Fukuyama Batteries
#5281
I always charge outdoor, yesterday a friend of mine charged his pack (same than mine) in home, only 20mV and the charging finished with the pack at 140ºF
#5282
If i'm running 19 turn I charge at 6 amps. 5 amps if I'm running modified. Like I said. It depends on the conditions where I set the delta peak. Anywhere in the range of 45 to 55. The colder it is or the more wind there is, the higher I go. Even if it's warm, if it's windy out, the breese can cool things down. Indoors, 50 should be about right I'd guess.
#5283
HEre we switched to 19T because some drivers are still runnign nicd packs.....the we decided to run only 19T to keep a reasonable race level......
I went to the track today to test my packs, but my speed had problems and I don't know how long can I run with these packs, anyway, it's much moooooooooore than 5 minutes, obviously I can charge at 6 amps....
i'll try 40~50mV next race.....
thanks for helpin Jon.....
#5287
I ran a club race at Hobbytown Newark, 19T. Had some problems in qualifying (still trying to figure out how to make the reedy quad mag go fast and last for 5 min). Ended up qualifying 3rd overall. In the main first and second both crashed in separate mistakes in the first lap, so I was out in front and ahead of the carnage and was able to cruise to the win.
Next week is the REVO race, a yearly memorial race for a local racer/announcer who passed away a few years ago. I'll be running 19T and mini. It should be a great race.
-James
-James
#5288
James - I tried the "polarity brush" trick mentioned by Barry Baker and it really woke my Reedy Quad Mag up.
Rob
Rob
#5290
it was wrote on reedy race thread....
baker said that he drilled reedy 766 brushes as he called polarity brushes....the (+) brush has a + cross cut and the (-) brush has a horizontal - cut......
#5292
So far i've tried running 767's both full face and with a cavity. They both make good power (i'm running 36* of timing), but i'm just having trouble getting the brushes to last for a run without burning up and making the motor lose a signifigant amount of power. I haven't been running a fan but i'm going to try the associated heatsink fan this weekend.
Thanks for the suggestions about the polarized brush trick, i'll have to try that.
-James
-James
#5293
-James
-James
