Pro-match Batteries
#3361
Ohhh my gosh.....I am so smart I figured it out all by myself......
Thanks Chris, you rock!!!
#3362
batts
i run a tc3, will the 3700s have a hardtime fitting, or will they fit just like a 3300, or? bcuZ i want to try the 3700s also!! Thanks alot
Steven Alexander
Steven Alexander
#3363
Stand ovation might be pushing it though...LOL
Any word on what we talked about? IB's
Stephen <><
#3365
MrShookie- I thank you......
THEY ARE UP FOR SALE ON THE WEB-SITE www.promatchracing.com
INTELLECT 3800'S ARE READY TO GO!!! RUNTIME STARTS AT 470 AND VOLTAGES ARE 1.175 UP THROUGH THE 1.18'S
#3366
I just saw you pricing for the 3800 and WOW, I just wish Scotty would allow them at the Vegas race.
How do they compare to the GP3700? Scotty is going to allow those.
I mainly run stock but will run 19T at vegas. How would a 3300 compare to a 3700 to a 3800.
Looking to try and determine do I need to go to a 3700. Will the 3300 be going by the wayside soon?
I am in the market for some new packs soon. 3-4 packs.
Thanks...
Thanks...
#3367
PMRGirl.... 5am!!!!
#3368
Hi all,
I have a question regarding my four PMR GP3300 packs...lately, they've been steadily loosing capacity when charging...when I first got the packs, they'd take around 3200-3400 mah when charging at 5.5 amps with a 4mv/cell cutoff.
I've had the packs for probably about 10 months now, and lately I can only get them to take about 2600-2700 on the initial charge at the same settings. I always tray them on a Novak Smart Tray at the .9V cutoff before charging, and they're used about 3 times per week. If I remember correctly, the numbers on the packs average around 420 secs/1.165V.
Just wondering what I can do to get the capacity back up. My local track has been running 6 minute heats with an occasional 8 minute main, but I have a hard enough time making 6 minutes with my 12x2 Orion powered B4 when I'm deep into the trigger, and if I REALLY finesse the car around the track I can just barely make 8 minutes (while other racers can run for several minutes after I've gone dead).
Any suggestions/comments on how to "revive" them would be appreciated. They run VERY strong for just average voltage packs, so I can't complain about their strength.
Thanks in advance.
John
Thanks in advance.
John
#3369
Thanks...
Thanks...
i can get a good 6 mins of runtime in 19T with my 3300s also. its really up to the place where you race if they'll allow 3700s. either way.. you cant go wrong when you invest in some new promatch packs
#3370
Johnnyshore: 1st off, change the voltage cut off on the Novak to .1 or .2. Then get one of the "old" Promatch trays. Leave the pack in the tray for 24 hours. Use this method everytime, new packs or old packs. It will help your old packs a great deal but it will not make them like new.
john
john
#3371
I have tried using .2V cutoff on the smart tray, and it ups the initial charge to about 2800mah. I know the newer 3300's aren't as durable and lasting as some of the packs from back in the day, but I wasn't expecting to lose 500-600 mah over a 10 month period.
Like I said, the packs are still very strong so there's no complaints in that category.
Thanks.
Thanks.
#3372
I've had the same exact experience with GP3300's. I had a bunch of 6 cell packs for about 8 months and the most MAH that would go into the cell was around 2800 as well. I tried zeroing the cells on my Integy Tray but it only boosted the mah about 200. The packs still ran strong just like you said but after time, I guess these cells loose some capacity.
I've been running Promatch Batteries for around 2 years now, and I really love them; excellent packs.
-Paul
-Paul
#3373
Bulb discharger
Just a quick question, when discharging my PM GP3300's with a 20 amp bulb discharger, with a 5.4v cut off switch, I have had two cells vent on two different packs. When I discharge on my Turbo 35 GFX at 20 amps I don't have any problem. Needless to say I'm not using the Bulbs anymore, just wondering why? Thank you in advance.
#3374
Using the "old" Promatch tray for 24 hours may get you another 200 mah or more. NEVER store your batteries with any charge in them! REPEAT, Never store your batteries with any charge in them. If you have the money to buy enough trays, store your batteries in the Promatch trays for days or weeks or months. Remove them an hour before charging. You will be impressed with the performance.
john
john
#3375
Polesitter: I have seen cutoffs that go well below 5.40 volts. As soon as a cell goes into cell reversal, it will vent. Cell reversal cause a major loss in performance. So your vented packs are now junk for serious racing. When dumping packs, use a higher cut off, then tray the remainder.
john
john
