Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-24-2003, 05:28 PM   #301
Jimmy Fukuyama's Avatar
Originally posted by teamAE
They should onlyt be run 2 time a day right? Also witht the packs I have been chagring them then discharging to 5.4 before the second charge then after that leave them at what ever they are after that run? Does this sound ok?
Thanks Drew
That should be fine.
Jimmy
Jimmy Fukuyama is offline   Reply With Quote
Old 09-24-2003, 05:44 PM   #302
Ok thanks
teamAE is offline   Reply With Quote
Old 09-24-2003, 05:53 PM   #303
Ok thanks
Ok, I mistaken what you said. You should charge it and race. Then after the heat/race, let it rest or cool down for at least 1 1/2 hours. Then repeak it back up to .05 or .48mv depending on your charger and the temp should be around 145f~155f. Then after the second heat/race, discharge it down to 5.40v for 6 cell pack or 3.60v for a 4 cell pack and let it rest. I don't believe that you need to recharge it back up even if you're planning to store it for 5 days. If you plan on storing more than 5 days, you might want to charge it up the day before the race and discharge it a couple of hours later so to make sure it's taking charge ok and there is no false peak. Then on race day, charge it up like normal and win races...
Jimmy
Old 09-24-2003, 07:34 PM   #304
holycow's Avatar
What the?
Didn't I just order these cells yesterday? AWESOME!
I gota say.. i am VERY impressed with the #s shipped... I can't wait to try them!!
holycow is offline   Reply With Quote
Old 09-24-2003, 07:36 PM   #305
Intermision's Avatar
Send a message via AIM to Intermision Send a message via Yahoo to Intermision
I don't like reading the whole thread so I will ask.Where is their website?
Intermision is offline   Reply With Quote
Old 09-24-2003, 07:44 PM   #306
holycow's Avatar
http://www.fukuyamaracing.com
Old 09-24-2003, 08:09 PM   #307
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Originally posted by holycow
What the?
Holycow your batteries are not in your car correctly!!!!!
mike_Webb is offline   Reply With Quote
Old 09-24-2003, 08:17 PM   #308
holycow's Avatar
aahh oh no!!!
nah.. i just slid them in there for the shot
Old 09-25-2003, 12:35 AM   #309
RBLove's Avatar
Trader Rating: 72 (100%+)
Default Charging/Discharging
Recommendations: Below are the methods I use to charge and discharge. Boviously with my Fukuyama Racing packs...
Before the first charge of my race day I will put the pack in an equalization tray. I only do this one time per race day before the first charge.
I charge at 6 amps with a .04 cut off. I attempt to have the charge complete right before racing. Usually never happens (too late or too early). So I repeak the pack "1" time at the same charge rate and cut off.
After the run I discharge the pack at 30 amps to 5.40 for 6 cell or 3.60 for 4 cell.
I let the battery rest for a couple of hours. Let them temp come down and get a good rest.
I try to practice one time each with my batteries and then race and qualify with them. Second run on the Fuku packs is AMAZING.
Second run I charge the pack the same way, but do "NOT" tray the pack. Once the run is over I discharge at 30 amps to 5.40 or 3.60 and let the battery sit until the next race day.
I have found no ill effect letting a battery sit at a discharge of 5.40 or 3.60 for a few week time period. Seems to be no advantage in storing the battery with a charge "UNLESS" you are talking months.
For mod racing:
I like to run the pack one time per race day and charge at 5 amps instead of 6. Provides great run time and still gives the punch needed. If chosen to run a second time in the day the run time drops slightly, but voltage goes up and ir's go down. This is why I HIGHLY recommend two runs for stock and only 1 for mod if run time is an issue.
All of my charging is done on a CE GFX.
Hope I didn't ramble on to much and you find the information to be beneficial. You may already have a system that works for you and that is great, but if you are looking for a method or need some advice try the above. Feel free to PM me or e-mail me at [email protected] with any questions you might have or post them here. I am here to provide support to the Fukuyama Racing customers.
WWW.FUKUYAMARACING.COM for all your voltage needs
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 09-25-2003, 01:18 AM   #310
holycow's Avatar
Anybody know of a conversion equasion to figure out what a cell would be rated at if discharged at 30 amps, if you only have the 20 amp numbers? 1.23 at 20amps, is what at 30amps?
Old 09-25-2003, 01:49 AM   #311
RBLove's Avatar
You really cannot convert. The battery is going to give a much different effect at 20 opposed to 30.
Used to be said that:
1.17 @30 is a 1.19 @ 25 and a 1.21 @ 20. 2 point difference. I do not believe this to be true. If you have some cells that are matched at 20 amps and want to know their output at 30. You could cycle them on a Turbo 30/35/GFX or send to a matcher to have batteries rematched at 30.
Old 09-25-2003, 07:51 AM   #312
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Rob, great charging instructions. Do you happen to use the long lockout mode of 600 seconds when charging for the first time after traying the cells to lockout false peaks during the first 10 minutes of the charge?
John
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 09-25-2003, 12:09 PM   #313
Maj. Teeth's Avatar
Default Converting
Maj. Teeth is offline   Reply With Quote
Old 09-25-2003, 01:03 PM   #314
Good information Daniel.
Old 09-25-2003, 01:43 PM   #315
dpaton's Avatar
Send a message via AIM to dpaton
Dan-
I'l be ordering cells soon, I promise. Hopefully before the end of the month so I can get in on that free shipping goodness
As someone coming from the other end (charging and power managemnt) I'd love to talk shop over lunch with you if I'm ever in SoCal again. Any thoughts on the higher than ideal charge rates (5-6A, vs 3.75-4A) in regard to capacity training and self-heating? Or is that too close to the secret sauce
Feel free to start another thread if you think I'm getting too techie for the general Fuku batt. one.
-dave
dpaton is offline   Reply With Quote
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
