Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-17-2004, 09:05 AM   #676
PMRGirl's Avatar
Red face Hello!
ASM~ Got your e-mail this morning! Thanks It was a pleasure meeting you at the birds and I am sure we will be in touch more often We are glad to Welcome you to our Team and hope you have a great racing season
Evoracer~ It was great to meet you. I am always glad to put faces to the voices I hear on the phone.
RC-J~ Your batteries are fine. If you don't like them or wish to exchange them please let me know and I will get you all situated.
promatchrcr~
PMRGirl is offline   Reply With Quote
Old 02-17-2004, 09:30 AM   #677
Whats the best way to charge the 3300's?
Homer Allman is offline   Reply With Quote
Old 02-17-2004, 10:13 AM   #678
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Homer,this is from the website:
How do I charge the GP 3300 cells?
I recommend charging these cells at 5-6 amps with a .03 peak detect (CEI turbo thirty/thirty five). A lower amp rate will give more run time and a higher charge rate will give more voltage. When using any charger follow the manufacturers recommended settings for charging. If no instructions are available start with the lowest possible peak detection setting (if available) and charge the pack. Check the temperature of the pack immediately after the charger shuts off. If the temperature falls within our recommended settings then leave the peak detection setting there. If it is too low the increase the setting and try again. Continue to use this method until satisfactory results are obtained. Use a charger that was specifically designed to charge NI-MH cells. To verify that the pack is fully charged you should check the temperature. We recommend a temperature reading between 125-130 degrees F when the charger first shuts off. The temperature will continue to rise after the charger has shut off so the temperature reading should be taken immediately after the charger shuts off. NIMH cells do not peak like ni-cads do. When a ni-cad battery reaches a full charge the voltage in the pack starts to drop quite rapidly. With ni-mh cells the voltage does not drop as rapidly when the pack reaches full charge. On the other hand the temperature does rise quite rapidly as the pack reaches full charge. The cells can get extremely hot when using some peak detection chargers as the peak detection circuit is not sensitive enough. If the cells get too hot damage to them will occur.
There is alot of good info there along with what I posted above if you want to check it out:http://www.promatchracing.com/techsupport.htm
Hope this helps!
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 02-17-2004, 10:16 AM   #679
jaysimpson's Avatar
Default Re: Hello!
promatchrcr~ [/B]
Whats up!?
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-17-2004, 10:20 AM   #680
Thanks I'll check it out. Be sure to check out the RCN.
Old 02-17-2004, 10:24 AM   #681
Chill Will's Avatar
Chill Will is offline   Reply With Quote
Old 02-17-2004, 12:14 PM   #682
jaysimpson's Avatar
LOL Will do Homer...
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-17-2004, 04:04 PM   #683
Chill Will's Avatar
Old 02-17-2004, 04:20 PM   #684
SOuthernFRIED's Avatar
Trader Rating: 21 (100%+)
Is Pro Match using the new short button cells now? I would like to know before I order some new packs.
SOuthernFRIED is offline   Reply With Quote
Old 02-17-2004, 04:44 PM   #685
Send a message via AIM to ZER01
Southern Fried, yes they are matching the new shorter can GP's.
ZER01 is offline   Reply With Quote
Old 02-17-2004, 06:11 PM   #686
Thanks for the info.
Old 02-17-2004, 07:04 PM   #687
Default Re: Hello!
promatchrcr~
Thanks for the reply. They work fine, I was just curious if any difference between the short/regular tab cells would present a problem. I haven't done any research to check to see if they are different at all. No need in worring about exchanging them and thanks for the offer.
RC-J is offline   Reply With Quote
Old 02-17-2004, 07:15 PM   #688
Tech Legend
Cain's Avatar
Trader Rating: 240 (100%+)
actually I have read from other matchers that the new GPs have more punch than similar voltage older GP cells. So these new ones should even be better!
Cain is online now   Reply With Quote
Old 02-18-2004, 07:29 AM   #689
jaysimpson's Avatar
Yeah the newer short cells IMO have more punch and perform better than the older "long can" cells. I have some with lower voltage than some of my older "long" cells and they are even better.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 02-18-2004, 08:02 AM   #690
Still Bill's Avatar
Hi Korgae,
Are the new shorter 3300 cells lighter in weight than the larger cells? How much?
Constantly evolving CRC WGT and WGT-R/T...Carpet & Asphalt...All thanks to Team CRC.
And a pair of Associated B6 buggies for turf and clay tracks.
Still Bill is offline   Reply With Quote
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
