Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 02-15-2004, 02:15 AM   #3601
Fire's Avatar
Originally posted by JohnMatrix
Hey John(jkerr),
You said that,
Unfortunately I have a 70 dollar charger right now. and since i just poured 150 in to the batteries and 60 in the discharger so i wont be able to get a better charger for a whlie.
This is the charger I have,Super Brain 959
Is there any way to properly use my charger with the Fukuyama's? My plan was to charge the new Fukuyama 's I just got at 1 amp.
Feed back would be greatly appreciated, I dont want to waste my 150 dollar battery investment.
Thanks.
this charger will not physically hurt your packs, but it will not deliever the ultimate performance since the highest charge rate is 4.5A
and you definitely need to change your plan as 1 amp will do you no good, you will need almost 4 hours to charge a pack and the pack will be flatter than the strips at airports
Fire is offline   Reply With Quote
Old 02-15-2004, 05:00 AM   #3602
B4
B4's Avatar
Default Eagle Racing CDC 6.0b charger
I just got the Eagle Racing CDC 6.0b charger and would like to know what to set each of the settings on to charge the GP3300 matched packs.
B4 is offline   Reply With Quote
Old 02-15-2004, 05:41 AM   #3603
Send a message via AIM to R/C Anonymous
took top honors last night in stock buggy ....i was using the power cube sells and Anonymous motors....great combo...more speed down the straight and more torque out of the corners then everyone else...thanks Fukuyama for making great packs...i even save my 1.174 packs now cuz my power cube has more then enough juice
Geoff C.
R/C Anonymous is offline   Reply With Quote
Old 02-15-2004, 08:41 AM   #3604
KevanB's Avatar
For the new 3300's you want to charge them at 4.5 amps, with 50mv. Everything else should be setup fine for it.
KevanB is offline   Reply With Quote
Old 02-15-2004, 08:55 AM   #3605
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
Hey John(jkerr),
You said that,
Thanks.
You really need to not charge @ 1 amp. Like Fire said, it'll take for ever and you will have no punch or power. Charge them @ 4.5 amps since that's as high as that charger goes. The problem I always had with that charger was the false peaking with any NiMh cells, be it Sanyo 3000's or GP3300's. What you need to do with that charger is charge @ 4.5 amps. I can't remember if the delta peak setting on that charger is accross the pack or per cell. But set it to where it's about 50mv accross the pack. If the charger false peaks, just start it again and continue to restart the charge until the pack is good and warm. The only reason I said a cheap charger could hurt your packs is I also had a charger that did the opposite. It would never peak. Just kept pumping juce into them. That'll kill your cells quickly!
Jon Kerr is offline   Reply With Quote
Old 02-15-2004, 06:03 PM   #3606
KevanB's Avatar
YESSS!!!! I just got back from racing with my new fukuyama packs (1.15). And I got 1st place bmain, and advanced to a-main!! With my new packs Im now running with the fastest guys there! Before I was running with the slowest due to bad batteries.
And I can even notice a difference between my 1.15 fukuyama packs and my 1.16 pro match packs.....fukuyama is a lot faster, and my pro-match's wire just fell off (bought it assembled)!!
I shouldve got a print out of my times, but thanks to your AWESOME packs I got the fastest lap out of the entire b-main (11.7). Most the fast guys are running around 11 seconds average so Im doing great!
Once again THANK YOU so much!!
Old 02-15-2004, 06:08 PM   #3607
Jon Kerr's Avatar
That's great. Glad to see you're getting results.
Old 02-15-2004, 06:10 PM   #3608
KevanB's Avatar
The charger seemed to charge them fine. I will, in the future, charge them with settings of 4.5 amps, 50mv, 3400mah (this high enough?). Taht way Im sure to get at least 3300mah out of it.
As long as I peaked them right before each heat, I was fast fast fast.
Old 02-15-2004, 06:28 PM   #3609
Jon Kerr's Avatar
Those settings sound good. If you have some way to measure the temps, check the just as they peak. You should be around 135* depending on the outside temp. http://www.tempgun.com/ is a good place to get a good temp gun for a great price. That's the one I've got.
Old 02-15-2004, 06:29 PM   #3610
KevanB's Avatar
Alright, Ill just borrow someones at the track nextime. Thanks!
Old 02-15-2004, 06:32 PM   #3611
Jon Kerr's Avatar
Actually, if you're only able to charge @ 4.5 amps, they probably won't reach over 115 to 120. I usually charge @ 6 amps and that will get the cells good and toasty
Old 02-15-2004, 06:33 PM   #3612
KevanB's Avatar
They seem to be catching up fine with other people who charge at 6. I will charge at 6 once I get the pulsar sport.
In about a week or two Ill have that $100 (work!!)
Old 02-15-2004, 06:53 PM   #3613
KevanB's Avatar
Here's a cool (imo) background I just made out of a photo I just took at our track today. Let me know what you think. Maybe you can even put it on the fukuyama website (like home page and have monthly calendars, kinda like www.hpiracing.com ).
*if only it was more clear! next time Ill take the picture in a higher res*
Old 02-15-2004, 08:31 PM   #3614
SalvadoriRacing's Avatar
Send a message via MSN to SalvadoriRacing Send a message via Skype™ to SalvadoriRacing
Talking
hey dan......
thanks for the tips to build the packs....
i've built my pack.....i think i did a good job once i built a battery pack for the first time.....i promise a better job next times!!!
Salvadori Racing
www.salvadoriracing.com.br
O.S. Engines - KM RACING - CONTACT TYRES - SAVOX - LRP - ARC | Blitz | Titan
SalvadoriRacing is offline   Reply With Quote
Old 02-15-2004, 08:32 PM   #3615
Thumbs down upload fail
I TRIED TO ATTACH ANOTHER PIC BUT THE FILE SEEMS TO BE CORRUPTED......
Salvadori Racing
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
