Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-31-2004, 11:27 AM   #2326
rayhuang's Avatar
Default GT7 in BMI
Hey BMI racers,
I wanted a cleaner wiring on my car so I mounted the NOvak Super schottky diode under the driveshaft by soldering the wires directly onto the solder tabs on the bottom of the ESC. I then mounted the diode under the driveshaft with dbl stick tape.
HEres a pic from the battery side. Looks better than it glued to the top of the ESC or hangin in space!!
Ray
Old 03-31-2004, 11:44 AM   #2327
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Man, reading this...BMI is taking off.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-31-2004, 12:42 PM   #2328
forty6's Avatar
Default Re: Re: Xray chassis
Originally posted by rayhuang
I beleive you get the chassis and upperdeck for $79.99 in black. Colors will be I think $10 more??!! Its 3mm bottom and top.
The front and rear shock tower, battery straps and bumper brace are optional.
Ray
Thanks for the info Ray.
forty6 is offline   Reply With Quote
Old 03-31-2004, 01:45 PM   #2329
RBLove's Avatar
Trader Rating: 72 (100%+)
Default Pro 4
Jason,
I sent the kit top deck to you next day air You will have in the a.m. to compare......
Pro 4 racer's... Here is a set up for carpet with foams that has been dialed for me. In stock that is......
Front:
#4 piston w/50 wt. Losi oil
Losi white spring
inside on arm
laid in third hole on tower
camber link is out and shimmed low (2mm spacer)
6 degree caster blocks
.5mm anit-dive
low roll centers
1mm up travel (droop)
kit sway bar
4mm ride height
-1.5 camber
2.5 block (arm sweep)
rear:
#4 piston w/45 wt. Losi oil
Losi black spring or white
middle hole on arm
out on tower
camber link inside shimmed high (4mm)
outside on hub
standard wheel base (large shim in rear)
.5mm anti-squat
low roll centers
1.5mm up travel (droop)
no bar
4mm ride height
-1.5 camber
2.5 toe block
RC-Square .5 rear hubs reversed (total of 2.0 rear toe) Cannot wait for HPI to release the blocks...
BSR purple orange front
BSR purple rear
Tires are same as Jaco
This set up has been very good for me at multiple tracks. I will post more as I find new adjustments...
To note:
BMI 3mm chassis/top deck/shock towers. These are soon to be realeased if not already. I will provide feedback of the stiffer carbon Sunday night after racing. It fixed any tweak issues, is rock solid, and most important beautiful
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 03-31-2004, 01:51 PM   #2330
forty6's Avatar
RB,
You don't drive a Schuie anymore ?
Old 03-31-2004, 01:56 PM   #2331
RBLove's Avatar
forty6,
No I do not.
Here are some pics!
Old 03-31-2004, 01:56 PM   #2332
RBLove's Avatar
Another:
Old 03-31-2004, 01:57 PM   #2333
RBLove's Avatar
And another:
Old 03-31-2004, 01:57 PM   #2334
RBLove's Avatar
Last one:
Old 03-31-2004, 02:01 PM   #2335
RBLove's Avatar
Schumacher:
For anyone interested in why I am no longer running the Schumacher. Before rumors start, etc..
The Mi2 is a great car. My car worked pretty good at Snowbirds, but I have struggled a little with it at home. It is just a new car and design and it takes time to get them right. I guess I was not really committed to put that time in right now. Paul Wynn and Schumacher treated me great. They are a stand up group of guys.
Anyone running the Mi2 keep an eye out for the all new P-Dub Racing product line. Going to be killer stuff.
Old 03-31-2004, 03:46 PM   #2336
Speedie's Avatar
Hey RB
I got my diode and my capacitor to fit up under there, heres a pic.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-31-2004, 04:14 PM   #2337
rayhuang's Avatar
Hey RB,
From the look of that chassis beveling job-youd think i did it for you!! hahaha!!! But seriousely-nice chassis prep and car looks sweet Jason!!
Ray
Old 03-31-2004, 04:42 PM   #2338
protc3's Avatar
thanks bro,give me a call some time this week so i can get all the particulars on your xray chassis.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-31-2004, 11:59 PM   #2339
Speedie's Avatar
Ive heard its particularly fast hows that?
Old 04-01-2004, 03:41 AM   #2340
burbs's Avatar
Send a message via AIM to burbs Send a message via Yahoo to burbs
hi i emailed bmi last week about getting a toplate for my current chassis... i have yet to get a responce... i used the email on there website... anyone know why or who to contact for stuff.. thanks
burbs is offline   Reply With Quote
Crawler / climber discussions Frost Malaysian R/C Racers 40 02-09-2007 11:37 AM
EXTREME RC MODIFICATION - Findings and Discussions mop_iko Nitro On-Road 126 08-20-2004 03:12 PM
Discussions with UCHEATULOSE !! lmunno Florida Racing 5 04-12-2004 08:34 PM
Gran Turismo 3 A-Spec helps and discussions Cmotif Chat Lounge 72 01-17-2002 07:19 PM
