Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 10-22-2003, 12:27 PM   #1006
holycow's Avatar
Originally posted by PitCrew
If you discharge down to .9 volts per cell at 30 amps, when there is no load, the voltage is going to jump right back up to 7.2+ for the pack. NiMH seem more suseptable to this than Nicd.
Yes that is exactly what they do. As soon as the discharge ends at 5.4 volts, if you leave it attached, you can watch the pack go RIGHT back to 7.x volts, like it was charging again.
So how do you incorporate all of this info?
30 amp discharge
the pack voltage going back up
using a simple blulb/resistor tray
holycow is offline   Reply With Quote
Old 10-22-2003, 12:35 PM   #1007
Holycow! (cool handle)
Just unscrew the bulb when it goes out. After all 6 are all out or unscrewed, you have an equalized pack. If you check the cells, they will be real close to .9 volts each when the bulb goes out.
I have the same tray. "Indy Activator". You can also buy 1.5 amp bulbs from Integy or radio shack so it works faster and better. Just make sure you have 6 of the same bulbs.
David Root
David Root is offline   Reply With Quote
Old 10-22-2003, 12:45 PM   #1008
Maj. Teeth's Avatar
David Root
Exactly!
Dan
Maj. Teeth is offline   Reply With Quote
Old 10-22-2003, 12:52 PM   #1009
holycow's Avatar
AHA! Uncrew the blulb! Now why is it that sometimes the easiest things are the last thing I think of? I will try that!
So are you saying that when the bulb is (just as an example) 75% out, that the cell is at .9 volts? Do you wait for the blub to be completely out?
Old 10-22-2003, 12:52 PM   #1010
Maj. Teeth's Avatar
Rory, No PM here. Can you send it again? Thanks.
Blue Sky: use a discharger to discharge it individually down to .9v per cell.
Berger: The packs when charged correctly should be around 145f~155F. Warm to slightly hot is a good thing for these cells.
Holycow: the reason behind using a good tray is that you want each cell to discharge evenly down to .90 cutoff per cell. This can be done with most tray that has a cut off of .90 which means the resistors will limit any current flow below .90v therefore the bulbs are not drawing any current at all. It also equalize the cells individually with this method and won't hurt the cells.
Dan
Old 10-22-2003, 01:03 PM   #1011
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dan - Got the batts built I'm ready for Sunday!
Old 10-22-2003, 02:01 PM   #1012
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Originally posted by holycow
But that doesn't do anybody any good if one cell discharges before another. If you pull when one bulb gets dimm, but another is fully bright, then you haven't used the tray like it was intended.
normally 1 or 2 or 3 bulbs go out before the others. My question is, is if one bulb is out, and one bulb is lit, is the cell with the "out" light getting drained below .9 volts?
I must not have stated that to clearly. I dont pull the whole pack off the tray when one goes dim, I just undo that cell from the resistor bank.
You can measure the voltage of the cell underload on the tray with a multimeter.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 10-22-2003, 02:02 PM   #1013
Good luck at the races bro. Keep us posted how you did and how you like the cells.
Old 10-22-2003, 02:04 PM   #1014
holycow's Avatar
I need a multimeter
Old 10-22-2003, 02:07 PM   #1015
Thanks John, I'll be in the Fukuyama booth on Sunday, hopefully I'll do good, gonna run pro stock.
Old 10-22-2003, 02:08 PM   #1016
I need a multimeter
They're very cheap and can be found at any hardware store/sears and have a lot of applications in the R/C hobby. It's always in my toolbox when I race
Now you can really find out the voltage when those bulbs go dim.
Old 10-22-2003, 02:15 PM   #1017
rc-zombies's Avatar
I need a multimeter
Flea market only a couple of bucks...
Old 10-22-2003, 02:16 PM   #1018
rc-zombies's Avatar
Good luck Randy... Leave the Lowsie at home and kick some butt with the WEB...
Old 10-22-2003, 02:26 PM   #1019
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I think he'll probably be running the Losi with all the work he put into the chassis. Besides, why run a coffee grinder when you've got a nice smooth Losi to run Right Randy?
Jon Kerr is offline   Reply With Quote
Old 10-22-2003, 02:50 PM   #1020
Losi's a good car.
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
