Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 08-17-2004, 08:36 AM   #5491
Herminator's Avatar
Send a message via ICQ to Herminator
Originally posted by acutts
Anyone know where I can get Fuky cells in the UK ...! The shop I used to deal with no longer has them ... BLEAK!
They are the best and I would like to keep using them ...
PM me, I may be able to help you out, depending on what you're wanting.
Herminator is offline   Reply With Quote
Old 08-17-2004, 08:44 AM   #5492
Moderator
StephenSobottka's Avatar
Send a message via AIM to StephenSobottka
I believe but am not for sure, I would ask John Fonataine for this probly. But the first bacth og GP's were the non sp cells and they yeilded regular numbers at the time, good runtime, 1.14 was the best average voltage usually. The second batch banged out some very good numbers 425's for runtime mostly with a lot on 1.17's and higher. The last batch, they switched to an actual shorter sized can but the numbers stayed the same. I believe the newer cells actually perform better on the track though with the same numbers.
~~Stephen Sobottka~~
SMC Racing
StephenSobottka is offline   Reply With Quote
Old 08-17-2004, 08:58 AM   #5493
Herminator's Avatar
Just a quick word on how consistant my packs have been over the last 8-5months.
I use a Pro-Trak charger at 6amps, with 0.40 cutoff.
Discharge at 20amps to 0.9v and before charging every second time I equalise to 0.6v per cell.
When comming off a charge the packs always peak around 9.1-9.2v and have a "power" rating of around 102% (which is basicly a rating of IR and 100% is set to be what you'd expect from a club level matched pack) With equalising they get around 4100-4200mah into them, without it 3650-3800.
I never bother discharging a full pack to get numbers from them, they perform on the track, not on a table
In recent months, running 19Spec outdoors, the power rating has started improving slightly, usualy ending up at 103% on their first charge of the day. I rarely use a pack twice a day but a couple of weekends ago I did and on the second charge, after atleast 2 hours rest I got 107% power and the usual peak of around 9.1v at 3600mah. This pack flew and helped me stay in the top group of 19Spec drivers who were busy beating the previous years track record...
...yet it was my lowest numbers pack, my newest pack at 5 months old but they are 1.159s, the others I have are 1.168's (the oldest) and two packs of high 1.17's.
It's just great to know that after plenty of racing, the packs show no sign of needing to be replaced. Unless Dan feels the need to hook me up with some 1.19's
Old 08-17-2004, 09:03 AM   #5494
Herminator's Avatar
Default Re: SP2
Originally posted by MSB
Ive read something about the new GP's SP2.
Anyone from the Fukuyama team could comment that or explain what is the difference between non SP, SP & SP2
I believe SP is just a sticker that Orion added to their GP's to make them stand out from the crowd. Something they started when the second generation of GP3300's came out, which were giving better numbers.
Then there was the switch to a shorter cell, where number temporarily dropped slightly but soon rose back up and performance on the track seemed to be just as good if not better than the longer can cells.
SP2 may be another new label from Orion, maybe the cell specs have changed slightly again, not heard of anything yet.
Old 08-17-2004, 12:44 PM   #5495
Default Zapping
Do any of Fukuyama racers Zapp your batteries and if so is it worth spending the extra to get a zapper, Integy makes one and the price is not bad what is your comment.
Dr Smooth is offline   Reply With Quote
Old 08-17-2004, 12:49 PM   #5496
Moderator
I dont rezap my batteries except for sending them back to get rezapped and matched.
SMC Racing
Old 08-17-2004, 12:59 PM   #5497
TRNun, do you disassamble the packs when you send for rematch and zapping?.
Old 08-17-2004, 01:20 PM   #5498
Moderator
Yes, disassemble all the cells and clean them up before sending them in.
SMC Racing
Old 08-17-2004, 04:48 PM   #5499
donoman's Avatar
Send a message via Yahoo to donoman
The other day I was discharging my batteries with my Deans (w/ Black Box autocutoff) and one of the cells went "Pop". Now it won't charge to 3600mAh, and it's down to 3300mAh. (previously it was 3.6Ah)
I'm just wondering if I damaged the cells, because I was using a 20A discharger and I don't own an equalizer yet. And what can I do to fix the cells again?
donoman is offline   Reply With Quote
Old 08-18-2004, 05:50 AM   #5500
Donoman, sorry man but you need a new pack, as the saying go's pop go's tha cell it's time for a new pack, there is no fixing when that happen.
Old 08-19-2004, 05:54 AM   #5501
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Sorry Donoman, what you have experienced is called a cell venting. You'll see that happen over time if you don't have an discharge tray that equalizes the cells. Basically what happened, was after many cycles of charging and discharging, one cell was out of match with the rest. Eventually that cell fell well below of the .9v/cell cutoff and got too hot and vented due to pressure inside the cell.
If you can find out what cell vented, give Daniel a call at HQ. Maybe he can swap it out for you?
Sorry that it happened.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 08-19-2004, 07:31 AM   #5502
Moderator
That cell has vented, you will need a new one more than likely.
SMC Racing
Old 08-19-2004, 07:43 AM   #5503
Donoman, just get a new pack and forget about all the fuss sending and waiting, use the old pack for 1/12 scale.
Old 08-19-2004, 09:55 PM   #5504
picco007's Avatar
Trader Rating: 92 (100%+)
Send a message via AIM to picco007 Send a message via Yahoo to picco007
Just wanted to wish all of the Fukuyama users to kick some tail this weekend.
Dan, I'll be calling you regarding some deals here in south texas. I'll be in town next week so I'll give you a call.
Ronnie
picco007 is offline   Reply With Quote
Old 08-19-2004, 11:40 PM   #5505
donoman's Avatar
I'd love to do that but I earn 9$ an hour and the government takes about 1/4th of that.
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
