Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-29-2004, 06:48 PM   #4426
AdR|aN's Avatar
Send a message via ICQ to AdR|aN
Originally posted by John Fontaine
My CE GFX rocks...mostly with the mods. I would love to get another turbo 35BL or GFX to replace my quasar pro which I hardly ever use anymore because the CE GFX does such a good job. Maybe I'll get that futaba to replace the quasar pro. Anyone know the dims on that futaba? I've heard from someone it's a pretty big unit. Anyone confirm?
John. I heard that the unit is much smaller then your Turbo 35.
But weight wise, i think its heavier.
AdR|aN is offline   Reply With Quote
Old 03-29-2004, 10:40 PM   #4427
Location: Built By The Racers For The Racers. Corona CA
Originally posted by jkerr0043
BTW, good job today Randy. Nice to have a car that's not glitching all over the track, huh.
Jon and Randy did a great job at R/C HEAT! Jon is getting faster every month!
Randy is one hell of a driver! Second place this week! I think First is coming next week! This guy can fly! Your lap times were all consistant 12's
I looked at the times pulled from the Factory drivers and yours, you are only an average of 1/2 to 3/4 of second off them per lap.
Great Job guys!
Peace...
John G.
R/C HEAT is offline   Reply With Quote
Old 03-29-2004, 10:43 PM   #4428
Oh fogot to mention, Randy took second in the A Main! All in all, he beat 44 others in 19T and Jon was 5th out of 44!
Way to represent guys!!!!!!
Old 03-29-2004, 10:55 PM   #4429
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Thanks John. I'm having a lot of fun at your races. I just need to put a full day of racing together. I'm going to try and make the Castle Park races my regular travel races.
Jon Kerr is offline   Reply With Quote
Old 03-29-2004, 11:26 PM   #4430
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Next time out, I'll try to get the car to actually work, it was horrible yesterday.. Hopefully next time out, I'll get it running .5 second faster per lap and get that nice silver cup
Old 03-30-2004, 01:52 AM   #4431
Default powercube
Hi all.
Any one here got fukuyama's power cube cell set?
I was thinking of ordering it and before I do, I was hoping to get some info from people bought it.
Thank you.
abarth is offline   Reply With Quote
Old 03-30-2004, 02:09 AM   #4432
Cole Trickle's Avatar
Originally posted by JohnMatrix
OK GUYS,
My "Super Brain" 959, which has actually no brain has crapped out.
THere for this week I am looking to buy a charger for my Fukuyama's.
Im willing to spend up to $200 for a charger.
My Front runner is the LRP competion charger.
What do you guys like and think?
From what I've been told, 10 amps is too little to discharge with. At least 20 or better 30 amps, will ensure that your packs stay punchy.
Off course, it'll depend on if you need a build in discharger...
Personally, I choosed the Integy/Eagle 16x5v6. Absolutely no problems with quality and finish so far. Many good features, including IR and average voltage measurement - even for single cells. So you can do some matching, if needed.
Schumacher Mi5 - Sanwa MT-4 / RX-462 / KO Propo PDS-2123 - Nosram 5600 X-treme Saddle Pack - LRP SPX Zero/X12 17,5 - Nosram Stealth Touch Evolution - MAAS SPS 9250
Cole Trickle is offline   Reply With Quote
Old 03-30-2004, 03:31 AM   #4433
Hardriven RC's Avatar
Default Re: powercube
Originally posted by abarth
Hi all.
Thank you.
Hi,
As far as practice packs they are allright. Since they are not matched they will need a bit of extra care. For racing however i would go for the matched ones.
Regards
Hardriven RC is offline   Reply With Quote
Old 03-30-2004, 04:13 AM   #4434
I've noticed that Promatch recommend a temp of 125-130 F, while Fukuyama recommend 135-155.
I've also noticed that my packs are hotter if I measure on the end of the cells (at the soldering bars), than compared to the side of cell.
So I'm in doubt of:
* where to measure the temp and,
* which temp will give best track performance and
* which temp will give the longest battery life? (not runtime)
Thanks.
Old 03-30-2004, 04:40 AM   #4435
Gutter Ball's Avatar
Default Canadian Distributor?
I emailed the folks at http://www.rolin.ca/racing with no responses. Is there anybody else in Canada that sells your batteries? Shipping and duty from the US would be pretty expensive, but if I can't get them anywhere else. Thanks
Gutter Ball is offline   Reply With Quote
Old 03-30-2004, 10:09 AM   #4436
Maj. Teeth's Avatar
Hi all.
Thank you.
They are great batteries. The only thing is they aren't matched based on runtime so you will need to equalize it before charge. The voltage ranges from 1.145 to 1.165. Runtimes between 380 to 410. It would be a nice cost alternative to matched cells. Now, if you compete in the National level, then I would suggest full blown matched packs. But for club level racing, they are way good.
Dan
Maj. Teeth is offline   Reply With Quote
Old 03-30-2004, 10:18 AM   #4437
Maj. Teeth's Avatar
So I'm in doubt of:
Thanks.
Promatch is correct when they said 125 to 130 because they based the charge amps at 5 amps. For us, we recommend a slightly higher temp since the cells will heat up more when charged at 6 amps instead of 5. So indeed, both are accurate.
I normally temp the cells at the can and not at the top/solder joint. Remember that these GP3300 is capable of withstanding 200f when discharging but ideally, you want to stay below that. 170f to 180 f while discharging is optimum. This was tested at 30 amp discharge.
As for battery life, it really depends of how you take care of the batteries. DO NOT LEAVE IN COLD, DO NOT OVER CHARGE, DO NOT DEAD SHORT, DO NOT REVERSE POLARITY.
Dan
Old 03-30-2004, 10:21 AM   #4438
Maj. Teeth's Avatar
Default Re: Canadian Distributor?
please send an email to: [email protected] with your contact info. I will personally refer this over to Rolins Event and have them contact you. Sorry for any inconvienences.
Dan
Old 03-30-2004, 11:10 AM   #4439
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Dan is the man! How can that even be disputed?
I bet that guy in canada that bought your T1R is even wanting packs now.
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-30-2004, 11:20 AM   #4440
rc-zombies's Avatar
The guy that bought the T1R from Dan awhile back...has it for sale now....
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
