Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-26-2006, 12:24 AM   #4216
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by Tsquare
My initial experience is the same as TRF415boy, I haven't seen a great difference between my GP's and IB's, in fact if anything, they feel like they have less punch. In addition with my GP's I don't have to make sure they never get discharged below.90. With my GP's I would discharge, Novak Zero tray them, till my next race - done. I hope as my experience increases with the IB's that my performance increases also. If someone has any suggestions on how to get better performance form my IB's I would appreciate it.
Right now I do the following:
Leave charge in battery, when ready to use, Discharge on Much More CTX-D 30A Impulse to .90, tray on novak smart tray to .90, Charge on Orion Advantage at 6V, Run car, and leave in remainder till next use. Then I will repeat cycle. I run stock and 19T on-road. Any suggestions appreciated.
TSquare.... i do exactly what you do.. but with one addition. after CTX-D to 0.9v... i throw them on the tekin tray... when the lights go out...it goes down to 0.7V...and after a while.... once all the lights are out.. it brings the entire pack down to 0.5V and holds it there.
i highly recommend the tekin trays. as recommended by promatch, they work great,... i can squeeze a little bit more performance out of the IBs...and they wont get damaged. if you have any more questions.. post here, or call up erika or jeff. you wont be disappointed.
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 04-26-2006, 12:39 AM   #4217
jarkkom's Avatar
Send a message via MSN to jarkkom
My initial experience is the same as TRF415boy, I haven't seen a great difference between my GP's and IB's, in fact if anything, they feel like they have less punch. If someone has any suggestions on how to get better performance form my IB's I would appreciate it.
Your motors are geared wrong.. Just try a 1-3 tooth smaller pinion with the IB's. I had the exact same feeling when I first got to try IB cells over the older GP's... Never looked back after I figured them out.
www.eurorc.com/?ad=jm
jarkkom is offline   Reply With Quote
Old 04-26-2006, 06:55 PM   #4218
Tsquare's Avatar
Thanks for the reply, I appreciate your comments. I will put them into play this weekend. The only chnage i am going to make to my battery routine is to tray them on my Novak to .05, similar to what you do on your Tekin Tray. After reading so many warnings about how IB's do not lik eot go below .90, i have been very careful. Will post in future on how my experience goes. Thanks again.
Tsquare is offline   Reply With Quote
Old 04-26-2006, 06:59 PM   #4219
Tsquare's Avatar
Thank you for your comments to my questions. I am in the habit of always trying to gear up for speed. By going down a 1-3 teeth on your pinion, do you lose topend? And if you do - is it noticeable?
Will give a try this weekend, Thanks again.
Old 04-28-2006, 10:04 PM   #4220
promatchracer's Avatar
Send a message via Yahoo to promatchracer
Hey guys and gals been awhile since I posted on here some of you where probably happy about it
I am in need of some help I was wondering if anybody has any 4200's that might want to get rid of
I am looking for 4 0r 6 cell packs with a ton of run time
I had a lot going on this week and forget to order some in and I have a Trophy race and need them by Friday if possible
The reason why I would like them is we are having an Unlimited pan car class and ppl ot making special bodies and modding their normal cars to go ballistic
Most are going to run Novaks 4.5 systems and some are running brushed 5 and 6 turns with 6 cells
I am looking to get a couple packs to have on hand so I can show them what Promatch power can do when there batteries don't cut it That way all I have to do is toss them the stick and say put that in
if no one has any on here for a good price I wil go ahead and call Erica on Monday and see what she has in stock
Jay call me also
Thanks guys
promatchracer is offline   Reply With Quote
Old 04-29-2006, 06:28 AM   #4221
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
shoot me a PM with your number again....
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 04-29-2006, 08:00 PM   #4222
TL_XXX-S_racer's Avatar
Send a message via AIM to TL_XXX-S_racer
Quick question for you guys,
What amperage should I charge my IB3800's for my 4.5 Brushless system, in a touring car. To run 5min. Should i charge at 6amps, or less.
Thanks,
Chris
ProMatchRacing
"Nobody does it better"
Team Corally
Superior Hobbies
"Supplying all your r/c racing needs"
TL_XXX-S_racer is offline   Reply With Quote
Old 05-01-2006, 06:57 PM   #4223
ASM
ASM's Avatar
Trader Rating: 21 (100%+)
Erika, thanks for the latest batch of cells! I tq'd and finish 2nd in the Florida State Series race at Superior Hobbies. Not too bad out of a 45 car field. Thanks again
Scott Meeks
2016 & 2017 ROAR Region 4 VTA Champion
USVTA Member #116
ASM is offline   Reply With Quote
Old 05-01-2006, 09:06 PM   #4224
rctoyguy's Avatar
promatchracer - what's up?! - Did I see you in a Spektrum ad in RCCA? Sure looked like you, Bama cap and all!
I went to my first TCS event this past weekend - what a blast! PM cells put down the best lap times of the day in spec, where it really is all battery, since the motors/chassis/tires are the same. Missed TQ by 1 sec, and due to "issues" in the main ended up 3rd, but that was driver trouble, not horsepower... If I stayed out of trouble the car was the fastest of the class - thanks to Pro-Match power.
Jeff
rctoyguy is offline   Reply With Quote
Old 05-02-2006, 06:53 PM   #4225
jaysimpson's Avatar
Thanks,
Chris
I would say 5-6 amps would be fine. They have runtime out the wazoo anyway.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 05-06-2006, 11:37 AM   #4226
theisgroup's Avatar
hey guys, check out th enew promatch site.
yang lai
Team Tamale | Team Tekin | RCAmerica | Speedmerchant | Speedzone RC | EA Motorsports | Ko Propo USA | eXpress Motorsports | Parma/PSE
theisgroup is offline   Reply With Quote
Old 05-07-2006, 05:34 AM   #4227
jaysimpson's Avatar
Yeah,it looks great! Easy to navigate and the battery assembly options are alot easier now.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 05-15-2006, 09:46 AM   #4228
dizzy1's Avatar
Trader Rating: 24 (100%+)
Do you know if you'll have any IB3800's in the 1.22+ range in stock any time soon? Need to get some packs before heading over to Reedy in a few weeks.
No more hot pockets, Russian rocket time again.
Hobbywing- Schuurspeed
dizzy1 is offline   Reply With Quote
Old 05-16-2006, 03:11 AM   #4229
jaysimpson's Avatar
If none are listed I would advise calling Erika and checking to what is possibly coming out of the matchers.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 05-16-2006, 05:37 AM   #4230
any dealer at daly city CA? thanks
skamolly is offline   Reply With Quote
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
