Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-30-2004, 04:46 PM   #4456
I just picked up some high 1.16's to try and if I like them I'll definitely get some 1.17's. I want to try the 1.16's compared to a couple of other matchers and once I see what works best I will get my race packs. Reading these boards it definitely seems that Fukuyama makes a good product but I want to see what else is around as well. Just out of curiosity, how do you know what kind of run time you're getting for sure when you buy the higher 1.16's or 1.17's? I am curious, what are the new batch of cells you guys are talking about?
dimples is offline   Reply With Quote
Old 03-30-2004, 05:21 PM   #4457
Speedie's Avatar
Originally posted by PitCrew
SIXTY NINE DOLLARS!!!
GOOD LORD THATS ALOT OF MONEY!
I cant believe someone would have a negative comment on Fukuyamas prices. From the beginnig they were the lowest priced highest quality available. Has anyone else notices that since Fukuyama has kept thier prices down alot of other matchers seem to be lowering prices to compete?
Thanks alot Fukuyama.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-30-2004, 05:51 PM   #4458
PitCrew's Avatar
Sorry dude(s)
So what do I get for 69 dollars. How about you keep the shrink wrap. Maybe not put it in the box.
Guess you guys haven't heard the chris rock comedy stuff.....
No harm intended.
Acctually NO. I haven't noticed a decreas in prices. Not that Fuk are over priced, I just don't see them controling the market on prices.
PitCrew is offline   Reply With Quote
Old 03-30-2004, 06:17 PM   #4459
Maj. Teeth's Avatar
Sorry dude(s)
No harm intended.
I can't believe my company and I are being bashed by you like this. I don't even recall you being a customer! This is not the first time you bash us. Please! I don't know what my company or I have done to upset you, but I certainly DO NOT appreciate this from you. You got a problem with me!? call me and we'll talk about it.
Maj. Teeth is offline   Reply With Quote
Old 03-30-2004, 06:29 PM   #4460
Maj Teeth: I don't think his comment was meant to be taken that seriously. Just a bit of light hearted humor.
Awesomatix A700L (building) | VBC Wildfire D07 (building) |416WE/X Smokem | Hobbywing 120A v2.1 | Sanwa M11x
itchynads is offline   Reply With Quote
Old 03-30-2004, 07:10 PM   #4461
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
I don know about the rest of you guys, but after purchasing a few FUKUYAMA 1.17+ cells, i am waiting to get more.
The price is fair everywhere on the net. Its not the cheapest and cant be said the most expensive.
But if service come second after the price,FUKUYAMA will stand out as the best.
John had gave me lots of help the past few weeks.
Just my 0.02
AdR|aN is offline   Reply With Quote
Old 03-30-2004, 08:00 PM   #4462
whats up dude, just got back, got 6th as you know and just wanted to say that my batteries were very good at this race. Let me tell you the way my car was working in the qualifier was very hard on the bats because it was lifting the tires and then comming back down when I was already full throtle, so there was a lot of amp draw. Very good power and run time, thanks for eveything and lets keep going forward.
se ya soon,Chris
Chris Tosolini is offline   Reply With Quote
Old 03-30-2004, 08:19 PM   #4463
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Good job at the Nat's Chris. Way to represent.
Jon Kerr is offline   Reply With Quote
Old 03-30-2004, 08:29 PM   #4464
thanks, Chris
Old 03-31-2004, 02:17 AM   #4465
Cole Trickle's Avatar
Promatch is correct when they said 125 to 130 because they based the charge amps at 5 amps. For us, we recommend a slightly higher temp since the cells will heat up more when charged at 6 amps instead of 5. So indeed, both are accurate.
I normally temp the cells at the can and not at the top/solder joint. Remember that these GP3300 is capable of withstanding 200f when discharging but ideally, you want to stay below that. 170f to 180 f while discharging is optimum. This was tested at 30 amp discharge.
As for battery life, it really depends of how you take care of the batteries. DO NOT LEAVE IN COLD, DO NOT OVER CHARGE, DO NOT DEAD SHORT, DO NOT REVERSE POLARITY.
