Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-10-2004, 12:07 PM   #1906
jaysimpson's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to jaysimpson
Actually the voltage loss on a Pro Match stick is VERY small. As Neil stated the way they do it is different and much better.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
jaysimpson is offline   Reply With Quote
Old 08-10-2004, 12:39 PM   #1907
jsp
I have personally watched them assemble stick packs and unless they have changed things in the last 30 days, what I said before is true.
john
jsp is offline   Reply With Quote
Old 08-11-2004, 01:05 AM   #1908
Neil Rabara's Avatar
They let you watch them assemble packs?
Neil Rabara is offline   Reply With Quote
Old 08-11-2004, 04:46 AM   #1909
jaysimpson's Avatar
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 08-11-2004, 05:08 AM   #1910
Cole Trickle's Avatar
Originally posted by jsp
Stick packs have very thin tabs between the cells and are spot welded. Side by side packs have thick low resistance bars and hopefully are well soldered. I have tested a stick pack at 20 amps for average voltage. Then disassembled the pack and put it back together using Deans bars. When I retested the pack, the voltage gained .2 volts. As the amps go up this voltage loss increases. But remember, stick packs usually go in play cars and the voltage losses are not seen.
john
Well spoken and nice work.
Mounted in a car for stock racing, 0,2 volts is quite a lot. 20 amps is close to the average amp draw of an stock motor, so the example is realistic. And 0,2 volts equal 0,03 volt pr. cell (6-cells pack). The voltage difference between a Promatch pack 1,150-1,159 and 1.175-1.179 is close to that total pack 0,2 volt difference. But the price doubles...
But again, in a play car, it wont matter...
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 08-11-2004, 05:27 AM   #1911
rccardr's Avatar
Cole-
True, but not everyone who uses a stick pack puts it in a play car. Tamiya's F201 and Mini class cars both have to use stick packs. Those of us who race these cars seriously have had to come up with ways to manage our cells and circumvent the voltage loss- which as you point out can be quite sizeable.
It would be nice if someone like ProMatch could do this...
Later
Doc
I've never lost.
I've just been a little bit behind when time ran out...
RED DOT MOTORS- Fastest Titan 12T and silver can 540 motors in the known galaxy!
rccardr is offline   Reply With Quote
Old 08-11-2004, 08:28 AM   #1912
jsp
Neil: Yes they let me watch. I have also watched them assemble packs in the side by side configuration using the inductive soldering. That system is water cooled and makes no contact with the cells or battery bars. The solder and flux is applied with a syringe. The operator hits the foot pedal, a little smoke (from the flux) rises and it's done. The finished solder job is so clean, it looks like it was super glued together. BTW, I talked to Steve at Promatch yesterday and stick packs are still assembled with the thin tabs and spot welding. This is industry standard. The tab has to be very flexible because it will be folded in half. Spot welding is used because there are similar materials and soldering is not required. I believe the tab itself is where the resistance difference is.
john
Old 08-11-2004, 11:58 AM   #1913
Chill Will's Avatar
Chill Will is offline   Reply With Quote
Old 08-11-2004, 05:11 PM   #1914
john
Promatch should video tape it and show us all. PMRGirl, what do you think?
Old 08-11-2004, 05:14 PM   #1915
jaysimpson's Avatar
That's a good idea. Maybe a small video on the website showing the assembly process.
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 08-12-2004, 06:26 AM   #1916
Chill Will's Avatar
Yeah! OOOOOkayyyyyy!
Old 08-12-2004, 09:02 AM   #1917
jaysimpson's Avatar
Chilly: You coming this weekend? The weather should be nice!
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 08-12-2004, 11:31 AM   #1918
Chill Will's Avatar
I'm not sure. I need to stay in town this weekend.
Old 08-12-2004, 11:51 AM   #1919
jaysimpson's Avatar
thats cool...
Kalgard Racing
Banzai Motorsports
ProMatch Racing
A-Train Racing
Warehouse Raceway
Old 08-12-2004, 12:49 PM   #1920
rctoyguy's Avatar
Trader Rating: 21 (100%+)
We're home from the hospital now, but I don't think I will make it Saturday... Maybe a stop by to say hi, but that might be pushing it. Looks like I will miss awesome weather for a race.
Jeff
rctoyguy is offline   Reply With Quote
Pro-Match Batteries Goingfast R/C Items: For Sale/Trade 8 03-02-2008 12:00 PM
Pro Match Batteries............. RH Customs Electric Off-Road 8 01-17-2006 10:19 AM
Pro Match Batteries dmayhew25 R/C Items: For Sale/Trade 2 09-26-2005 05:49 PM
FS: 4 Pro Match Batteries L.Fairtrace R/C Items: For Sale/Trade 11 11-10-2004 06:41 PM
How do you zap and match batteries Yokomo Aust Electric On-Road 24 05-10-2004 12:41 PM
