Team ORCA USA Discussion Thread
#421
what size track are you running on, and is it a tight track or a nice sweeping one? i too have set the motor to the specs you mentioned before and about 50 different other combinations in between and im running like 160-165 deg, ive also messed with the rotor spacing, in the motor, what kind of car do you have, and what kind of esc are you running?
#422
My VTA car motor gets hot while another driver's VTA motor runs cool with similar gearing. I can't figure it out either.
This is the track and the car in the video is not with this ORCA motor.
+ YouTube Video | |
#423
You don't HAVE to run your motor up to 160 degrees. If it has enough speed and isn't getting hot then thats good. I've had motors never get over 135 no matter what gearing I threw at it. I just geared it so I had the best lapped times and left it. ended up temping around 125 when all was said and done.
I currently run my 17.5 on a very similar track in size but slightly lower grip than what you guys have over on the west side. I temp about 165 after 6 minutes. I'm running 3.72 fdr as well in my T4 '14. I'm just under 2mm past the last mark.
Only way to know though is to go up a tooth and see what it feels like. It may get you more top end down the straight but kill your infield speed. Thats how it was for me when I tried.
#424
#425
Just wanted to drop a note in here and thank EA for his help with the VXX. I was never a huge fan of the brakes in the VX, but this new ESC really got it right. Feels better than my LRP which is hard to do. Buttery smooth throttle, perfect brakes, and such a compelling looking package. Plus, its reversed A/C wires make it perfect in the Awesomatix. Love it!
#426
Sorry if this has been asked before, I have just got the Orca TX 13.5 motor and was wondering what is the safe running temp for these motors as I don't want to fry it!!
Thanks in advance
Thanks in advance
#428
TX Motor bearings?
What type of bearings are in the TX motor from the factory? What size are they if I was looking to upgrade them?
#429
#430
I looked there first, they list the ceramic bearings but absolutely no information on the size or specification of the stock bearings or the ceramic replacement bearings.
#431
You can check their actual thread its like orca rc products ask a question they answer quick he said that you need a special tool to replace the sensor board bearing I was looking to replace mine as well because its TIGHT google the part number on the bearing specs should come up
#432
Team EAM
These are awesome Ceramics if you want some for the motor. http://www.avidrc.com/product/1/bear...-bearings.html
They are 1/8 x 3/8 x 5/32.
EA
EA
#433
Eric do you have, or can you get, replacement motor cans? I just need the end the motor mounts to. Managed to hit something with my TC and bent it slightly. I rotated the can 60 degrees or whatever it is and the motor mounts straight in the car now but would like to replace it if I can.
#434
Looking for FDR suggestions for 17.5TX.
This is the track layout which as you can see (see video) is tight and technical accompanied with a 82 foot long straight.
http://www.youtube.com/watch?v=gCFMSryT7k8
Now, in the video below I am using a TRION 17.5 (Japanese) with a 13.5 rotor.. crazy torque, but too much off throttle drag.. Now the speed control is using dynamic hybrid boost turbo (reventon pro 1.1)
The only problem is now my track has decided on doing away with motor timing and esc boost/turbo ect.
In summary we can only run blinky/fixed timing.
#435
