Pro-match Batteries
#4082
Not sure yet, when I hear something I will post it here first.
#4083
IP 3800 are available at promatch. go to the site. they are this month's specials
#4084
http://www.promatchracing.com/main.htm scroll down a little and they are there.
#4085
the IP cells have higher voltage, and a lower IR. But they seam to be a little soft on the first charge. I also noticed that using the same charge profile as my IB3800, the IP came off alot cooler. they were about 95 where my IBs come off around 120. Will work on them some more next weekend.
#4086
wonder if you can bump that up to 6.5amps or even 7amps? if its coming off so cool.
#4087
7a to 2700mah
.2 to 2750mah
6 to 5000mah
this is the profile I was using for ib3800 and they were always great on the track. they do come off cooler with the step charge. but I knew that the IBs needed to be above 110. needs more playing, but it was a short race program last night. most wanted to get home bfore the "Big Game"
.2 to 2750mah
6 to 5000mah
#4088
7a to 2700mah
.2 to 2750mah
6 to 5000mah
.2 to 2750mah
6 to 5000mah
#4089
as long as it goes faster.
lol
lol
#4090
Stick to side by side
How hard is it to convert a pro-match stick pack to a side by side configuration?
What's the best way to get the cells apart?
Thanks.
Thanks.
#4091
Thats a tough one, I have never done it; I would be careful to not damage the cells pulling them apart. I would call Erika and ask her if they would do it for you.
#4093
Thanks.
Thanks.
1. i took an xacto knife and cut off the plastic tubing.
2. removed the end caps.
3. unsoldered the deans connectors
4. gently stretched out the stick pack..until i can see the thin strips of metal (correct name?) then i cut them in half.
5. i took a set of pliers and pulled off the pieces from the ends of each battery making sure not to damage the ends.
6. i used a dremel to sand the end of each cell.
7. soldered them into a side by side pack using a dean's battery jig.
sending it to promatch would be easier tho.
#4094
i would have to agree with promatchrcr.
and looking at the discharge curve of the 4200, they do not have more voltage in the first 5-8min. they have the same voltage for longer.a good matched set of 3800 give you over 1.20 for 470-500 seconds. that is well past the 5min mark. 8 min is only 480 secs. I have 3800 with over 500sec of 1.20+. also their IR is not any lower.
the cells to watch are the IP cells, no more voltage, but the IR on the newer series is way low. that means more punch.
How does the IP cells compare with IB? phyisically are the IP's smaller or bigger? heavier? with regards to performace?
#4095
Originally Posted by promatchrcr
I have not tried the 4200's yet but with the 3800's having such high voltage I have not experianced any motor fade. I actually use less trigger since I get more out of less...(if you know what I mean)
i know exactly what you mean... ... Thanks... we'll be getting our first batch of 4200's...
