Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-30-2004, 09:17 AM   #2296
rayhuang's Avatar
When your at the LHS-just buy the Blue screw kit from Associated. I dont have a part number-but its a bag filled with assorted socket, flat and button head screws-all in Blue aluminum.
If your stripping them-your tightening them too much. Also-one small tip if I may-use a steel socket head to prethread all new holes-or a 4-40 tap if youve got one. I use steel screws still in the steering rack with a drop of threadlock and Long steel screws in the battery posts to make sure they dont bend.
Also-I use 3mm screws in the body posts as they are a bit oversized and will NOT loosen up.
Ray
Old 03-30-2004, 09:28 AM   #2297
WVRACER's Avatar
Send a message via AIM to WVRACER
Originally posted by UnderDaHill
Any suggestions for a screw set to use when assembling my chassis. I have a racer kit now and was going to switch from the steel to the blue aluminium but they strip so easily. I'd go with titanium but they are a bit expensive. Suggestions?
Links to a good prices would also be handy.
http://www.rcscrewz.com/
here is what i use thay seem to work good and the price is good i bought the big racer kit and it's lasted me for a while
Rob
WVRACER is offline   Reply With Quote
Old 03-30-2004, 10:06 AM   #2298
WVRACER's Avatar
bearing in frount of the spur is binding what are you guys doing to fix this?
thanks
Rob
Old 03-30-2004, 10:07 AM   #2299
Regional Moderator
UnderDaHill's Avatar
Send a message via AIM to UnderDaHill
Thanks WVRACER and rayhuang... I ordered a set from rcscrewz and will remember the 3mm screw trick for the body posts.
UnderDaHill is offline   Reply With Quote
Old 03-30-2004, 10:18 AM   #2300
rayhuang's Avatar
thanks
Rob
1-Take the aluminum spacer out!!
2-put a dab of thread lock on the bearing cap screws and then evenly tighten down the cap till its barely snug on top of the bearing.
Thats it-hope that helps,
Ray
Old 03-30-2004, 10:27 AM   #2301
WVRACER's Avatar
Ray
thanks ray i'll give that a shot. did doing this let you roll free?
i was wondering if i got a little bering sized gruve machined into the part if that would help
Rob
Old 03-30-2004, 10:37 AM   #2302
rayhuang's Avatar
Rob
Rob,
Its funny as I told Jason-you need a little sheet of paper with an addendum to the manual explaining about that little spacer and how the bearing cap is designed to float above the motor mount.
Do Not machine/sand or otherwise do anythng to the motor mount!!!
My drivetrian has old outdrive bearings, carpet fuzz in the input shaft bearings, cheap bearings with grease in them in the hubs and it spins the usual 8 seconds. Oh-I also have the Warpspeed Diff cases which I highly recommend.
Ray
Old 03-30-2004, 10:42 AM   #2303
WVRACER's Avatar
your right becouse on my old chasses i put the drimmel to the whole thing to get it so it would feel free with the screws snuged tight. so you don't even snug the screws down you just screw them down till it tuches the cap right
thanks for the help
Rob
Old 03-30-2004, 10:47 AM   #2304
rayhuang's Avatar
thanks for the help
Rob
Righto!! Always willing to help!!
Old 03-30-2004, 10:55 AM   #2305
WVRACER's Avatar
one more if you don't mind. do you use the alum cap or the stock one
thanks
Rob
Old 03-30-2004, 10:58 AM   #2306
rayhuang's Avatar
Stock cap on mine. Mine is barely tightened down without any threadlock and the screws have yet to back off.
Ray
Old 03-30-2004, 11:04 AM   #2307
WVRACER's Avatar
thanks alot!! i can't wate to get back up to the gate. i have never been anywhere where everyone was so willing to help a out of towner. especialy Tony W, Eric, Ray, little Zack with out there help i would have been lost at the champs last year
thanks
Rob
Old 03-30-2004, 03:38 PM   #2308
Send a message via AIM to LarryPryor
RB love please check your PM.
LarryPryor is offline   Reply With Quote
Old 03-30-2004, 03:53 PM   #2309
protc3's Avatar
dont use aluminum screws on the hinge pin blocks.every time i hit the wall it would snap the head off the flat head screws.i use titanium ones in there and aluminum everywhere else.
Jason Breiner
BMI Racing
Team Associated
J Concepts
protc3 is offline   Reply With Quote
Old 03-30-2004, 03:53 PM   #2310
carkillaii's Avatar
Wzup guys i was just reading up on useing the nitro tc3 steering rack on the bmi chassis, I understand why we would use it but what does lowering the diff case do ?
can anyone help me with this one
carkillaii is offline   Reply With Quote
Crawler / climber discussions Frost Malaysian R/C Racers 40 02-09-2007 11:37 AM
EXTREME RC MODIFICATION - Findings and Discussions mop_iko Nitro On-Road 126 08-20-2004 03:12 PM
Discussions with UCHEATULOSE !! lmunno Florida Racing 5 04-12-2004 08:34 PM
Gran Turismo 3 A-Spec helps and discussions Cmotif Chat Lounge 72 01-17-2002 07:19 PM
