Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-05-2005, 09:59 PM   #3811
jamescam's Avatar
R/C Tech Charter Subscriber
My wife is kicking me out to the garage which gets kind of hot during the day. How hot is too hot of a work area to keep my batteries stored? It can get to the upper 90's in a garage in Texas if not warmer. I was considering buying a used wine cooler to house my batteries but not sure how much moisture it would generate and if that would be a concern.
jamescam is offline   Reply With Quote
Old 10-06-2005, 08:00 PM   #3812
i just got my 3 gp3700 packs today and the battery bars barely look soldered . how come . on several of them you can't even see a solder joint . i work around pcb boards all day as a fuji surface mount operator and i know that a good solder joint is important for maximum current flow and reliability
rcfreak24 is offline   Reply With Quote
Old 10-06-2005, 08:06 PM   #3813
rctoyguy's Avatar
Trader Rating: 21 (100%+)
They are soldered...
You are correct, a good solder joint is critical. I am sure you also know that a good solder joint doesn't require a ton of solder -
IF (biggest if ever in the history of the world) you have problems, don't worry, that is the glory or Pro-Match. They WILL make it right.
Jeff
rctoyguy is offline   Reply With Quote
Old 10-06-2005, 08:15 PM   #3814
yes i am aware that you don't need alot of solder but on some of the bars you just can't see any signs of solder at all . this is the first time running 3700's what should my chargers be set at i have an lrp comp 2 and a duratrax ice . thanks
Old 10-06-2005, 10:38 PM   #3815
Hebiki's Avatar
Trader Rating: 26 (100%+)
or you can solder like i used to when i was first learning.
now i leave all that up to the pros at ProMatch
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 10-07-2005, 12:00 AM   #3816
maxepower's Avatar
Talking Nice soldering job!
Don't believe him. I saw Chris solder those batteries yesterday!
Tamiya Track Local. 10,000 Watts of power! ($5 donations for gas appreciated)
Proud Father of GT-1 Past Champion!"Hey, I got to go to Japan too!
FF03,TA-05V2 ,EVO-6,TA-07,TRF419W,EXOTEK-6
"Tamiya Racer to Infinity and Beyond!"
maxepower is offline   Reply With Quote
Old 10-09-2005, 09:11 AM   #3817
batts were good .powered my mf2 to TQ and the Amain win at ashtabula speedway yesterday
Old 10-10-2005, 03:48 AM   #3818
highwayman's Avatar
i'm not sure what thread i read it in, but i vaguely remember reading that in order to achieve a linear performance from the IB's you have to gear down, since it produces too much voltage that the motor heats up, thereby feeling "soft" in the latter minutes.
has anyone else noticed this? thanks -jason
highwayman is offline   Reply With Quote
Old 10-10-2005, 07:47 PM   #3819
PaintingRoly's Avatar
Trader Rating: 56 (100%+)
Thanks PROMATCH
for getting me the run time and voltage I need not only to make the main but finish 4th in 1/12 scale at this past weekend's ROAR Nats.
In 1/12 where batteries are more important than any other class I never even came close to "dumping"
Roly
follow me @RC3grafix on Instagram for pictures of my paint work.
PaintingRoly is offline   Reply With Quote
Old 10-10-2005, 09:58 PM   #3820
I just received my promatch receiver pack for my 1:12. On the instruction, it says i should not charge it higher than 0.1A but according to my calculation, it'll take approx 1.5 hour to charge up the 160mah pack at 0.1A and since we only have a 50-60mins gap between each race... and minus 10 mins or so for scrutineering and stuff. so not only i'll need an extra charger so i can charge my car battery and receiver pack at the same time but even so i still won't have time to charge it up completely. so it seems i HAVE to charge it at higher amp? so my questions are:
1. How many races can a fully charged receiver pack last? 1 race? 2 race? or more?
2. Has anyone tried charging it at a higher amp? like 0.5A?
yellow15 is offline   Reply With Quote
Old 10-11-2005, 12:23 PM   #3821
PMRGirl's Avatar
1.) Your pack will last approx about 30 min depending on the current draw of the cervos/receiver being used. It can vary but typically you should get about 30+ min.
2.) is too high to charge them at. That will cause rapid deterioration of the cells and may even destroy the pack!!!!!!
PMRGirl is offline   Reply With Quote
Old 10-11-2005, 07:26 PM   #3822
PMR Girl did you receive the email regarding The East Coast Truck Classic? I'll give you a ring tomorrow
lineburner is offline   Reply With Quote
Old 10-13-2005, 01:21 AM   #3823
highwayman's Avatar
PMRGirl :
hi, did you receive my email? thanks - jason
Old 10-13-2005, 07:23 AM   #3824
PMRGirl's Avatar
lineburner- yes, I did. I will get back to you today
Jason, sorry Yes, I received it. I will make sure I get you answered today also. Sorry about that. We have been swamped with orders and e-mails and I am just making my way through them one by one. I will be sure to get to yours today.
Old 10-18-2005, 04:42 AM   #3825
jaysimpson's Avatar
Send a message via AIM to jaysimpson
Come on folks....what is this doing way back on page 3?
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
