Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 11-04-2003, 07:28 PM   #31
rtypec's Avatar
Default Re: Tribo, Speedjuice or nothing (Nothing)
Originally posted by popsracer
I DO take offense when someone who does not know me personally, makes derogative statements about my driving and tuning abilities.
Pops, perhaps you should not talk offense so easily. Neil is only offering a suggestion and did not intend to disturb you.
Originally posted by RCInfinity
Pops, pitting could possibly due to spring tension and driving style.
He did not say YOUR spring tension and YOUR driving style did he? If people were to rip on each other by providing advice based on experience..all anybody would do is disagree.
My experience with Tribo is a mixed bag. Yes, it feels like it has a little more power on track (not much but enough to make you want to use it at big races) and yes it also gums up the brushes if you use too much.
Just my 0.000000002 yen
rtypec is offline   Reply With Quote
Old 11-05-2003, 12:27 AM   #32
Neil Rabara's Avatar
Default Re: Re: Tribo, Speedjuice or nothing (Nothing)
Thanks for the support Rod. Looks like I hit a nerve with Pops, which I didn't even intend.
Guess who got a partial?
Neil Rabara is offline   Reply With Quote
Old 11-05-2003, 02:58 AM   #33
RBLove's Avatar
Trader Rating: 72 (100%+)
One thing we have found with the Monster motors to get more torque out of them is to put a timed cut on the brush but put it in backwards...To take timing out. It will knock off around a 1000rpm but will bring the torque and power up.
Hope this helps.
Eric Anderson
Putnam Propulsion
Eric,
Mind giving a little more detail on how this is done? Thanks man. I have heard different things and am somewhat confused...
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 11-05-2003, 05:54 AM   #34
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Rob just take 10-15 thousandths off the leading edge of the brush...Normally you would take about the same off the trailing edge. You can also run a very small hole in the center of the brush after you de-time it to help brush contact.
ea
I can take a pic of a brush later if you need.
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 11-05-2003, 05:59 AM   #35
RBLove's Avatar
Leading edge.... When inserting the brush into the hood you are talking about right side as the leading edge??? That is what is confusing to me. I have seen the cut that Todd puts on his brushes, but get contradicting answers on leading and trailing.
Old 11-05-2003, 06:35 AM   #36
jrighter's Avatar
The leading edge would be the right side. Todd cuts the trailing which is supposed to help torque.
jrighter is offline   Reply With Quote
Old 11-05-2003, 06:45 AM   #37
sands's Avatar
Actually, a leading edge cut will advance the timing and make the motor spin faster to the sacrafice of efficiency and torque.
A trailing edge cut will retard the timing and make it more torqy and possibly help the efficiency.
I've found that a hole in the positive brush will help the efficiency drastically and push the rpm up a bit. Power stays the same with a shift to the higher end. Torque drops.
Cutting the corners off of the trailing edge of the negative brush should reduce the arcing and burn, though I don't have enough experience to comment on the torque and power impact.
I need more torque and wanted to confirm the trailing edge cut. I've never tried it before. I'll probably try it tonight with some 4499s so I don't waste my Putnams on it. If it works, I'll do it to my putnams.
sands is offline   Reply With Quote
Old 11-05-2003, 09:04 AM   #38
rtypec's Avatar
Default Re: Re: Re: Tribo, Speedjuice or nothing (Nothing)
The hell if I know It seems that everybody has a partial. Except for me and Berger...kinda ironic huh?
I'll be bringing a brand new bottle of tribo with me to Japan
Old 11-05-2003, 09:42 AM   #39
BigDogRacing's Avatar
R/C Tech Charter Subscriber
Send a message via MSN to BigDogRacing
How would cutting the leading edge advance the timing if it delays where (in realtion to) the brush makes actual contact with the next contact on the comm? It doesn't. It retards the timing. Your thinking must be a little backwards there sands. You can rest assured that EA has forgotten more about race motor tuning than most of us will ever know.
EA- WHY YOU TELLING ALL THE GOOD SECRETS!!!
BigDogRacing is offline   Reply With Quote
Old 11-05-2003, 09:45 AM   #40
Suspended
Trader Rating: 28 (100%+)
Totally agree with you BDR.What sands says is backwards.No offense.
racenut123 is offline   Reply With Quote
Old 11-05-2003, 10:55 AM   #41
Default Re: Re: Re: Re: Tribo, Speedjuice or nothing (Nothing)
YGPM
Old 11-05-2003, 11:06 AM   #42
sands's Avatar
advancing the timing on a mod motor means turning it more in the direction of rotation. looking at the end bell, this means turning it clockwise. From say 12 deg to 32 deg. Last time I checked (I still may be wrong, need to check this out tonight) this meant more speed, less torque.
The same can be done with a fixed endbell by trimming the cut of the brush.
http://www.nascart.com/electric.htm for how to cut a brush to increase the timing, what I call advance (and may be incorect)
This may also be a semantic issue, my definition of advanced timing might really be retarded timing.
Leading edge cuts = more speed
trailing edge cuts = more torque
advance, retard, whatever, the brush cut matters. If I read the other posts right, we are saying the same thing.
Old 11-05-2003, 11:15 AM   #43
jzone's Avatar
So why not square the brush. Cut both leading and trailing edges.
I used to do it on the old MVP's worked great.
J
Jesse Galang
Northwest R/C Club - VP
OverGeared Racing OG
Team Associated | Reedy | Orca
jzone is offline   Reply With Quote
Old 11-05-2003, 12:13 PM   #44
tc3rookie's Avatar
Default stock
i used a stock class for a while and it had good power and speed, but was very sensitive to heat/ overgearing. one toothe off and it starts frying if you're not careful
tc3rookie is offline   Reply With Quote
Old 11-05-2003, 02:43 PM   #45
jzone's Avatar
I much prefer the monsters to anything else right now.
Anyone try any brush timing with the Camillion 2?
Jesse Galang
NIP Putnam Propulsion Items FS ovalnator R/C Items: For Sale/Trade 32 08-26-2007 06:43 PM
Putnam Propulsion Invades Australia Todd Putnam Australian Racing 27 10-21-2005 12:46 PM
Putnam Propulsion new mod motors Michal101 R/C Items: For Sale/Trade 0 12-18-2003 02:10 PM
Axiom vs. Putnam Propulsion M Ignacio Electric On-Road 12 03-31-2003 07:25 AM
Putnam Propulsion Site Now Up! Racer X Electric On-Road 0 01-10-2002 05:01 PM
