Team ORCA USA Discussion Thread
#751
Team EAM
Not sure what happened to the Orca website but they do not list any of the VX3 systems on the website. Further to this they do not even have the firmware's available for download anymore. Does anyone know what is happening or where I can get the most up to date files from?
On a side note I tried to connect a VX-1 up with the USB Link and it will not find it for some reason. Does anyone know if the new software works on Windows 10? Going to try google next but hope someone can help out here first..
Jr
Jr
The software worked on the original release of windows 10 but they updated it 2 weeks ago and not it does not work. Im not smart enough to figure out why either.
EA
#752
Jr
Jr
Regards,
Ian
#754
for those looking to install orca software/driver on windows 10
try running the following command in cmd prompt as administrator
bcdedit /set testsigning on
then reboot
then reboot
#755
Firmware Change?
I have an ORCA card with one of the newer if not the newest firmwares presently installed on it. I would like to know if it's possible to download and install an older firmware version onto this card so I can use it with my ORCA Spark? My current version doesn't support the Spark. If so, would I be able to go back to the newer version afterward to use with my newest ORCA ESC's?
#756
should be no problem. you can load any software version and go back and forth without any issue.
#757
tech question guys,program card read error when i try to go truh the set up menu. Any sugestions?
#759
Team EAM
#761
Well - the vast majority of businesses are closed on Sunday, no? Also, yesterday was a holiday where About RC Racing is located, so needless to say they were probably spending it with their families. Now they'll need to get caught up from all the requests they received over the weekend ... so be patient and give them some time to respond.
#762
I'm guessing no new firmware update that increases drag brake for VXX and VX3?
I see the new Hobbywing XR10 Pro finally has PWM that might match the smoothness of Orca, but it probably has the drag brake I need for F1. I'd prefer to stick with Orca!
#764
VXL3 ESC HELP?
Recently purchased a new VXL3 and rx3 combo. I ran 4 packs through it and now it's screeching like hell. Thought it was the sensor wire and changed it multiple times, it still squeeled. Tried a another motor and it still squeeled. I'm now thinking it's the esc.
I was wondering if anybody had contact info or info on how to get a hold of orca for warranty service.
#765
Team EAM
Anthony is his name.
EA
