Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 05-20-2004, 11:54 AM   #5056
rod_b's Avatar
Send a message via AIM to rod_b
Default Re: Question. . .
Originally posted by lem2
I'm new to Fukuyama Packs, saw their performance here in Manila and I was BLOWN away!!!!! So i got them
my question is:
How many times do I cycle them before i get the most out of it?
I use LRP Pulsar Comp, could somebody using the same charger and batteries post their charging set-ups?
Much Appreciated!!
Lemuel Pia
Philippines
Charge Rate: 6A - Linear
Peak Detect: 50mv
Trickle: Off
Pretty much the basic stuff.
rod_b is offline   Reply With Quote
Old 05-20-2004, 11:56 AM   #5057
Hebiki's Avatar
Trader Rating: 26 (100%+)
Originally posted by rangulo
rustler753- These motors will run hot if you over gear them. You are currently running 7.3 final drive and socal is a fairly small track. Here in Florida we run in the hot weather and on small tracks we run between 7.5 and 8.0. When track size is bigger than 100 feet long then you could run pinions that give you a final of 6.8 to 7.3. These mako motors are strong motors but be careful not to over gear the motor because heat can hurt the magnets.
track size of 80 to 90 feet use 7.3 to 7.8
100 to 140 feet use 6.6 to 7.0
Remember the stock motor always comes out hot but to much heat will hurt.
rangulo.. believe it or not... most of the people at socal run their monster motors between 6.5 to 7.6. yes someone runs their motor at 6.5 depending on the layout. so its a very common thing to gear a monster pro at 7.3 depending on the track layout. everyone usually stays between 7 and 7.5. we only know of one person who gears it at 6.5
Hebiki Design Works
Custom R/C Vinyl Graphics & Apparel: Your gear, your way!
Web Design - Web Development - Logo Design - Graphic Design
www.facebook.com/HebikiDesignWorks
Hebiki is offline   Reply With Quote
Old 05-20-2004, 12:29 PM   #5058
RCBuddha's Avatar
Trader Rating: 35 (100%+)
Originally posted by Hebiki
.... we only know of one person who gears it at 6.5
Hebiki's probably refering to me.... I'm still looking for pinions higher than 50 teeth.....j/k
RCBuddha is offline   Reply With Quote
Old 05-20-2004, 12:49 PM   #5059
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
LOL. Highest I have is 38 and that's 64P
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 05-20-2004, 01:42 PM   #5060
Hebiki's Avatar
i actually have a 51 tooth pinion thats 64 pitch the highest pinion ive used so far was my 48T 64P pinion
Buddha.. hehe..your not the guilty one of gearing a monster pro at 6.5 - that goes to alex N. hehe
Hebiki Design Works
Old 05-20-2004, 01:51 PM   #5061
Hardriven RC's Avatar
you can always put the spur on the motor and the pinion on the spurgearholder
Hardriven RC is offline   Reply With Quote
Old 05-20-2004, 09:45 PM   #5062
Well.....actually I've switched back to the tub...( and made some heavy modifications...secret..secret!) plus in addition to making the motor area larger, and for this hot wheather I think I just might run a 5 VDC fan in that little small area. It will provide enough cooling and most who've used a fan with that amount of power draw have had plenty of power to last the race. Maybe its just that lately its been REAL muggy down there at the track.
rustler753 is offline   Reply With Quote
Old 05-21-2004, 08:30 AM   #5063
Lem2- These packs should be run in your car not the T35. Everytime you run a pack as a cycle you use up one of your runs. I run the packs for mod immediatly and for stock I tend to run packs that are not brand new so the cells are working more like one cell versus having 6 cells.
Hebiki Maybe because you guys run indoors the motors will hold a bigger gear. Here in florida we run 6.5-6.6 on a track that has a huge sweeper and a track size of 140 feet by 70 feet.
Rafael
rangulo is offline   Reply With Quote
Old 05-21-2004, 02:36 PM   #5064
Regional Moderator
Racer_Chick's Avatar
Send a message via AIM to Racer_Chick Send a message via MSN to Racer_Chick
Hey Raf,
Which track is that? lol.
Toni Green|Munno Graffix|CFX Racing
Кто глупее? Дурак или дурак, который следует за ним?
Racer_Chick is offline   Reply With Quote
Old 05-21-2004, 03:09 PM   #5065
JDXray's Avatar
Send a message via AIM to JDXray
what are some good voltage #'s? And Cell voltage.
JDXray is offline   Reply With Quote
Old 05-21-2004, 03:19 PM   #5066
Hebiki's Avatar
for fukuyama... the team drivers get all the 1.180+ batteries. any left over are sent to the hobby shops (like speedtech rc).
if you can get HIGH 1.170s... get them. i was able to get 1.183.. but it took awhile to get them because team drivers get priority. most of my packs are 1.179s.
Hebiki Design Works
Old 05-21-2004, 03:21 PM   #5067
JDXray's Avatar
thanks hebiki, how about on SMC batteries.
Old 05-21-2004, 03:21 PM   #5068
stjerno's Avatar
I have a equlizer board with no cut of or electronics on it..
Should I use it to discharge my new Fuku cells after a run ?
When everyone say that the cells should be discharged to 0.9V is that then their voltage when discharging or when they are resting ?
Thanks for you help
stjerno is offline   Reply With Quote
Old 05-21-2004, 03:51 PM   #5069
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Thanks for you help
Personally, I wouldn't use it. .9v is the voltage while discharging. As soon as the discharge load is taken away, the voltage will bounce back up above 1.1 or so per cell. You really should equalize with a tray with a cutoff of .9v to make sure you're not over discharging the cells.
Jon Kerr is offline   Reply With Quote
Old 05-21-2004, 04:01 PM   #5070
Hebiki's Avatar
your gonna have to visit the SMC thread for that. cant go wrong with fukuyama batteries tho.
Hebiki Design Works
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
