Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 07-21-2004, 05:58 PM   #676
Trader Rating: 37 (100%+)
thanks for the props....
Hopefully everyone is taking advantage of the new lower prices on teamhurricane.net.
See everyone at the track.....hopefully some of you will be at trackside this sunday.
I'll be bringing my new and improved Votron Hurricane blue lion XXXS :P
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 07-21-2004, 06:05 PM   #677
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Nexus.....that looks Sharp man
I will see you and the Blue Lion at Trackside on sunday.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 07-21-2004, 09:05 PM   #678
trackdesigner71's Avatar
Send a message via AIM to trackdesigner71 Send a message via Yahoo to trackdesigner71
Hola team Hurricane!
The US Pan Car Championships are rolling right along and entries will open on July 31. I hope to see many of you doin a little Texas two step April 28-May 1 Here is the flyer/entry form
trackdesigner71 is offline   Reply With Quote
Old 07-21-2004, 09:34 PM   #679
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
prices are awsome now!
Kave is online now   Reply With Quote
Old 07-22-2004, 02:09 PM   #680
Looks like it should be a good day of racing at S&N. The weather man is predicting a hurriacane!!!!!
Did you here about the boy in california? Well he was at the zoo and a ostrage bit off his eye lids. So he was rushed to california genrel were the performed extensive surgury and ended up circumsizing him. So they could use his for-skin for eye lids.
Yea they say he is a little cock eyed now.
That could come in handy for fu man chew----
Chad Parry is offline   Reply With Quote
Old 07-23-2004, 03:14 PM   #681
kevin2's Avatar
Send a message via AIM to kevin2
Post
I have been runnin a couple of gp 3300 for about 2 or 3 months. I cant get any run time out of them now. I have been charging at 6 amps and discharging with 20 amps but one bulb is burnt out so its i think 16 amps then. Then equalize them on a indi real time tray.I just got a indi reactor 30 amp dis charger and a novak smart tray, r they packs i have right now trash?
kevin2 is offline   Reply With Quote
Old 07-23-2004, 03:42 PM   #682
Kevin K's Avatar
Hey Kev....what Charger are you using and what peak detect are you using? How much run time are you loosing? Like you cant make 5 minutes in Stock? Also which Indi tray is it that you have one of the trays is a dead short tray and that might be why you have a loss of run time too. But your packs should not have had any major loss of run time in that short time frame. Give me some more info so I can help you out. Also if your going to be at Trackside on Sunday stop by and see me I will take a look at whats going on with your packs.
Old 07-23-2004, 04:12 PM   #683
kevin2's Avatar
Post
yeah ill be there on sunday. I have my pulsar at 30mv cut off, but i have used my dads pit bull with the long lock out but it still is pretty low.Usually i have gotten some where between 2400-2600 mah.in 19t i dump every time and stock half the time i dump on the last lap.
Old 07-23-2004, 04:29 PM   #684
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
sounds like the cells just need some tlc, usually gp's bounce right back.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 07-23-2004, 04:32 PM   #685
Kevin K's Avatar
Ok come by on sunday and let me charge one of your packs and see how it comes out on my charger. They should be peaking alot higher then 2600mah. I still have a feeling that this might be caused by your discharge tray depending on which one it is. If you were leaving the packs on the tray too long you would be like dead shorting the cells and then not puting a jumper wire on them....that would be like taking them to a very low voltage and left there which will hurt your performance. But Stop by on Sunday and I will take a look and charge up a pack and see how it works on my Charger just to try something from the outside to see whats going on. Also I will check out your discharge tray and see which one it is.....Indi I dont think makes a Real time....they ones they make are called Octane or something like that. The Real Time one is a Trinity one and that one will bring your packs down to zero which will hurt the performace if you leave them that way. We will get this figured out on sunday....if you need some packs to race with I can lend you a few to use as well.
Old 07-23-2004, 04:33 PM   #686
kevin2's Avatar
Post
what would i have to do to get the mah back?
Old 07-23-2004, 04:38 PM   #687
Kevin K's Avatar
Kev....its hard to get the MAh back but with your packs not being that old we just might be able to. We will work with them on sunday and get you heading in the right direction.
Old 07-23-2004, 04:39 PM   #688
kevin2's Avatar
i ment the indi octane-2 but im getting the smart tray on sunday
Old 07-23-2004, 04:43 PM   #689
kevin2's Avatar
Post
thanx
Old 07-23-2004, 04:48 PM   #690
Kevin K's Avatar
The Smart tray would be a better way to go....with its adjustable cut off. I think that the Octaine 2 will go down to Zero but Im not 100% sure. The only time that I use a tray is right before I charge. Once Im done running the pack I just take it down to 5.4volts and leave it until next time. But that is just how I treat my cells. Anyway we will get you squared away on sunday and help you out the best we can.
Team Hurricane GP3700 wallstreet R/C Items: For Sale/Trade 2 04-06-2007 05:48 PM
Team Hurricane Matching EP Cells wallstreet Electric On-Road 6 03-12-2007 03:45 PM
Midwest Touring Series sponsored by Hurricane Motorsports Speedie Wisconsin & Illinois Racing 1069 07-27-2005 08:26 PM
Hurricane Motorsports shipping? Clegg Wisconsin & Illinois Racing 20 12-03-2004 11:12 PM
Hurricane Motorsports Stock Challenge At The Den R.C. Raceway Shawn05 Wisconsin & Illinois Racing 120 03-16-2004 06:59 AM
