Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 05-03-2005, 05:55 PM   #1591
Kevin K's Avatar
Trader Rating: 32 (100%+)
Send a message via AIM to Kevin K Send a message via Yahoo to Kevin K
Chuck.....Yeah I will be out there with the new car. Its almost built I have the drive train and front end build thats about it. But I will have it out there ready to run on saturday.
On the second charge of the day the Voltage goes up the Runtime goes down.
2013 USVTA World Champion of the World
MOTIV RC presents the Midwest All-Star Carpet Series....15th year running 2017/18!!!
USVTA National Championship....check it out!!!
Im only responsible for what I say NOT what you understand.
Kevin K is offline   Reply With Quote
Old 05-03-2005, 08:42 PM   #1592
wolfden's Avatar
Hey Kevin,
I seen you post earlier about not discharging after you run. What your saying is that i can take the pack out of the car after the six minute race and not do anything until the next time i race? Unless of course it's the same day.
R the novak trays worth the money? I have the real time 2 from trinity. I could buy a novak if it will help keep the edge in the cells.
Do you have any idea how much run time you loose. Cause if the voltage goes up. That could never hurt. Guess if it keeps getting better i better practice 6 times with my pack before i race......
wolfden is offline   Reply With Quote
Old 05-03-2005, 08:56 PM   #1593
Kevin K's Avatar
Wolfden.....Yeah after you run the pack and its done for the day there isnt really any maintenance that needs to be done at that point....unless you are going to store them for an extended period of time like 2 months or so. If you are doing long term storage put about 500 seconds of charge into the pack and leave it like that. Then with these packs next time you get to the track put them on a tray and discharge them before the first charge of the day.
The Novak is a great tray....if you want something a little cheaper and only use 6 cells the Rayspeed one is nice but doesnt work well with 4 cell packs. The Trinity tray and most of the Integy trays will take the cells down to far if left on the tray to long as they dont have cell cut off settings.
On average you will loose about 25 to 40 seconds of runtime on the second run of the day but that can change depending on the type of racing that you are doing. If your racing stock sedan or something you will only loose about 20 to 35 seconds of run time, but with mod or 19t sedan you will loose more like 35 to 45 seconds on the second run. You can run a pack like 3 or 4 times in a day mainly if you are racing stock other wise you might start to run short on runtime. Even with doing that in stock the pack will seem to fall off sooner into the run then it did when it was on the first or second run of the day. What I do for racing normally is I have 3 "race" packs that I race with and the pack that I run in the first qualifier is the one that I run in the main. Then next week I switch them up so Im not running the same pack again in the first qualifier and main. This method for me makes my packs last a lot longer. I have like 2 or 3 practice packs that I will run a number of times in practice but they are just that practice packs and Im not to concerned with taking care of them.
Old 05-03-2005, 09:07 PM   #1594
wolfden's Avatar
Sounds good,
The novak tray has programmable cut off points? Does this mean you can discharge each cell individually. Meaning the tray shuts off each cell when it reachs the setting point? Is the standard setting on the tray what most people use?
thanks for the info.
Old 05-03-2005, 09:15 PM   #1595
Kevin K's Avatar
With the Novak tray you pick a set value for the whole pack...say .9 per cell. Then each cell is discharged on its own until it falls below the .9 voltage or what ever setting is that you choose. But you cant set it up the voltage for each cell like if you wanted to set one cell at .8 and another cell at .9.....if thats what you ment. Yeah most people set the tray up for .9 or .8 per cell. Im not 100% on what the default is but its easy to set and change.
Old 05-03-2005, 09:20 PM   #1596
Send a message via AIM to goop
Default wolfden
you hit it right on the head that is exactly what the novak tray does and the setting should be .9
Hurricane Motorsports
Team Trinity
TOP Racing - Gravity Rc - Contact tires - KO Propo - Competition Electronics
goop is offline   Reply With Quote
Old 05-03-2005, 09:20 PM   #1597
Trader Rating: 37 (100%+)
man kev...great info!
Wish I could make it out to AJs for the first Sat. night.
I should be racing the next weekend at AJ's or Tinley.
kev you going to be running your JRXS outside or the XXXS?
Serpent Racing * Speed Passion * Fantom Racing * Windy City Raceway
Nexus is offline   Reply With Quote
Old 05-03-2005, 09:25 PM   #1598
Kevin K's Avatar
Tone....I will be racing the JRXS outside once I get it completed and get around to painting up a body or two. Easier said then doen these days....lol.
Old 05-03-2005, 09:31 PM   #1599
man i threw down my new xray at aj's on saturday and it was soooo windy. the wind was blowing off the offroad track so when it kicked up you couldnt even see your car anymore. then when you were done and went back inside the car was just filled with dirt. my xray is trashed time to rebuild. but i must say it was fun running a 7x2 revolution motor.
Team Trinity
Old 05-03-2005, 09:36 PM   #1600
Kevin K's Avatar
Goop....what were you running for tires? Foams or Rubber? Will you be out at AJ's this saturday as well?
Old 05-03-2005, 09:52 PM   #1601
wolfden's Avatar
Thanks for the great info.
Old 05-03-2005, 09:54 PM   #1602
i was running cyan and magentas and i dont think i can make it this weekend. my car is in pieces being rebuilt
Team Trinity
Old 05-03-2005, 10:00 PM   #1603
Kevin K's Avatar
Come goop....its an X-ray its faster apart then it is assembled just like my JRXS is....right now its soooo fast sitting on my work bench....I think it TQed from there last weekend.
Wolfden.....No problem man any time.
Old 05-04-2005, 01:06 AM   #1604
wallstreet's Avatar
Trader Rating: 20 (92%+)
Send a message via AIM to wallstreet
is there any way to get the run time back into the packs ?
wallstreet is offline   Reply With Quote
Old 05-04-2005, 03:49 PM   #1605
Kevin K's Avatar
Wallstreet....are you talking about if there is a way to get run time back in the same day or over the life span? Well with a pack that is run more then once in the same day you will loose some run time like stated before. How ever you will get that back after the pack has time to rest like 24 hours or more time and all the run time will come back....with that being said the longer you can let the pack rest the more of that lost runtime will come back. Also when a pack is older and has been run or race "cycled" many times and has lost some runtime there is no way to get that back.
Team Hurricane GP3700 wallstreet R/C Items: For Sale/Trade 2 04-06-2007 05:48 PM
Team Hurricane Matching EP Cells wallstreet Electric On-Road 6 03-12-2007 03:45 PM
Midwest Touring Series sponsored by Hurricane Motorsports Speedie Wisconsin & Illinois Racing 1069 07-27-2005 08:26 PM
Hurricane Motorsports shipping? Clegg Wisconsin & Illinois Racing 20 12-03-2004 11:12 PM
Hurricane Motorsports Stock Challenge At The Den R.C. Raceway Shawn05 Wisconsin & Illinois Racing 120 03-16-2004 06:59 AM
