Go Back   R/C Tech Forums > General Forums > Electric On-Road > Team and Company Discussions
Old 09-22-2003, 08:44 AM   #211
RBLove's Avatar
Trader Rating: 72 (100%+)
Jimmy,
I had TQ by 8 seconds until a fellow racer decided I shouldn't have it Car was just ballistic yesterday. Fastest lap was 10.8 and I had 6 or 7 10.7's in the main. Absolutely dialed.
Racers,
Go get some of these Fuku cells. You will not be disappointed. If you have any questions about charging and discharging let me know. I am here to help.
[email protected]
THANKS JIMMY & DANIEL
RC America, Xray, Hudy, R1 Wurks, EA Motorsports, ProLevel RC, Ulti Tires America, PROTOform
RBLove is offline   Reply With Quote
Old 09-22-2003, 08:57 AM   #212
John Fontaine's Avatar
R/C Tech Charter Subscriber
Send a message via AIM to John Fontaine
Originally posted by RBLove
Jimmy,
Racers,
[email protected]
I was the same way this weekend as well. For the 3rd qualifier I had three laps on the field at the end of the 5 minute main. I wasn't TQ this week as we all decided to bump it up from 19 turn and run total mod. I was running a Reedy T1 11 turn double with my XRAY 1.77 gears and I had so much punch I was always getting the hole shot and an early lead to the race. Small 58 mm foam dia limited my straight line speed so I wasn't the fastest on the straight, but my car was dialed and I could take everyone inside on the twisties I never had such a good time as I do now with these cells. They make all the difference. If I had Jimmy's knowledge of motors now than I would feel like a king
Any questions, please ask me as well. We're all here to help
Xray and Serpent....very dusty!
John Fontaine is offline   Reply With Quote
Old 09-22-2003, 09:41 AM   #213
mike_Webb's Avatar
Send a message via AIM to mike_Webb
Devin.. How were you gearing your X-Ray... what was your roll out?
I am running a 8x2 with a 19 rollout and this wekeend with some old packs my Brushes came unsoldered from the motor. The Gear mesh was fine and the car drivetrain spins for about 5-6 seconds without the pinion touching the spur. I could not figure it out.
What are you guys charging your packs at for mod. I was thinking 5 amps with 30mv cutoff.
Stock and 19 turn 6amps with 30mv cutoff.
B4 5.5 amps with 30mv cuttoff.
Mike Webb
mike_Webb is offline   Reply With Quote
Old 09-22-2003, 10:02 AM   #214
Mike Webb
Hey Mike,
For my Reedy 11 turn I was running a 124/32 with the 1.77's so that gives me a 6.86 final ratio. This could get a bit hot, but I have a 5 volt fan blowing on top of the end bell so that helps it cool quite a bit and not overheat for a lower ratio. I got a Orion 7CFM fan...quite a bit of airflow for .013 amp draw if that is correct, maybe .13..I need to check out the specs of the fan again. It's quite a big track you need to push the motor a bit. I found no discoloration of the brushes or comm.
I'm charging at 6 amps at .03 on my CE GFX. Repeak 5 minutes before the race at 5.5 amps @ .01 cutoff.
You must really be heating up the motor to have the brushes come unsoldered. My Mod was running about 130 degrees.
Hope this helps.
John
Old 09-22-2003, 10:05 AM   #215
was foolin around cause i had some time in my hands.. that took bout 3 minutes
if anybody likes it and wanna print decals, lmk i can make bigger versions..that probably takes 30 seconds
versa is offline   Reply With Quote
Old 09-22-2003, 10:13 AM   #216
Whoa, that looks pretty neat!
Old 09-22-2003, 10:14 AM   #217
mike_Webb's Avatar
I have no clue what I did. I was running 125/27 with 60mm foam tires. The car ran fine for the first pack and then the second pack at the end of the run I knowticed the brush shunts were not connected. This is with a Reedy Ti 8x2.
Old 09-22-2003, 11:06 AM   #218
Bizzare. Maybe one of the motor bearings locked up.
Old 09-22-2003, 11:17 AM   #219
stonedgti's Avatar
Trader Rating: 15 (100%+)
Jimmy,
Please also contact me when you get some good 1.17s in.
Thanks!
Team Powers | ORCA | OD 12 Racing | NorCal Hobbies | JWerks | Sonic Racing | Team Gayzer | AYO Racing | Team Hastings | Uncle Larry Concepts | Moonlight Toys
stonedgti is offline   Reply With Quote
Old 09-22-2003, 02:04 PM   #220
mike_Webb's Avatar
Yea... I checked that also. THe comm spins really well in the motor. Indoor racing is starting in 2 weeks so as long as I have it figured out by then I should be good. We have a lot of talented Factory Team Drivers are our indoor carpet track so hopefully I will be able to keep up with them.
Old 09-22-2003, 02:07 PM   #221
Super Moderator
Kraig's Avatar
Trader Rating: 71 (100%+)
What springs are you using on the motor? If they are the stock springs then that is your problem. You need something stronger like trinity's purple or Reedy equivalent. Usually running around 18 degrees of timing helps.
There is great need for a sarcasm font.
You never know when it will strike, but there comes a moment at work when you know that you just aren't going to do anything productive for the rest of the day.
Sometimes I post just to look at my avatar.
Kraig is offline   Reply With Quote
Old 09-22-2003, 02:24 PM   #222
I was running team paradigm purple and red springs in my Reedy Ti 11 double. Seem to work well, 24 timing.
Old 09-22-2003, 03:07 PM   #223
pro3racer's Avatar
Default website
is there a website to get fukuyama batteries, or is it just by email, i need a battery or two for this winter.
pro3racer is offline   Reply With Quote
Old 09-22-2003, 03:09 PM   #224
rc-zombies's Avatar
Default Re: website
http://www.fukuyamaracing.com/
you won't be dissapointed.
Old 09-22-2003, 04:13 PM   #225
GTMilenko's Avatar
I just made my order Jimmy could you let me know you got it ok,
thanks a bunch.
GTMilenko is offline   Reply With Quote
fukuyama batteries/ trinity batteries 20-50 dollars a piece. jackfast R/C Items: For Sale/Trade 10 02-22-2005 06:37 PM
3 fukuyama batteries HEWITT R/C Items: For Sale/Trade 3 07-19-2004 11:32 PM
fukuyama batteries TRF_StEvE Australian Racing 6 03-25-2004 05:04 AM
Fukuyama Batteries horniez Singapore R/C Racers 8 11-14-2003 01:19 AM