Dan
Hi Dan
Thanks for the answer. Promatch aint very specific about the charge rate, they recommend 5-6 amps, lower for runtime, higher for punch.
With my Sanyo 3000 HV, I've experinced that around 40-45 deg C (104-114 deg F), they are much less punchy. At 50-52 deg C (=122-126 deg F), they perform well. I have no experience with higher temperatures.
I see the point in charge rate versus temperature. I will charge at 6 amps, since I race in stock class. I could adjust the cut off sligthly lower to achieve a lower temperature.
So can you please enlight me about temperature versus performance? Even though they seem to resist high temperatures quite good, I would like to go lower to not stress them more than nessecary.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-31-2004, 05:22 AM   #4466
danjoy25's Avatar
R/C Tech Charter Subscriber
Trader Rating: 37 (100%+)
Default Best charger for Fuku
I have been using Fuku for the last 6 months now and is very happy. Looking to upgrade my CDC V6 charger to a CDR-5000 or GFX. Which would be the best?
Awesomatix A800 & A800X/ Mugen MTX-5 / 3 Racing F113 / Kyosho RB5 / Kyosho Mini-Z
danjoy25 is offline   Reply With Quote
Old 03-31-2004, 06:08 AM   #4467
John Fontaine's Avatar
Send a message via AIM to John Fontaine
I think that either charger will be very good, but I do know, the CE line has been the leader on the charger market and what Dan and I use and we believe it is the benchmark for all the chargers. Dan and I love our GFX's.
Chris, awesome job bud. I gotta give you a ring and find out how to be such a good driver like you. Seeing the vids of the mod mains and that was so spectacular. I'm glad you're the elite of RC racers.
As for 69 dollars for a matched cells? I think that is cheap compared to the product/voltage of the Sanyo 3000's and NiMH 2400 packs just a short time ago (1.13's and 1.14's were top with a run time of 380!). The price of the cells is the technology used for zapping and processing the cells. If you have gone to any of Dan's facilitys, you can see he spent a lot of money to build this business and he has done it right! So right, that everyone is jumping on the boat. His CET process is second to none, and he's even coming up with a new version. I'll stop there, these cells are worth the money! The choice is up to you. Just ask Adrian and Tor Erik, they're people I have helped lately and they love the cells.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-31-2004, 06:14 AM   #4468
AdR|aN's Avatar
Originally posted by John Fontaine
I'll stop there, these cells are worth the money! The choice is up to you. Just ask Adrian and Tom Erik, they're people I have helped lately and they love the cells.
John
Old 03-31-2004, 10:59 AM   #4469
I can't wait to give them a try. I'm curious to see if the high 1.16's perform like others 1.17's. I even got one pack of 1.17's to boot. Now that I think about it 4 packs of batteries was a bit much for a test but oh well, they should be good As far as pricing, they are pretty much even with everyone else or better. Pro match and SMC seem to be the two big dogs for true competition packs now adays but Fukuyama is right there with numbers and pricing. I know I liked talking to them and ordering with them direct and you can't do that with another large company. Now on to the battery question, do you guys at Fukuyama recommend equalizeing the cells? And if so what tray? I probably won't deadshort but their is no guarantee since I will probably run stock and maybe very little mod.
Rob
Old 03-31-2004, 11:14 AM   #4470
Yes, Fukuyama is running definately with the big dogs, PMR and SMC
On Fukuyama's website, it recommends not to dead short the packs. I would trust their advice, after all, they have done tons of testing and know the best way to treat the cells.
As far as the equalizing tray, the answer is yes. I use my Rayspeed Discharger and a trinity realtime 2. I like the Rayspeed the best because it cuts off at .9v/cell and the realtime if left on too long will drop the cells down to 0 and that's not good for these GP3300's. There are other trays on the market too that will work one. Novak's new tray and some integy trays are good though I have no personal experience with these. Maybe someone else can chime in here.
Enjoy the cells, I know you'll be happy with them. If you want more information, visit fukuyama's website.
John
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
