Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 01-13-2004, 12:17 AM   #496
losi jon's Avatar
well since i race at night right after i get off of work i usually have to charge my batts during the day before i go to work and "repeak" at the track and have noticed no difference in voltage or runtime versus the occasional time i can charge and peak the batt at the track and run it right away....so it's your call on this,see how it works for you.
losi jon is offline   Reply With Quote
Old 01-13-2004, 12:28 AM   #497
fatdoggy's Avatar
R/C Tech Charter Subscriber
What you can do is discharge your batt's for a few minutes and then charge them so that they peak closer to race time. If you don't like that idea you can always just re-peak a minute or two before the race at .03 or lower mv threshold. Your goal is to get them from the charger to the start of the race with as little time as possible in between.
fatdoggy is offline   Reply With Quote
Old 01-13-2004, 12:29 AM   #498
Chill Will's Avatar
I can tell the difference when I run a pack fresh off the charger than one that has been sitting a long time then re-peaked. Might just be a mind thing.
AE - It's ok to re-peak. I would do it about 5 mins before your race.
Chill Will is offline   Reply With Quote
Old 01-13-2004, 06:12 AM   #499
John Fontaine's Avatar
Send a message via AIM to John Fontaine
If the cells have been sitting for 30 min or longer, repeak at the same amperage and same peak delta Voltage. If it is less than 10-15 min repeak at same amperage and .01-.03 delta V. It is best to have the cells peak no more than 5 minutes before the start of the race.
Hope this helps.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 01-13-2004, 02:27 PM   #500
If I want to cycle my batteries, just to see what voltage and mah they really have should I have any delay between the peak and discharging? Does cycling have any negative effects on the cells? If so I wont do it.
AE Racer is offline   Reply With Quote
Old 01-13-2004, 02:32 PM   #501
Cycling does stress the cells and reduces runtime so if you don't really have to do it I would advise against it. (only if your cells are really sucking at like 2400 mAH) If you do cycle, put atleast 10 minutes or maybe 15 to let them cool down a little before discharging. If you don't and you discharge at 30 amps you be seeing your cells hit 180F and that's way to hot and you'll damage them.
Old 01-13-2004, 02:57 PM   #502
jaysimpson's Avatar
Send a message via AIM to jaysimpson
We need to get you another avatar John! LOL
Thanks for fill'n in for us!
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 01-13-2004, 06:59 PM   #503
Ok, I wont do that, but wouldnt running them right after they peak have the same effect?
Old 01-13-2004, 09:50 PM   #504
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Not really because your packs will never have the load they do when being discharged at a constant 30amps.
In Mod you might get close but then again you do have wind going over the cells to cool them a bit and so forth.
mike_Webb is offline   Reply With Quote
Old 01-14-2004, 04:39 AM   #505
jaysimpson's Avatar
Trust us on this AE Racer, we won't steer you wrong.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 01-14-2004, 07:09 AM   #506
LOL - just trying to help a racer out that has questions
Old 01-14-2004, 11:09 AM   #507
BigDogRacing's Avatar
Send a message via MSN to BigDogRacing
BigDogRacing is offline   Reply With Quote
Old 01-14-2004, 11:56 AM   #508
mike_Webb's Avatar
Originally posted by BigDogRacing
Why the faces
How are your guys Mini T packs? I got a couple of Venom Packs but they are crapping out. Are ProMatches packs just like the other 1200MAH pack out there or are they a different cell structure?
Mike
Old 01-14-2004, 01:50 PM   #509
jaysimpson's Avatar
They are using the KAN cells right now and they are awesome! Better voltage than before. The GP 2/3 A cell will be available also sometime in Feb. Get some,they are niiiicccee.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 01-14-2004, 02:15 PM   #510
PMRGirl's Avatar
Talking
We also have the 1.165-1.169 voltage packs back in stock!!!!!
PMRGirl is offline   Reply With Quote
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
