Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 01-09-2008, 12:42 AM   #4711
BSchorr's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to BSchorr Send a message via Yahoo to BSchorr Send a message via Skype™ to BSchorr
Cycling my friends packs for him, but one cell wasnt happy.
Proline ~ Genesis R/C Products ~ First Premier Satellites
BSchorr is offline   Reply With Quote
Old 01-09-2008, 12:44 AM   #4712
Trader Rating: 49 (95%+)
Send a message via Yahoo to loopedout
Thats what mine looked like, just called up Erika and about 5 minutes later she had a cell on the way to me.
loopedout is offline   Reply With Quote
Old 01-09-2008, 12:48 AM   #4713
BSchorr's Avatar
Ya, I dunno, that pack isnt the WC kind, its just the regular IB4200
Old 01-09-2008, 12:52 AM   #4714
Junkman's Avatar
Those look like the blue IB cells?
I have started a new regiment for charging cells, that includes five levels of safety.
1. Depending on the pack (which means my level of confidence of how matched they still are), set to either zero peak detect or 3mv/cell (Ice charger)
2. Set the temperature probe between cells that get the hottest. I use an IR temp sensor (also for checking nitro engine temps )
3. Reduced Charge rate from 6 to 5 amps.
4. Set the cutoff temp to 102 deg f. -- I do this because when the Ice reads 102, my temp gun reads about 115 and rising quickly. The cells peak out at around 120-130 f.
5. Keep an eye on the cell temps using the temp gun, when they get around 95 deg, they start to rise in temp FAST. If the cells are out of match by very much, the peak detection might not work, don't feel bad about stopping the charge.
I then re-peak at 6 amps about 5 minutes before my race just to get some heat back into them.
http://www.wheretoracerc.com
online race sign up system for the masses.
Get your race listed with the Original Online Sign Up System for RC Racers!
Northwest Championship Tour website--> www.nothwestchampionshiptour.com
Rock Crawler events! --> Signup on wheretoracerc.com
Junkman is offline   Reply With Quote
Old 01-09-2008, 12:54 AM   #4715
Excellent ideas!
Old 01-09-2008, 05:49 PM   #4716
P2
P2's Avatar
Trader Rating: 15 (100%+)
Looks like the cell was shorted out by the water
Seriously, I hope no one got hurt.
TopRacingUSA | Team EPIC | Thunder Power | OD Racing
P2 is offline   Reply With Quote
Old 01-09-2008, 05:55 PM   #4717
Junkman's Avatar
They also look fairly old since they do not have the Pro-Match "Match on date"
Old 01-10-2008, 02:44 AM   #4718
RocketRacer's Avatar
i will be picking up my promatch EnerG 4600 6cell packs today. what are the charging and discharging recommendations for these packs?
RocketRacer
XRay T2'008/Nosram ISTC/Nosram 13.5T Spec
Futaba 3PKS with FASST
>>>Knowledge is Power<<<
RocketRacer is offline   Reply With Quote
Old 01-10-2008, 08:43 AM   #4719
Trader Rating: 17 (100%+)
Send a message via AIM to TMR CHASSIS
RocketRacer,
These cells are great! charge like you normally do. Equalize them to .90 on a tray then charge any where from 5-7 amps and dicharge 30-35 amps! After using them I equalize them and put back 1000+ sec back into the pack should be good for two weeks sitting.
Raymond McCoy
Team ProMatch Racing
TMR CHASSIS is offline   Reply With Quote
Old 01-12-2008, 03:48 PM   #4720
P2
P2's Avatar
Erika,
I need to order 2, 6 cell packs. ENER-G 4600 PLATINUM LEVEL, preassembled, reverse side by side. Hopefully you have them in stock....and I really need them by next weekend Let me know what's available.
Thanks,
Paul
Old 01-13-2008, 01:55 PM   #4721
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Quick poll. Who all from the ProMatch team is going to be at the Birds'? And what classes? Im looking forward to representing ProMatch Batteries at the Snowbirds. Its going to be alot of fun. Hope to see you all there.
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 01-13-2008, 06:13 PM   #4722
theisgroup's Avatar
Originally Posted by Kropy View Post
Who's all going to the SnowBirds? I'll be there racing
1/10 Stock Foam
1/12 Stock GTP
Originally Posted by theisgroup View Post
me too
Originally Posted by TL_XXX-S_racer View Post
Ill be there.
Originally Posted by ASM View Post
I'll probably get over that way to check it out once or twice, hopefully I'll be able to meet a couple of you guys.
Chris, are you running the birds? Also, are you going to Superior this week-end?
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 01-13-2008, 06:42 PM   #4723
redlion's Avatar
I plan on being there. I will be running 1/12 stock and 1/10 stock foam.
Wes Lion
redlion is offline   Reply With Quote
Old 01-14-2008, 12:37 AM   #4724
Trader Rating: 48 (100%+)
Hi Promatch
Is it okay to compare the number from Energ cell vs. Ib cells since they were matched by you guys? Will you have the IB 4200 6 cells on sale back in stock? I need some high number packs for TCS and HPI challenge. Thanks.
Yellowtaro is offline   Reply With Quote
Old 01-15-2008, 12:37 PM   #4725
theisgroup's Avatar
Originally Posted by Yellowtaro View Post
Hi Promatch
you can compare the numbers, but that is all they are worth. really different cell with different manufacture tollerences will yield different "feel" on the track. even cells made by the same manufacture in different batch codes will "feel" different and perform different.
I have not heard that promatch is going to match any ib cells at this point. you can never say nevers, but I don't thinks so at this point.
yang lai
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
