Fukuyama Batteries
Old 12-06-2003, 10:33 AM
  #2281
Randy Caster's Avatar
Trader Rating: 47 (100%+)
Hey Dan, YGPM
Randy Caster is offline
Old 12-06-2003, 03:40 PM
  #2282
picco007's Avatar
Trader Rating: 93 (100%+)
Default run time on gp 3300's????
Hey guys, I finally got to run my 4 cell fukuyama cells this weekend. I ran a 10 dbl in 1/12 scale, I had great punch and great run time. I TQ'd and won in 1/12 scale mod, Thanks Jimmy and Dan for great batteries.
After I was done, I discharged the packs at 20 amps and found to have 25 to 38 seconds left and 230 to 255 mah left. I was gentle on the throttle and I was told that I might have to gear the car different.
I want to keep my cells with as much run time as possible, do you have any suggestions that would help me keep my run time? I have a rayspeed discharger equalizer and conditioner if that helps....
let me know
Ronnie
picco007 is offline
Old 12-06-2003, 05:37 PM
  #2283
picco007's Avatar
Default Dan you have a pm.....
Hey dan check your pm box......
Ronnie
picco007 is offline
Old 12-06-2003, 06:18 PM
  #2284
Scrad's Avatar
Trader Rating: 15 (100%+)
Picco, if you still have about 25-30 seconds left when you discharge then your are geared just about right. You could also go up 1 tooth. I usually have about the same amount of discharge seconds. You can usually get about 3 more laps. You could also take some timing out of your motor or add a reciever pack and charge at 5 amps instead of 6.
Dan I won't be going to the Birds not enough money right now.
I think I convinced SpeediePhatt to get some Fuku cells. He saw how my 12th scale ripped it's way to a TQ and win today.
Another note I was running 19t with some tropical storm team guys tonight and at first I was running my PMR 3300 Sanyo's from last year and I was getting smoked down the straight. So I put the Fuku's in and problem solved. I just need to learn how to drive that dang xray though.
Scrad is offline
Old 12-06-2003, 06:56 PM
  #2285
picco007's Avatar
Default Thanks Scrad
I have heard some people on the other forums saying they are loosing 120 seconds of run time off of the gp 3300's. Have you heard this and what do we do to keep the run time at its max?
I would appreciate it.
Ronnie
picco007 is offline
Old 12-06-2003, 08:29 PM
  #2286
Speedie's Avatar
Originally posted by Scrad
I think I convienced SpeediePhatt to get some Fuku cells. He saw how my 12th scale ripped it's way to a TQ and win today.
Scrad if you call an A$$ woopin and MAD RIP convincing, Im convinced. I need an edge in stock rubber and 12th scale. Im gonna order some monday.
Mo knows RIP
Speedie is offline
Old 12-06-2003, 08:49 PM
  #2287
rc-zombies's Avatar
Default Re: Thanks Scrad
Ronnie
I've had my packs for 4 months now... and I'm still getting over 3600mah after I charge them up at 6amp with my Integy 16X5V6 and have plenty of runtime left.
rc-zombies is offline
Old 12-06-2003, 11:13 PM
  #2288
Hixsy's Avatar
dan,
once again thanks for the great packs, i managed a 3rd overall trophy for fuku and i won the last final with them!
thanks
Hixsy is offline
Old 12-07-2003, 06:35 AM
  #2289
picco007's Avatar
Default Re: Re: Thanks Scrad
Thanks, are you discharging them to 5.40 and leaving them until the next weekend? or are you putting them in a tray at one point? I would appreciate it.
Ronnie
picco007 is offline
Old 12-07-2003, 08:58 AM
  #2290
JR V's Avatar
Ive always discharged to 5.40v, then before I charge, tray, then charge.
JR V is offline
Old 12-07-2003, 09:23 AM
  #2291
hey guys
i was really dissapointed today , pole all the way thru both finals leading slightly but then dropped off as my friend came and taken the line with his racer GP3300 against my panasonic3000 UMH, i think i need to upgrade i think fucku'z willl be the coolest
GP3300 1.170-1.174
they are the ones i want, any one got any idea on other average specs? IR, runtime ect ect
thanks alot
Tarnjit
Evo_Uk is offline
Old 12-07-2003, 09:31 AM
  #2292
Speedie's Avatar
I just orderd a few packs to try out. Im sure I wont be disapointed.
Speedie is offline
Old 12-07-2003, 10:20 AM
  #2293
I know you wont
Old 12-07-2003, 10:38 AM
  #2294
can anyone answe my question please
Evo_Uk is offline
Old 12-07-2003, 11:09 AM
  #2295
Jon Kerr's Avatar
Trader Rating: 17 (100%+)
You'll probably see IR's around 14 to 16 and runtimes around 400 to 410.
Jon Kerr is offline
