Fukuyama Batteries
Old 12-12-2003, 01:15 PM
  #2386
Registered User
Post the flu
damn randy... your always sick!!!!!!!!!
looks like were gonna have to boost your immune system.....
drop down, gimme 25 push-ups......
count em out
muggleh8tr is offline
Old 12-12-2003, 01:18 PM
  #2387
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Default Re: the flu
count em out
I havent been sick in about 2 years, just cought this cold recently, but didnt even miss work. I tough it out
Randy Caster is offline
Old 12-12-2003, 01:20 PM
  #2388
rc-zombies's Avatar
I think a couple shots of brandy will cure anything. ...
rc-zombies is offline
Old 12-12-2003, 01:21 PM
  #2389
Registered User
Post the flu
2 years.... yeah-- i think that was the last time i saw you....
Old 12-12-2003, 01:43 PM
  #2390
John Fontaine's Avatar
I designed the machinery to package the flu mist vaccine.
John Fontaine is offline
Old 12-12-2003, 02:17 PM
  #2391
I havent cought the flu yet, just makin sure I dont. But if I do get it, I'll have to give your vaccine a try
Old 12-12-2003, 03:21 PM
  #2392
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
That's pretty cool!
Jon Kerr is offline
Old 12-12-2003, 04:57 PM
  #2393
Moderator
Speedo's Avatar
I used an 80 watt Weller iron, and I thought I did a decent job assembling it but who knows. Next pack I get from Fukuyama I'll have assembled by them, and see if that makes a difference. IR was considerably higher than the lables.
Speedo is offline
Old 12-12-2003, 11:32 PM
  #2394
Maj. Teeth's Avatar
There is a difference in resistance but it only depends on the solder you're using and how much. If you doubt the voltage, I'll gladly take it back and take a look at it. The batteries, like all matchers, are done and matched in an ideal control enviroment. Once soldered and built, there should be an increase of IR no doubt. There is also a deviation with a T35, T30 and GFX although the readouts should be more accurate when each cells is read individually. But for what its worth, if the runtime is good and solid and performs under load with good to great punch, then there is absolutely no problems with the pack. Here's what you can also do. Equalize the packs for 20 mintues with an Octane 2, then charge and cycle at 6 amps with an intermission of 6 minutes of cooling only so the pack is still hot to warm, then discharge at 30 amps. Once done, let it rest and repeat the process after 2 hours. Now, the second cycle is a more accurate number of what your cells will look like under racing condition. Hope this helps and Thanks again for supporting Fukuyama Racing!
Dan
Maj. Teeth is offline
Old 12-12-2003, 11:43 PM
  #2395
Maj. Teeth's Avatar
Default Heads up T4T
Guys, just wanted to let those who are planning the local T4T race this Sunday that I'll be there but because there might be more people attending and pitting with us, if you can please bring your own pit table, chair and an additional tent. I'm hoping we can all be having a blast with the FUKU row of racers but my tent is only a 10x10'. The gen is 2000watt Honda but there's already 3 charger, 2 solders and a compressor tapped onto it. So let's hope we have enough to share.
I'll also bring the soda, bottle waters, and ice. There's others in the ice chest but I'll just let you find out.
We won't be carrying any new packs of batteries since our inventories are quite low this week and the numbers are mostly 1.16s. Therefore I must apologize. Lets just make this race outing a fun one and all party a bit more then usual since it's the last Parking Lot race of the year. Hope you all can bring that Xmas mood with you and rock the track! I'm wanting to meet all of you who I might have missed in the last Toyota Race and those who I've meet, lets just hook up again and party some more.! yeah!
See ya there.
Dan
P.S. We're talking about the Toys for Tots charity race out in La Mirada this coming Sunday hosted by Charlie Barnes.
Old 12-13-2003, 03:37 AM
  #2396
McLaren's Avatar
How long can you keep a battery without using it and not causing harm to it?
McLaren is offline
Old 12-13-2003, 06:30 AM
  #2397
I'm anxious about the La Mirada T4T race as well, had a great time hanging out in the Fuku pit last time, and it sounds as if it's gonna be a lot bigger this time around Too bad this batch of cells sucked, I was amazed at how many people switched to Fuku power at the last race
The only thing I'm not so excited about is the 3:30am wake up call
Old 12-13-2003, 06:33 AM
  #2398
wyd
Tech Legend
wyd's Avatar
Trader Rating: 50 (100%+)
Maj.Teeth I run more chargers and irons off my Honda 1000 gen so you should be ok. The compressor will use the most power, especially when you first turn it on. Might want to check all you chargers once you turn on the compressor as it might make them false peak.
wyd is offline
Old 12-13-2003, 06:55 AM
  #2399
We were actually fine with power last time with 2 chargers, 2 irons, lights, and the compressor. I gotta say that Honda generator is sweet, we had it right in the pit with us, and you couldn't even hear it over the other generators 200 or so feet out from us.
Old 12-13-2003, 10:49 AM
  #2400
Maj. Teeth's Avatar
As long as you bring the cells back down to 5.4v and store it in a dry place. It is good. It'll sleep for months.
Dan
