the rear arms in a collision?
I had a TC3 set from Burp and they saved the arms but, just had to replace outer bearings once in a while.
They won't even come close to fitting the TC4.
rcinsight is offline   Reply With Quote
Old 11-11-2004, 04:01 PM   #2181
MR JOLLY's Avatar
Location: MOOD;; feeling good not racing ,saving shed loads of money,lovely Tan i have aswell
Jon
I`m running a X-ray FT with a BMI 350 in gold very nice & tarty, i call it MR T ,here`s a pic
EAMotorsports;;BRCA 27t National 2007 Champ's
FKO4,AdyB fan club !!
saying of the month;;The Past is History, the Future is a Mystery, this Moment is a Gift- that's why it's called The Present.
MR JOLLY is offline   Reply With Quote
Old 11-11-2004, 05:16 PM   #2182
blast's Avatar
MR JOLLY very sweeeeet chassis.... Jason is the man
Patrick Connors
FTM Grip
Old 11-11-2004, 05:36 PM   #2183
Trader Rating: 244 (99%+)
Check this out guys!!
DYNO-CHARGE
Dyno-Charge Features :
16x2 dot matrix blue backlit LCD display Soft touch buttons
Compact size : 5x5x2.2"(125x134x58mm)
PWM technology: light weight, compact,
cooler operation, high efficiency,
quiet operation
DC Charger Features :
Linear current with adjustable delta voltage
Adjustable charge current 0.5 - 8A (0.1A incre.)
Programmable temperature cut-off (without overheating batteries)
Celsius( C) and Fahrenheit( F) selections Selectable initial peak
lockout to prevent false peak (on/off)
Auto detect number of cells (1-8 cells)
Replaceable input and output fuses LCD Display : output voltage,
output current, charging capacity,
charge time (secs.), battery temperature ( C/ F), charging status,
peak voltage, and input voltage
5 programmable charging profile memories Temperature
probe included Motor Dyno Features :
Over current protection
Selectable output voltage 0.1 - 8V (0.1V incre.)
10 spin up speed selections
5 motor data memories
10 break-in pulse speeds
LCD display : output voltage, current draw,
RPM, run time(secs.) and supply voltage
Adjustable break-in time
Can be used to power comm. lathe Optical RPM sensor included Aluminum motor mount included
Specifications:
Dimensions ........................................ 5"x5"x2.2"(125x134x58mm)
Weight .................................................. ................... 1.5 lb, 680 g
Input Voltage .................................................. ....... 12-16 volts DC
Charging Mode .................................................. ................. Linear
Charging Capability .................................................. ...... 1 - 8 cells
Charge Current ............................................. 0.5 - 8 A (0.1A incre.)
Delta Peak ................................. 10 - 200mV (per pack, 1mV incre.)
Initial Peak Lockout .......................60 secs.(default), 600 secs.(long)
Temperature cutoff ...................................... 59 - 140oF (15 - 60oC)
Programmable Charge Profile Memories.........................................5
Motor Test Run ................................................. 0.1 - 8 V(max. 20A)
Motor Data Memories......................... 5 (max. RPM & max. Amp draw)
Motor Spin-up Speed .................................. 0.2 - 2V/secs. (10 levels)
Motor Break-in .................................................. . 0.1 - 8V(max. 20A)
Motor Break-in Timer ..........................10 - 3600 secs.(10 secs. incre.)
Break-in Pulse Speeds............................................ ......................10
Protection..........................Input/output fuses, Input RVP, Short Circuit
LCD - Display .................................... 2 Line, 16 character Blue Backlit
Buttons .................................................. ................... 4 (Soft Touch)
Fred Perkins is offline   Reply With Quote
Old 11-11-2004, 06:23 PM   #2184
Mr. Jolly - that chassis is *sick*. Awesome bling-factor.
Fred - looks pretty sweet. What kind of street-price are we talking?
Old 11-11-2004, 06:34 PM   #2185
JDXray's Avatar
Send a message via AIM to JDXray
http://www.rcuniverse.com/product_gu...product_id=258
Street price is 249!
JDXray is offline   Reply With Quote
Old 11-11-2004, 06:44 PM   #2186
reilly's Avatar
Now that's what i'm takin about.
who makes it?? and where and when can I get one. Does it do the multipe rate changing like the pitbull x3? Any info would be great. Thanks
CEFX, Express Motorsports, Parma, Reilly Paint
reilly is offline   Reply With Quote
Old 11-11-2004, 06:48 PM   #2187
Mike Haynes's Avatar
DYNO-CHARGE
Old Man, i should be one of the first able to test it, i will let you all know how it is as soon as i get mine.
Team Associated - Reedy Power - Sweep - Protoform - TQ Wire - Lacher paint
Mike Haynes is offline   Reply With Quote
Old 11-11-2004, 06:57 PM   #2188
That what I want to know! Where can I get one!!
Old 11-11-2004, 07:01 PM   #2189
BANG BANG BABY !
Troubled is offline   Reply With Quote
Old 11-11-2004, 07:29 PM   #2190
From what i have been told, they are still not available yet, not even to team drivers. Possibly a month till you can grab it, i wasnt given a date tho so you cant quote me on that. I will tell you as soon as i find out.
Surge problem!!!! ghj1997 Electric Off-Road 2 07-01-2008 03:16 PM
12th scale associated. free shipping worldwide kurtcash R/C Items: For Sale/Trade 2 01-21-2008 08:14 AM
Mugen MTX3 Prospec 3mm Chassis $50 shipping worldwide asw7576 R/C Items: For Sale/Trade 0 07-19-2005 10:39 AM
shortage worldwide of FK kits DUE TO NEW CAR COMMING OUT? VenomWorldOrder Australian Racing 72 01-18-2005 11:37 PM
