Team ORCA USA Discussion Thread
#242
Andrew's settings from the Snowbirds were:
Drag Brake - Off
Initial Brake - Off
Brake Frequency - 1K
PWM - 4K
Punch - 10
Andrew doesn't like to run much brake - so you might need to play around with the settings if you prefer more brake.
Regards,
Ian (Andrew's Dad)
#243
Hi,
Drag Brake - Off
Initial Brake - Off
PWM - 4K
Punch - 10
Regards,
Ian (Andrew's Dad)
Drag Brake - Off
Initial Brake - Off
PWM - 4K
Punch - 10
Regards,
Ian (Andrew's Dad)
what were his Mod settings?
I'm thinking about running a 6.5? what setting would you recommend? carpet, 90 foot long straight..
thanks for any input
#245
Hi,
Can you help me with a starting set up with Vitra VX speedo et RX2 10,5 motor blinky mode on high grip carpet please?
especially with brake and PWM frequency please
Can I start with punch at 10?
Where can I find some examples of speedo set up please? I don't find on Orca website.
thanx,
thanx,
#246
Here are Andrew's settings for Mod (5.5 ORCA TX Motor)
1,25%
2,19%
3,normal
4,0.05
5,27*
6,-2
7,4%
8,4%
9,4k
10,6
11,8K
At our local track, we have a number of people getting into Mod and I recommend that they use the ESC in blinky mode until they get used to the speed of Mod.
Regards,
Ian
#248
It depends on the backup at the ROAR lab. If there are a ton of motors there (Which I assume there will be since approvals have been closed for 3 months) then it could take several weeks. Add on any thing that needs to be questioned or extra paper work. I would say 4-6 weeks is a safe bet.
EA
EA
#250
Hi,
thanx,
thanx,
#252
thanx a lot I will try this at the beginning.
#253
I bought a Orca TX 17.5.
Can anyone tell me spec on the motor? Kv, rotor size?
Then how much onboard timing does it have and how much will the timing advance with each notch? The center notch show 10*?
#255
i also send them a mail, but. Nothing yet. Any luck from your side?
