Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 06-02-2005, 03:16 PM   #3376
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally Posted by johnnyshore
I have tried using .2V cutoff on the smart tray, and it ups the initial charge to about 2800mah. I know the newer 3300's aren't as durable and lasting as some of the packs from back in the day, but I wasn't expecting to lose 500-600 mah over a 10 month period.
Like I said, the packs are still very strong so there's no complaints in that category.
Thanks.
dont forget to take into consideration.... you are using the packs 3 times a week for the last 10 months? 4 weeks in a month.. so 12 times a month. so you've used the packs 120 times? a drop off is inevitable, but id say thats pretty darn good.
do you have a 3 step charger?
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 06-02-2005, 03:57 PM   #3377
johnnyshore's Avatar
Trader Rating: 72 (100%+)
I use a Quasar Pro, so no, I don't have a 3 step charger. It's funny that we still have some old 1400 SCR packs from the early 90's that still take 1500+ mah on a charge...ahh, the olden days! :-D
Oh well, I guess it's just age catching up with my packs. I've been very satisfied with their performance, and I'll be getting more PMR packs when the time calls.
John Schroer
Check out Shamrock R/C Raceway
Minnesota's only outdoor astroturf off-road track!
https://www.facebook.com/ShamrockRC/
johnnyshore is offline   Reply With Quote
Old 06-02-2005, 04:16 PM   #3378
Hebiki's Avatar
theres a bunch of things you can do to extend the life of your packs.. but it'll involve an investment (trays, 3step charger... etc) PM me or IM me on AIM.. i can help you out further on there.
Hebiki Design Works
Old 06-02-2005, 07:07 PM   #3379
crACkeD ChaSsiS's Avatar
Send a message via AIM to crACkeD ChaSsiS Send a message via Yahoo to crACkeD ChaSsiS
Originally Posted by crACkeD ChaSsiS
i run a tc3, will the 3700s have a hardtime fitting, or will they fit just like a 3300, or? bcuZ i want to try the 3700s also!! Thanks alot
Steven Alexander
I ordered some 3700s today but, can anyone help me with the question above?
crACkeD ChaSsiS is offline   Reply With Quote
Old 06-02-2005, 08:06 PM   #3380
PMRGirl's Avatar
There's got to be someone here that knows if the 3700's will fit in a tc3
unfortunately I am not one of them but I am trying to get someone to come forward and help........
PMRGirl is offline   Reply With Quote
Old 06-03-2005, 06:13 AM   #3381
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
I would imagine you will have to grind the chassis to make them fit. I would recommend you getting a BMI chassis...not only will the car drive better but Jason makes it to handle 3700's and 3300's with no problem.
PS You will probably grind a good bit of chassis away if you stick with the stock chassis. If you don't mind grinding then go for it.
And yes I am still watching the PM thread via the hosital.LOL They started her labor but they have given her oain med. so believe it or not she is sleeping,LOL....so here I am surfing....I doubt this will last too much longer.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 06-03-2005, 07:24 AM   #3382
ttso's Avatar
Hebiki, would you post a sample of 3step charging setting for GP3300? I got some old GP3300 and own a ICE (4steps caps) with Novak tray. Like to know how to extend their life...
Thanks lots.
ttso is offline   Reply With Quote
Old 06-03-2005, 07:31 AM   #3383
highwayman's Avatar
Originally Posted by PMRGirl
INTELLECT 3800'S ARE READY TO GO!!! RUNTIME STARTS AT 470 AND VOLTAGES ARE 1.175 UP THROUGH THE 1.18'S
great !!! just wondering, were the IB's matched the same as the GP's? 5amp charging, 30amp discharge?
highwayman is offline   Reply With Quote
Old 06-03-2005, 07:36 AM   #3384
Hebiki's Avatar
Thanks lots.
[disclaimer]by using this 3step profile, i am in no way responsible for anything that may happen to your battery pack. by reading my disclaimer you cant sue me if your packs blow up. [/disclaimer]
i use the record breaker charger... and i charge my promatch packs at:
stage1: 0-3500mah / 6amps
stage2: 3500-3520mah / 0.2amps
stage3: 3520-4900mah / 5amps
18-30mv for delta peak (depending on ambient temperature)
45deg C for temp cutoff
btw... ive actually reached the mah cutoff on my GP3700s. it charged up to 4900mah my oldest practice pack 3300s average around 4000-4200mah.
Nobody does it better
Hebiki Design Works
Old 06-03-2005, 07:37 AM   #3385
highwayman's Avatar
Does using a 3 step charging process really better for the batteries? if so... in what what are they better? does it extend the performance/life of the batts?
Old 06-03-2005, 07:37 AM   #3386
Hebiki's Avatar
early congrats. i hope she has a quick painfree delivery. another member to the PMR family.
Hebiki Design Works
Old 06-03-2005, 07:51 AM   #3387
Default But will they fit?
Will the 3700's fit in a TC4?
Same question for the 3800's.
JWATT is offline   Reply With Quote
Old 06-03-2005, 08:02 AM   #3388
highwayman's Avatar
Congratulations in advance !!!
Old 06-03-2005, 08:02 AM   #3389
Mr. Shookie's Avatar
Send a message via AIM to Mr. Shookie Send a message via MSN to Mr. Shookie
Hey Chris,
You said Depends on ambiant tempature. In what way should I adjust for ambiant temp? It is getting hot and I don't want to fry my batts. Lets say that the ambiant temp is 85* what delta peak shoudl I use?
or 95*
Or 105* yes it getting that hot here vey soon.
How would I adjust for those numbers.
Thanks in advance.
Stephen <><
Also could you PM me any helpful hints that you have for the Tamiya track would be very much appreciated.
I am racing KO and have never ran there let alone there in late June...
Like tire compounds and gear ratios to start with in 19T with those Yokomo handouts?
Any other hints would be appreicated.
Thanks....
All who love the LORD JESUS I praise with you.1 Cor 10:31
Team HOLY Rollers (Team Manager)
The Church is a Hospital for Sinners not a Museum for Saints.
RcTech Feedback <>< RC Tech Subcriber #92
Mr. Shookie is offline   Reply With Quote
Old 06-03-2005, 08:12 AM   #3390
Hebiki's Avatar
not sure if its "really" better... but MY PERSONAL opinion/experience. i get the same performance from my packs but more runtime and the packs arent coming off "hot". ive managed to extend the life of my practice packs (formerly race packs) since they dont come off as hot as they did with my older chargers.
Originally Posted by Mr. Shookie
Hey Chris,
or 95*
Thanks in advance.
Stephen <><
Thanks....
got AIM? hit me up on there, DunpealHunterC.
maybe erika, or rod can correct me on this. for delta peak. i adjust according to ambient temp.. so.. if its 100 degrees outside.. im sweating buckets. i put the delta peak to 18mv per pack. 3mv per cell. the battery should come off warm not hot.
now.. if its 60 degrees and im wearing a sweater. i crank up the delta peak to 30mv (5mv per cell) so that when the pack peaks.. its also warm.
Hebiki Design Works
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
