Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-14-2004, 08:02 PM   #2806
Trader Rating: 17 (100%+)
Send a message via AIM to Kave
i have tried both, along with taking it out of the car, along with a different reciever, along with a different servo
Kave is offline   Reply With Quote
Old 04-14-2004, 08:03 PM   #2807
and guys dont get me wrong, im not raggin on bmi, i love my bmi car!!!! i plan on a bmi pro4 soon!
Old 04-14-2004, 08:05 PM   #2808
protc3's Avatar
it even happens with the electronics not touching the chassis?
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-14-2004, 08:06 PM   #2809
all but the servo, cuz thats what i use to test da glitching, how far they twitch, yep
Old 04-14-2004, 08:06 PM   #2810
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Send a message via AIM to wyd
Originally posted by pballkid21587
brian i cant even throw it down on a track, the wheels literally go back and forth when i hit the gass on the bench, same on the floor
Did you try the Novak wiring harness like they use on the GT7. I use that wiring setup and that stopped the glitching I had. It is only 10 bucks and was well worth the money.
ST Racing Concepts (STRC)
Old 04-14-2004, 08:07 PM   #2811
it is a gt7, and of course, yes i use it
Old 04-14-2004, 08:10 PM   #2812
protc3's Avatar
let me think about this for a bit.i will see what i can come up with
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-14-2004, 08:11 PM   #2813
thanks, jason ur customer service is AWSOME.
Old 04-14-2004, 08:12 PM   #2814
Default glitching!!
PBALL !! make sur you put 3 pieces of servo tape under the speedo and reciever . and also chk that the motor/motors your running does not have blown diods in them .. make sure your wiring is clean and not crossed over eachother . and that your crystals are ok.. if your reciever is on top of the servo put 2 pieces of servo tap under the servo .. .. make sure your speedo isnt touching the center support and the last thing I could think of and tryed is to put some insulation on your antenna wire from the reciever to the antenna tube .. you should be ok.. didnt you have glitching problems on other cars too .. dont know if it was you or not .. give it a try . let me know if i can help you out ..
Mark Barden .
mb racer is offline   Reply With Quote
Old 04-14-2004, 08:14 PM   #2815
wyd
Tech Legend
wyd's Avatar
Man I know of a ton of guys with the GT7 that glitch. I know Tony Stewart had 5 or them on his Custom Works cars and everyone glitched. He put in all new Keyence speedos and the glitch was gone. I have seen and heard the GT7's have problems from time to time. I'm sure you changed speedos but if not I would.
Old 04-14-2004, 08:15 PM   #2816
do you think the lrp v7.1 is a good esc
HEWITT is offline   Reply With Quote
Old 04-14-2004, 08:16 PM   #2817
i have, but ill try it again, i think i have 3 gt7s laying around
Old 04-14-2004, 08:17 PM   #2818
Default gt7
I run them and I dont have the problems some people have with them ..i must have good luck or good products .. !!
Mark Barden .
Old 04-14-2004, 08:24 PM   #2819
rayhuang's Avatar
Could be a bad module or radio. my brand new Helios suffered the same problem and it was a loose wire in the radio that cuased the antenna to not be connected. It wasnt dropped or abused-the wire just came off.
Ray
Old 04-14-2004, 08:27 PM   #2820
this may sound wierd, but i took everything out, put it back in, and then played with reciever postion, ontop of the servo with no servo tape, to a very very thin layer is the only place it went away. dont ask, i know i wont, but it worked and there is only 3 weeks of onroad left so ill live
Crawler / climber discussions Frost Malaysian R/C Racers 40 02-09-2007 11:37 AM
EXTREME RC MODIFICATION - Findings and Discussions mop_iko Nitro On-Road 126 08-20-2004 03:12 PM
Discussions with UCHEATULOSE !! lmunno Florida Racing 5 04-12-2004 08:34 PM
Gran Turismo 3 A-Spec helps and discussions Cmotif Chat Lounge 72 01-17-2002 07:19 PM
