Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 04-02-2004, 04:17 PM   #2371
Send a message via AIM to True R/C Racing
Originally posted by koabich
All these changes you stated above about the BMI chassis being stiffer and having moved the batteries...is this compare to the normal X-Ray chassis or the new Factory team chassis?
thanks
Joe
If Im not Mistaking It is on the normal evoII chassis. The Ft ver just came out, that chassis been available sometime.
True R/C Racing is offline   Reply With Quote
Old 04-02-2004, 04:17 PM   #2372
Speedie's Avatar
That sounds interesting. It would bolt right on but Im not sure if the motor mount will clear you might have to notch out the top plate or drill a hole in it to reach the screws. Then there is the center brace for the BMi top plate that will need holes drilled for it as well. Pieces parts..... fused........
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 04-02-2004, 04:27 PM   #2373
protc3's Avatar
the upper plate will not fit on the warpspeed chassis due to the different style motor mount.with the clamp style motor mount,you need to remove the upper brace to take the motor out due to the verticle removal.other than that and the standoffs it would probably fit.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 04-02-2004, 08:06 PM   #2374
protc3's Avatar
racenut123,the cuda chassis is my next kit.it will be available real soon.i will keep you posted.
jason
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-02-2004, 08:34 PM   #2375
forty6's Avatar
jason
Hopefully, the SD will be next to follow after the fish.
forty6 is offline   Reply With Quote
Old 04-03-2004, 04:24 AM   #2376
protc3's Avatar
SD will be immediately following cuda
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2004, 03:23 PM   #2377
protc3's Avatar
here is the ultra tune Xray asphalt upper brace.you adjust the flex by sliding the clamp foward or backward.let me know what ya think.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2004, 03:26 PM   #2378
protc3's Avatar
the clamp consists of 2 halfs.top is a button head washer that i machined fro 6061 aluminum and the bottom is the same but it has a boss milled into it which locates center and keeps the bottom plate from spinning.it slides freely through the slot in the upper brace with very little to no rotation.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2004, 03:33 PM   #2379
Yo that Topdeck for Xray looks Awsome man. hope it actually works that little thing you slide back n forth to adjust flex in it.
Old 04-03-2004, 03:41 PM   #2380
RBLove's Avatar
Trader Rating: 72 (100%+)
Jason,
Very inovative dude. That is a slick little idea. Great work!
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 04-03-2004, 03:44 PM   #2381
its Really cool but, is there something to hold it in place? It looks like its real easy to Move up n down. Like while your driving it will it Rock back n forth?
Old 04-03-2004, 05:56 PM   #2382
protc3's Avatar
this is how it works.the bottom piece is threaded and the top piece takes a flathead screw.you loosen the screw,adjust the clamp and the lock the screw.the screw will lock the 2 plates together.i did test it and it did increase flex the further forward you moved it.i made this one out of 2mm c/f due to my chassis being very stiff,it was the only way i could get it to flex.thanks guys.its going to get some track testing next weekend. i will let you know how it works out.i will also post a disassembled pic so you can get a better idea how it works.
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2004, 06:06 PM   #2383
protc3's Avatar
here is a pic of the clamp
Jason Breiner
BMI Racing
Team Associated
J Concepts
Old 04-03-2004, 06:54 PM   #2384
Speedie's Avatar
Thats a sweet Idea.
One up for the Xray guys. Are ya gonna try something like that with other top braces as well?
Old 04-03-2004, 07:14 PM   #2385
rayhuang's Avatar
Default Tis is sour grapes, but....
I'd say something about it on Xray thread-but then I'd have to hear again how Xray thought of everything first and dont even think about putting something on your Xray thats not made by Hudy---haruumph!
BTW-Jason-I will soon have the complete fleet of BMI electric conversions!! Xray, Tc3 and Pro4!!! hahaha!! I can start a dealership of BMI cars!!!
Ray
Crawler / climber discussions Frost Malaysian R/C Racers 40 02-09-2007 11:37 AM
EXTREME RC MODIFICATION - Findings and Discussions mop_iko Nitro On-Road 126 08-20-2004 03:12 PM
Discussions with UCHEATULOSE !! lmunno Florida Racing 5 04-12-2004 08:34 PM
Gran Turismo 3 A-Spec helps and discussions Cmotif Chat Lounge 72 01-17-2002 07:19 PM
