BMI Racing Discussions
#2762
Tech Legend
Trader Rating: 51 (100%+)
Originally posted by dr_hfuhuhurr
wyd,
We run Asphalt/Foams during the summers here. The track is being constructed this weekend I believe. He'll probably have some answers for you soon.
Blake
wyd,
Blake
#2763
Brian - I ran jaco purples all 4 corners and TRC magenta front or purples and purples rear outside. Works well when the track is clean!
Track temps should be higher this weekend, so you might be able to get away with Sorex 24R's or takeoff 27's if you want to try running rubber. The foam soaks up too must of the dusty and makes the tire slide more. Rubber might be the answer till that track is prepped.
#2764
Tech Legend
Cool. I was going to try my indoor tire set up 1st with Jaco D. Purples on the front and Jaco purples on the rear. If that is not enough steering then I will go for purples all the way around. I might and I mean I might pull out the one way to try.
#2766
Tech Legend
I have alot of stuff to try. The one way, a little stiffer oil in the car instead of the 40wt I have now, and I want to go to a longer front camber link setup this week. Wow I think I will be busy.
#2768
Tech Legend
Originally posted by John Fontaine
Brian - I'll send you PM.
#2770
Thanks - I try to help as much as I can and share my knowledge to other racers. I must of converted more than 100 people already to the proper charging of GP3300 cells.
John
John
#2772
Mi2 Chassis?
This was probably already asked but I'll ask again. Any plans for a BMI Mission 2 chassis? price? availability? Thanks
#2773
Tech Legend
BMI Pro4 titanium chassis setup:
#2774
Wyd,
No asphalt yet. Test and tune is next weekend at our "parking lot" track. It is not very smooth and is a giant tire truer I will be sure to post any set up info I find........ I had my TC3 absolutely dialed outside so I have a pretty good idea on set up already....
