Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 03-03-2004, 08:14 PM   #4006
JusBox's Avatar
Originally posted by Chris Tosolini
hey anyone out there what do you think if you take the bat off charge as soon as the volts start to drop..
Not sure if i understand what you're asking but isn't that what the charger looks for to end the charge anyway???
JusBox is offline   Reply With Quote
Old 03-03-2004, 08:19 PM   #4007
Ok guy, what I'm saying is you can set your peak detec but watch your bat and it will go to 9.25 and then it will drop down to 9.20, I beleave that if you can watch it and take it off right at peak its better.. and if you put the peak detec to low it will false peak..
Chris Tosolini is offline   Reply With Quote
Old 03-03-2004, 08:26 PM   #4008
Randy Caster's Avatar
Trader Rating: 46 (100%+)
Dan - YGPM
Old 03-03-2004, 08:32 PM   #4009
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
I see your point Chris. The higher the voltage is maybe a little more power at the start. Maybe something to try. Have you been doing this?
Jon Kerr is offline   Reply With Quote
Old 03-03-2004, 09:01 PM   #4010
ya I do this sometimes, I just want to here some ideas on this. I think its good, peak detec is there so you dont have to watch it but its not perfect.
Old 03-03-2004, 09:05 PM   #4011
I've tried it, but didn't notice any increase in track performance at the start. You propably use up that extra voltage checking through the transponder loop and lining the car up on the grid...
It might help a stock racer if someone checked his car in and set him on the grid, but for mod, wouldn't having the extra pack capacity be more worth it?
Old 03-03-2004, 09:20 PM   #4012
I don't know but if the bat drops .20 I thought that is capacity that is lost on the charger, I need to know, I when it drops that meens its done right.. so dont let it drop and dont over charge to get it hot. Hope Dan will give some ideas tomorrow..
Old 03-03-2004, 09:26 PM   #4013
Speedie's Avatar
If your looking for the drop and it goes from 9.25 to 9.20 thats a .05 peak detect isnt that what most people are setting thier chargers at anyhow. I know what your saying but I dont think that we cold get it any closer than our state of the art chargers can.
www.victoryhobbies.com Greenbay, Wisconsin
Speedie is offline   Reply With Quote
Old 03-03-2004, 09:32 PM   #4014
I see what you mean, .20 is a lot of voltage, without knowing a ton about batteries, it's hard to answer. It would be cool to get a discharge graph of the battery. Say the battery peaks out at 9.2, but drops to 9.1, I'd think you'd start your run with 9.1, but I wonder that after drawing power from the pack if it will peak back up to 9.2 say a lap into the run...
Dan... where are you, lol
Old 03-03-2004, 09:33 PM   #4015
Oh I see my chargers only go .10..20.30, ect.. I ether way I got the idea.. thanks..
Old 03-03-2004, 09:39 PM   #4016
Speedie's Avatar
what type of charger do you use? those settings could be 10-20-30mv 10mv + .01v. I think the pulsar I used once was like that or maybe it was a Novak I forget.
Old 03-03-2004, 09:39 PM   #4017
Yokomo
Old 03-03-2004, 09:42 PM   #4018
Team EAM
EAMotorsports's Avatar
Trader Rating: 79 (100%+)
Send a message via AIM to EAMotorsports
Hey Chris have you tried using just the temp setting on the yokomo charger instead of peak detect? If not youd be surprised of the difference...Never false peak a battery again.
If im not mistaken the optimum temp for a battery when it goes on the track is 147 degrees...I'll have to look at my notes.
ea
Contact Us
Team EAM, Our Facebook
Team EAM | Xray | RCAmerica | Hudy | APEX Raceway and Hobbies | RC Mission | Killer Concepts | AVID | Hobbywing.
EAMotorsports is offline   Reply With Quote
Old 03-04-2004, 06:50 AM   #4019
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
On my gfx in graph mode while charging you can easily see when the cells reach peak voltage by just looking at the graph peak. I have never turned it off at this point (1st peak) because the cells have not gotten up to racing temperatures at this point. I use the .05 or .06 voltage drop to bring them up to temperature as well as getting a little more runtime into the cells during this point. I think cutting them off prematurely than you will be getting the same voltage out of the cells but they wont be idealy at temperature of 135-150 for racing. I have however, never really tested this theory and used a heat gun to temp the cells when they hit their peak voltage. I'll try it next time to see what temps the cells are at when at peak voltage before they drop to the delta V and what temp they are at when the GFX stops it's charge cycle.
I have in the past stopped the charge permaturely during the 2nd peak before a race so the cells do not over heat.
Good discussion.
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 03-04-2004, 12:43 PM   #4020
wolfeman09's Avatar
Send a message via AIM to wolfeman09 Send a message via Yahoo to wolfeman09
If I'm not mistaken that one does take them down to 0 and that is worse than not equalizing. Try tossing them into a Rayspeed once before the first charge of the day and see what it does. If I'm at the track you can come by and try mine.
I should be at the La Mirada Race and the next Corona Race is you are coming up again. Thank you for the offer.
Right now, is the Rayspeed the best equalizing tray on the market?
Are there any others that you would recomend?
Thanks....
wolfeman09 is offline   Reply With Quote
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
