Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-10-2006, 12:53 PM   #4291
rctoyguy's Avatar
Trader Rating: 21 (100%+)
rctoyguy- they keep going.....and going.....and going
Jeff
rctoyguy is offline   Reply With Quote
Old 08-10-2006, 04:42 PM   #4292
Trader Rating: 48 (100%+)
Originally Posted by PMRGirl
Yellowtaro- The 4200's are still a little larger and heavier than the 36's or 38's
Apl Hed-You are very welcome and Thank-You for the kind words and continued support!
Promatchrcr- hmmm.....YO!!!!
ICEMAN- You are welcome!! These latest batts are AWESOME!!!
Nutfluff- It was nice talking w/you, thank you for calling. I don't always get in here as often as I would like.
PMRgirl
So do I need to sand the battery slot on my Xray T2, HPI Pro 4, and Yokomo CGM? I know that the T2 is newer but can the 4200's fit it okay? It give me an idea how I can use the batteries if I purchase them. Thanks.
Yellowtaro is offline   Reply With Quote
Old 08-10-2006, 04:45 PM   #4293
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
ProMatch goes to matching their packs at 35 amps!!! If anyone hasnt seen their website yet.
Cant wait to see how much better these are going to be than the other 3800's.
Congrats!!
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 08-12-2006, 02:36 PM   #4294
ASM
ASM's Avatar
Erika, I left ya a message Friday, give me a call. I've got the need for more speed
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 08-14-2006, 10:32 AM   #4295
t4mania's Avatar
Default Cycling Receiver Packs
I
SC10 4X4 Short Course
SC10 FT 2WD Short Course; FT B4.1 +8mm Buggy
FT T4 Dirt Oval
Silva Concepts R50 Oval
Custom Works Dominator; FT TC3 Trans Am
t4mania is offline   Reply With Quote
Old 08-22-2006, 05:00 PM   #4296
rtypec's Avatar
Hi Erika and gang. The matched mini/micro packs are awesome. The difference between these and stock unmatched packs that came with the kit are night and day with dare I say "too much power"
I ended up 3rd in the unlimited class (and it wasn't because of a lack of horsepower) and I won the past champions class...so overall not too bad
As promised here are a couple of pics of the Frog. Erika, I'll burn a CD of the pics I took this weekend and give them to you in Vegas.
Take care!
Pro-match Batteries-frog.jpg   Pro-match Batteries-frog1.jpg   Pro-match Batteries-frog2.jpg   Pro-match Batteries-frog3.jpg   Pro-match Batteries-frog4.jpg
rtypec is offline   Reply With Quote
Old 08-22-2006, 06:09 PM   #4297
Nova F1 Racer's Avatar
R/C Tech Charter Subscriber
Erika, you gots email, both here and office...
This is DICK!!! And you're NOT!
RC Tech member #11
Aussie Rules Footy, Brisbane LIONS!!
[url]http://www.pitter-pat.com/[/url] for pet care needs in Northern Virginia
Nova F1 Racer is offline   Reply With Quote
Old 08-22-2006, 07:13 PM   #4298
maxepower's Avatar
Default HOPPED-UP FROG? I think I made a joke?
Take care!
Hey Rod,
Are those shocks modified TRF shocks with long shafts? Where did you get the springs and those rear tires? Already thinking about hop-ups for Timmy's Frog!
Max
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 08-22-2006, 08:12 PM   #4299
rtypec's Avatar
Originally Posted by maxepower
Hey Rod,
Max
Max, here's what I pm'ed Izzy with
What I did was the following:
Shocks
I used old TRF shock shafts (the ones that are a bit longer). I then took a two hole piston and drilled the holes out to 1mm. I then drilled two 0.5mm pilot holes perpendicular to the two existing holes. I drilled those out with a 1mm drill bit. I used the new 1mm down spring retainers. I also reamed out a bunch of those plastic shock rings you find on the Vparts tree to fit on top and bottom of the spring (prevents spring from popping off). I used Losi Mini LST springs (white). 400 weight front and 500 weight rear for oil.
Shock Mounts
I threaded 3x12mm droop screws into the existing holes. Added a 3mm spacer so that shocks can clear body and suspension. Top them with aluminum ball stud.
Front Axle
I cut the drive axle ears off to prevent anything getting caught in there.
Front Chassis
I dremeled a section of the chassis where the front suspension hits in order to get a little bit more up travel.
Tires
Fronts had stock sidewalls with a center section of Proline Bowties. No insert.
Rears were Losi IFMAR Pins cut and sectioned to fit Tamiya Wheel. Insert was foam from the Dark Impact (? DJ made the tires so I'm not sure). The rear tires Jimmy used were Crime Fighters for the Mini Inferno with two rows cut out and Trinity Soft (white) Inserts for the RC18. Cut Square Fuzzies were for doing hyper-donughts and were no good when the track dried out.
Camber
Rear 4 degrees
Front 1.5 degrees
Toe
Front about 1 dgree toe out
Rear is stock
I think that pretty much covers it. Let me know if there is anything else I can help you out with.
I hope this works.
And now we return to our regularly scheduled programming
Old 08-27-2006, 05:46 PM   #4300
Ive seen the Tekin Battery Doctor8.0 in promatchs website. Is it the recommended tray for your batts? thanks
skamolly is offline   Reply With Quote
Old 08-27-2006, 08:33 PM   #4301
theisgroup's Avatar
the tekin tray is a great tray. just don't leave your batts on the tray pass when the lights go out. there are some usage recommendations on the promatch site.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 08-29-2006, 03:56 PM   #4302
Hey, Promatch!!
I just went onto the website and you are "out of stock" on the IB4200 1.23 volt packs.
Are you in the process of matching more and if so, will they be ready in time for Vegas?
Thanks for the great packs and service!!
Crashby is offline   Reply With Quote
Old 08-31-2006, 09:43 AM   #4303
Hebiki's Avatar
Trader Rating: 26 (100%+)
Hey guys... how's everyone doing. Good luck to all the ProMatch drivers who'll be attending the IIC.
Does Erika still sign on? I need to ask her something.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 09-06-2006, 09:40 AM   #4304
Hebiki's Avatar
bueller?
hope everyone had a fun labor day weekend. who's racing this weekend? Rod, will you be running the new MRE?
Hebiki Design Works
Old 09-06-2006, 10:35 AM   #4305
rtypec's Avatar
Yes, I also ran it last weekend. I want to get into the twelves with it but we'll see how it goes. This should be a fun weekend so long as it isn't too hot.
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
